Question about Sanyo Microwave Ovens
Sanyo-Microwave oven-start up
I do have sanyo 800W Combo microwave ove oven.
I am find the start up problem with ot.
When ever I start the oven first time it works fine; but on every second time (open the door for rolling/rotating), Oven Start switch doesnt work or Oven not get started.
Is this is due to heat or fume problem
  • animeshsingh Aug 09, 2008
    Swith is working fine(checked).
    Oven doesnt get started only after first run.
    i.e; when oven get heated or microve waves generated.
    I like to appriciate Thanks for the response.
  • Sanyo Master
  • 9,086 Answers
This is usually caused by either a bad door switch, a loose door switch mount, or misaligned door hinge.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
Posted on Aug 08, 2008
Model em-p672w. What caused it to stop working?
Sanyo EM-P672W Microwave Oven Repair Questions ...
www.fixya.com > Forum > Microwave Ovens > Sanyo
Recent Sanyo EM-P672W Microwave Oven questions, problems & answers. ... Mysanyo super shower microwave wave stopped working it shows on the display to press clock key but ... What would cause my Sanyo Microwave to not heat up?
Sanyo EM-P672W Microwave Oven Sanyo microwave fuse ...
Nov 19, 2015 | Sanyo Microwave Microwave Oven
Manual for sanyo microwave oven EM-S3553S
Here it is
http://eu.sanyo.com/AssetBrowser/Technical%20Database/Instruction%20Manuals/Microwave%20Ovens/EM-S3553.pdf
Mar 13, 2013 | Microwave Ovens
I need a user manual for a Sanyo super showerwave 800w microwave. Model no. EM-G204 There aren't any on manuals online. Thanks Luke.
You can just type "EM-" (without quotes) in the search box at the Sanyo (Panasonic) support site here.
Check a few of the first results to see if they're close enough to help you.
If not, contact them via that page for more help.
Aug 22, 2012 | Microwave Ovens
My Sanyo EM-D975 starts and then stops after 3 seconds with E01 on the display, i pressume this means error 1, can anyone help
I would first suggest that you check the door switches and switch holders. See this file.
If it is equipped with an inverter, that may be the trouble.
You can locate Sanyo owner's manuals, part distributors and authorized servicers here.
Good luck.
Jan 30, 2010 | Sanyo Microwave Microwave Oven
Our sanyo microwave 800w is not working.the light is on and it is turning also.but the food is not warming up.
PROBLEMS WITH 3 PARTS CAUSE "NO COOK" PROBLEMS--THE HV CAP ,,THE HV DIODE OR THE MAGNTRON--IF THIS MAKES A LOUD NOISE WHEN TRYING TO COOK-YOU HAVE ONE OR MORE OF THESE PARTS BAD,,SORRY ,USUALLY NOT COST EFFECTIVE--TUNICA
Oct 29, 2008 | Sanyo Microwave Ovens
Hi I'm John I have a microwave - grill model number EM-G2565S 800W the trouble is when switched on the electronic clock does not come on and no buttons work all that happens is when i open the door the...
Did any other electronic items fail recently?
If sounds like a problem on the control board, possibly due to a surge.
I would suggest you contact a Sanyo-authorized service agent. You can find one here.
Aug 03, 2008 | Sanyo Microwave Ovens
Microwave Ovens Logo
134 people viewed this question
Top Sanyo Microwave Ovens Experts
William Miller
William Miller
robert landry
Greg Cann
Greg Cann
Are you a Sanyo Microwave Oven Expert? Answer questions, earn points and help others
