Pioneer SD-P4552 turns off immediately after turning on
Television turns off immediately after turning on. Tried unplugging, waiting a few minutes and replugging. This did not help. Any clues on fixing the problem, and where can I get a diagram of the parts locations inside the t.v.? Hello I have a Pioneer Rear Projection tv and it is stuck in standby the model number is SD-P5183-k. I found other similar tv's with the same problem and they state to check C258 video assy. What is that and where can I find it. Or could this tv just be trashed?
  • 1 more comment
  • Anonymous Aug 19, 2008
    I have the same problem. TV stuck in stand by mode. I hear a click when I push the stand by button and then another click as it shuts off.
  • mpesho Nov 21, 2008
    I have the same problem on a Pioneer SD-P5183-K. If you turn the unit on, the light goes green, you hear a click and it shuts back down right away. In order to do the same thing again, the main power switch (standby power) must be turned off and then back on. Any suggestions, this tv has been great up to this point? Hate to get rid of it.
  • Anonymous Nov 29, 2008
    I have the same problem. I had a friend check things out and it looks like the flyback transformer has went bad. About $120 online to buy another one. There are some other minor components in the circuit that have went bad as well. About $11 for those parts.
  • 927 Answers
Good Day, vash4056;
Don't dig a hole yet I'll will have to some more research.
Okay?? big IRISH.
Posted on Aug 07, 2008
Samsung HLN507W turns on for about one minute then shuts off, three blinking lights stay on in front. It is not the lamp, nor the blue lamp cover switch for sure. I unplug it and immediately turn it on. ...
Samsung HLN507W turns on for about one minute then shuts off, three blinking lights stay on in front. It is not the lamp, nor the blue lamp cover switch for sure. I unplug it and immediately turn it on. It always does the same thing: comes on for 1 minute, then powers down - there is no wait time in between unplugging and powering on. All fans seem to work and I cleaned the dust out of it. Help.
Nov 04, 2010 | Samsung HLN507 50" Rear Projection...
We have a Pioneer SD P5006 Television and it keeps turning off.
Ur hight voltage transformer it dead.
The Fly Back Transformer the black plastic square block with the red wire with the cap to ur CRT(tv tube) is dead.
Aug 25, 2009 | Televison & Video
Pioneer SDT50W1 rear projection TV clicks off when switched on.
Hey dudes...even i hav had the same problem that too with the same model specified here..Its a problem actually concerned with the power circuit boards of the tv. Its best to get it checked by an authorized technician. For me I had to replace a transistor on one of the boards. But after that my tv came up with a new problem....the colours appear like rainbows! Could nyone xplain y dis is happening?
Feb 06, 2009 | Pioneer SD-P50A5-K 50" Rear Projection...
Pioneer SD-P50A5-K 50 inI
Hi, I am just curious. What is going on wih the Television? Thanks, Mike
Nov 04, 2008 | Pioneer SD-P50A5-K 50" Rear Projection...
Pioneer SD-p5073-K Shuts off
it is the power supply board an know problem with pioneer. If you have any soldering experience you can remove the powersupply board and resolder the tracks and as many parts as you can. I had the same problem and not the power supply works great. You will soon have other problems like pic and sound going intermittant where you have to hit the tv to get it back on. more solder problems on video main board. best of luck
Aug 22, 2008 | Pioneer SD-P50A5-K 50" Rear Projection...
Picture on my rear projection TV
Your set will one day soon not come on at all. theres several capacitors on the PIP board if your set has PIP or the capacitors in the power supply. A good tech should know where to check as this set some say is hard to work on but i quess its like anything you work on for a bit gets easyer. Call an authorized repair center for pioneer. Good Luck
Aug 13, 2006 | Pioneer SD-P50A5-K 50" Rear Projection...
Televison & Video Logo
246 people viewed this question
Top Televison & Video Experts
Electro Med Services...
