Question about Hotpoint 23 in. BFI62 Built-in Dishwasher
Hotpoint BF162 no longer cleans properly
My diswasher no longer cleans properly. I have cleaned the filter at the bottom. I have dteatched and cleaned the spray Arms, I have used a dishwasher cleaner regularly. The tablet dispenser door no longer opens during the wash cycle so I put the tabet on the dishwasher floor. All to no avail
    Top Expert:
  • Hotpoint Master
  • 10,061 Answers
Check rinse pump
Posted on Apr 07, 2018
3 Suggested Answers
SOURCE:
  • 185 Answers
SOURCE: hotpoint bf162
after the 20 seconds does it restart
Posted on Mar 28, 2008
SOURCE: Hotpoint FWD70 - dispenser flap not opening. My
This has hapened to me twice. I am no expert so treat the following with caution. This is what has worked for me.
1/ I sugest you check the dispenser solenoid - it should be about 1.65K. If it is open circuit buy a new dispenser assy - about £29.00 - try http://www.hotpoint-spares.co.uk/dispenser-assembly-for-fdw70p-p-121945.html. This sorted my first failure.
2/ My second failure occured 18 months later. I removed and checked the solenoid as above. I found the resistance was OK so I put it all back together and it now works OK so I can only think that there was a bad connection at the dispenser which all the disconnection / reconnection sorted out (two connectors at dispenser).
3/ A word of warning - take especial care not to damage the seal aroud the dispenser - this seal is somewhat delicate.
4/ If all else fails, try an expert !
Posted on May 24, 2011
Hotpoint fdw85 does not drain
sounds like the pump is not working
Jun 11, 2017 | Dishwashers
Ctd80 hotpoint dryer panel flashing dryer not working
Filter at bottom of machine needs pulling out and cleaned on a regular basis. This is a common fault and the lights is telling you to clean the filter. It is a large filter that unclips at the bottom front of machine. Remove two small screws from the front of the filter located left and right and gently remove the front plate. Once removed you will see a metal filter clogged with clothing debris. Clean with cotton buds and a damp cloth till clean. replace all parts and you should have it working once again with a good heat source as well. Every 2-3 months is sufficient to keep it cleaned. Hope this helps.
Feb 27, 2014 | Hotpoint Dryers
I have a hotpoint wm54 and it is not rinsing or spinning properly, at the end of the cycle the clothes are dripping wet & soapy, however if i manually put on to rinse and spin it seems to work!
You need to check and clean the pump filter.
Remove rear panel od washer, locate and remove large black hose on bottom of drum, remove and clean filter inside the hose.
Nov 15, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Hi could anyone help me please..My Hotpoint WMA52 keeps flooding
It is not draining properly, or overfilling due faulty pressure switch.
Try cleaning the filter first.
Remove lower rear cover of washer.
Remove large black hose onto bottom of drum.
Remove and clean filter inside hose.
Remove hose onto pump, and check for obstruction here and in the pump.
Hope this helps.
Dec 07, 2009 | Hotpoint Aquarius WMA52 Front Load Washer
LG LDF8812 Diswasher - Self Cleaning Filter not cleaning itself
you should not have to use any type of screwdriver to remove filter. The rest of it , leave alone. Take both rotors out and run unit. Both rotors top and bottom should push water through at a good rate. If not, a blockage in water /motor line. I suspect the rotors simply need to be properly cleaned, If not rotating properly it will cause undesolved residue.
Mar 28, 2009 | LG LDF8812 Stainless Steel Built-in...
My BF162 dishwasher won't start
it might be flooded in the tray underneath due to a blockage, try loosening the bottom panel (3 screws) and emptying it of water and re setting. Clean out all the traps etc in the dishwaser to make sure nothing is blocked
Mar 15, 2009 | Hotpoint 23 in. BFI62 Built-in Dishwasher
Hotpoint BF162............. Water left, not draining
Open the bottom panel of the washer and see if it is full of water, if it is drain it away and clean all of the filters inside the washer and reset.
Mar 04, 2009 | Hotpoint 23 in. BFI62 Built-in Dishwasher
Hotpoint bf162 built-in dishwasher error codes
take out diswasher, tip it backwards and drain out water. make sure that salt resovoir is on tight and there are no leaks from the arms
Jan 11, 2009 | Hotpoint 23 in. BFI62 Built-in Dishwasher
Poor cleaning with Hotpoint NDA300Y 73BA dishwasher
be sure rinse aid dispenser is full ..also ck water level after fill should be almost to bottom of float
Nov 01, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint 23 in. BFI62 Built-in Dishwasher Logo
51 people viewed this question
Top Hotpoint Dishwashers Experts
Archie Ferrarini
Archie Ferrarini
Marvin
Marvin
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
