Question about Brother MFC 240C All-In-One InkJet Printer
Paper jam, and I don't see any piece of paper inside, but the priner show me an error, PAPER JAM all the time. the printer is a brother MFC-240c thanks
  • t20384cub Aug 08, 2008
    ok, but I don't see any piece of paper, How can I cleanthe rear roller?, I need to dismantled the rear roller form the printer?
    thanks so much
    TOMAS
I had the same problem.  I had removed all the visible paper and when it came back on made some awful noises and flashed "paper jam".
I even moved the roller forward and backward (after having uplugged the device.  I did this repeatedly and the "paper jam" alert continued (along with the awful noise).
As a last resort I thought I would just take it apart and hope to get it back together but figured it was a sensor or something along that line if I could not find any paper anywhere
with the machine unplugged (it would not shut down), I opened the lid I used a flashligt to look around trying to figure out how to take it apart.
It then dawned on me that I had not moved the print head over and using a screwdriver I gently pushed it to the center of the bar.  When I looked inside with a flashlight, there was the paper jam way inside under the cover.
I used some needlenose to reach in and took the paper out and it is now working fine.
I hope this helps, but you may have to search really deep into the device.
Posted on Dec 10, 2008
  • tomAzu Oct 22, 2010
    thanx for this,it was helpful
  • 3 Answers
Maybe the problem is because you reach the limit pages for this equipment.
You may reset this counter.
Reset the purge counter to zero with the following procedure.
(1) Press the Menu/Set and Black Start keys. Next press key four times to make the machine
enter the maintenance mode.
(2) Press the 8 and 0 keys in this order in the initial stage of the maintenance mode.
(3) Press the Black Start key several times until the purge count appears on the LCD
(4) Press the 2, 7, 8, and 3 keys in this order to reset the purge count to zero.
(5) Press the Stop/Exit key to return to the initial stage of the maintenance mode.
(6) Press the 9 key twice to exit from the maintenance mode.
Posted on Feb 05, 2009
  • 50 Answers
Clean the rear roller, and reset the printer. this will resolve the problem.
Posted on Aug 07, 2008
SOURCE:
Paper got jammed. Removed. Still says paper jam, but I can't see any. What should I do next?
Error says paper jam, but there is not. What could cause this ...
https://www.ifixit.com/.../Error+says+paper+jam,+but+there+is+not...
iFixitThere is no paper jammed anywhere! each time I would finish with the steps and ... I have to turn off and turn on the printer to get it going again. ... and the grinding sound and the paper jam message still comes up. i am going to try .... well no luck Iremoved ink and they are not dry - new- and now it says paper jam and not so ...
Fixing Brother Printer "Paper Jam" Error with No ... - YouTube
? 1:54
https://www.youtube.com/watch?v=SqWNFVIR6JA
May 30, 2014 - Uploaded by Refresh Cartridges
Fixing Brother Printer "Paper Jam" Error with No Paper Jammed.... problem occurred again. i try this many times but the problem is still in there. ... There was paper jam front rear on my brother j450dw that wasn't going away, that was ... How to remove jammed paper HP LaserJet Professional P1102 Printer ...
How to fix a printer paper jam. - Computer Hope
Dec 03, 2015 | Office Equipment & Supplies
Paper jam on screen will not reset
To clear the error message Paper Jam after you removed the jammed paper, open and close the scanner cover.
If you still receive the error message, a small piece of paper may be stuck inside your Brother machine.
Refer the below link for the steps to remove any ripped paper remaining inside your Brother machine:
still receive the error message Paper Jam after removed the jammed paper...
Apr 22, 2014 | Brother International Brother MFC-J4510DW
I have a Brother Printer HL-240D that gives me a constant paper jam inside indication even though the paper goes completely through the printer, and there is no actual paper jam. What switch causes the...
Have you tried shutting it down completely? Also, double check to see if the inside of the printer is completely clean. I had the paper jam indicator showing because there a small piece of paper stuck inside. Also, found a helpful manual for a similar printer, you can see it here - Brother HL-2240 manual
Sep 29, 2013 | Brother HL-2040 Laser Printer
Paper jam in front of the printer due to another user opening the paper bin while it was printing
Turn off the printer and open all access doors to take out the paper that is stuck inside; make sure to take it out in one piece. If after doing this it still shows a paper jam error, please let me know.
Sep 14, 2010 | Brother HL-2040 Laser Printer
Small piece of paper jammed in my brother 240C. Can't see if but I know it is there. how do I get it out?
  1. Turn the printer off and on to see if it can automatically clearsome or all of the jam. Many printers provide an error-code listing onthe front panel display for the area where the jam occurred. If yourprinter shows an error code, be sure and check the printer manual tosee if that identifies the area of the printer where the jam occurred.
  2. Step 2 Turn off the printer.
  3. Step 3 Remove any paper trays. Inspect them for wrinkled or damaged paper.
  4. Step 4 Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. Step 5 If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
  6. Step 6 266_a1.jpg Ifyou find a piece of jammed paper, remove it by holding it with bothhands and pulling firmly (see A). The goal is to keep the paper fromtearing. If several pieces are jammed together, try pulling out themiddle piece first to loosen the jam.
  7. Step 7 266_a2.jpg If the paper does tear, try rotating the roller gears manually to free the paper (see B). Don't force anything, though.
  8. Step 8 Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. Step 9 If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
Nov 26, 2009 | Brother Multi-Function Center MFC-240C...
Error: "paper jam", in brother dcp 8040, but not paper jam helpppppp?'
Hey try this
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Apr 24, 2009 | Brother DCP-8040 Copier
HP Photosmart 2610 - Paper Jam
I cleared the paper jam but i am still getting a paper jam message. I checked thoroughly and dont see any pieces of paper anywhere. I press ok and still get paper jam message. I turned the priner off and on serveral times and that did not work. Same message. I am feeling very frustrated. Its been a week today. Help!
Sep 16, 2008 | HP Photosmart 2610 All-In-One InkJet...
Paper jam
give this a shot
alternative :
Jul 08, 2008 | Brother Multi-Function Center MFC-665CW...
Brother MFC 240C All-In-One InkJet Printer Logo
266 people viewed this question
James Cagle
James Cagle
Jim Keysor
ctnozil
