My convergence board for my sony is messed up how can i fix it?
  • 10,594 Answers
Please mention exact model number of Sony TV to help you out.
Posted on Aug 07, 2008
Sony KP57W5500 with the blue convergence messed up?
do not change the board, change the convergence IC's which should be stk392-560's on the D board.
Mar 08, 2012 | Sony KP-57WS500 57" Rear Projection...
Top, bottom, and sides of screen are blurry
Hello there,
Being a practical technician I would assist you technicaly.
Please find G-Board in your TV and replace IC1502 & IC1506 (STK392-150)
Before replacement of above said ICs, check follwoing Fuses (PS1501-1502-1503-1504-1505 & 1506) all are 2A rating. If you have VOM (Volt Meter) then confirm +15Volt & -15Volt supply on G board. If you need further help, I can provide with pictures of related circuit portion.
Jul 07, 2008 | Sony KP-53V80 53" Rear Projection...
Sony kp-46v15 convergence problem dont know were to start on adjusting main convergence board in front were do i start there is 15 or so red green blue ajustments for horizontal and the same for vertical...
Do not mess with those, they don't just go out. they are also for skew linearity, heighth, width for vertical and horizontal adjustments. If your convergence went out need to find convergence circuit and look on the plugs for your vcc voltages going to the convergence circuit. If missing, trace back to power supply and look for an open low value resistor.
Apr 20, 2011 | Sony KP-46V35 TV
The convergence is way off and will not adjust. Pulled and sent Sony the D board...new D board installed but did not fix the problem. Flash focus nor manual convergence will adjust. Have 3 images for...
Hi, thank you for visit fix ya.
Do you replace STKs ICs?.
If so, you need go to service menu tv.
With you tv off, press on your remote control:
display + 5 + vol+ + power.
You will go to service menu tv.
NOTE: Be Careful before you do this, because if you don't know step by step convergence adjustments.....YOU WILL MESSED UP YOU TV.
I recommended if you don't have electronics skill, take the tv near to tv shop.
Any question I will be here .
( I need model number tv, please)
Thank you
Jul 26, 2009 | Televison & Video
PT-53WX42F
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Jan 26, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Kp-57ws500 sony projection tv convergence problem
Sony convergence problems
Sony Convergence
look for the board that has heavy heat sinks on them the ic will be stk392-XXX
no experience in soldering i would send the board into ptscorp.com and have them repair it.
Jan 22, 2008 | Sony KP-41T65 41" Rear Projection...
Color is messed up
sounds like bad convergance ic
http://www.techlore.com/forum/thread/18970/Sony-KP-46WT500-Convergence-Repair/
Dec 14, 2007 | Sony KP-46WT500 46" Rear Projection...
SONY KP 413SU
Sony Convergence
Dec 06, 2007 | Sony KP-41T65 41" Rear Projection...
Sony KP-46WT510 Rear Video Projector Convergence Problem
Subject
Video bowed in, convergence out, PS5001
Symptoms / Customer Description
Video bowed in and convergence is out.
[Primary Symptom Code: 1436 ]
Solution
Found PS5001 on G board was open.
HQ Comments: Could be cold solder joint on one of the STK IC's on the D Board. They run hot and the solder connection might have broken down causing intermittent condition which could have opened the fuse on the
-22v line.
You can find the full repair manual Here!
Nov 18, 2007 | Sony KP-46WT510 46" Rear Projection HDTV
Auto convergence not working
If its the color won't align its the convergence board. First you could look for bad resistors and or capacitors
Sep 13, 2007 | Mitsubishi WD-52725 52". Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
