Question about AudioBahn DUB Mag Audio DUB2502 Car Audio Amplifier
Audiobahn DUB Mag Audio 2502 Amplifier
Hi.
Ive had this amp for about 3 months.
which connects to my kenwood sub.
the other day, the red light on the amp came on (protection mode) and i have no idea why, or how to fix it.
I looked at it and the 12v cable was very loose, so i re-connected that and protection light is still on
PLEASE help!!!
  • 631 Answers
If the protection light is on, the amplifier likely has shorted output transistors. To eliminate other possible causes, read through the following page.
Amp in Protect Mode - Troubleshooting
Let me know if you have any other questions.
Posted on Aug 09, 2008
I just installed my 10 inch square pyle sub and its hooked up to the dub amplifier..the amplifier is in safe mode and the subs woint hit..what do i do to fix this?
ok if the amp was in safe mode before the sub was hooked up then the amp needs to be fix , make shor the suds are hooked up right an the wires arent touching , the amp is in pro mode so there for u have to find out more on why the amp is not working or let me know what is goin on with it ,
Jul 19, 2011 | AudioBahn DUB Mag Audio DUB2502 Car Audio...
I have a dub audio 2502 amp, do i use 4 or 8 gauge wiring ?
Despite the fact that they claim that the amplifier is 500 watt RMS if you look at the fuse it has on it, which should be one 30Amp fuse it means that the max that you might get out of this amplifier is 300 watt RMS. So an 8 Gauge cable will be more than enough for it. However, saying that, using a 4 gauge cable will not harm it in any way. what you should check before buying a 4 gauge cable is if it will actually fit in the allocated 12V terminal. Respectfully dreamsystems
Feb 03, 2011 | AudioBahn DUB Mag Audio DUB2502 Car Audio...
I have a dub2502 amp with the red protection light on and will not go off. The amp is a 1100 watt peak amp @ 4 ohms and my sub is an Audiobahn 1100 watt peak, 4 ohm. wired perfectly. so how do I fix the...
The unit will need to be repaired by a technician. Most likely you have a bad transistor that is causing the protect mode to turn on. The only way to get the protect mode to turn off is to remove the bad part.
May 04, 2010 | AudioBahn DUB Mag Audio DUB2502 Car Audio...
Amplifier Problem
never ask geeksquad about amps lol check your ground wire connection and push on sub do you feel scratching if so its blown sub also never turn an amp up all the way it starts pushin dc voltage witch a 200 watt amp can blow a 800 watt sub dc voltage is not good for subs also up all the way can burn out the internal battery in the amp lets hope thats not it just make sure ground is good protection light means that the amp has power but a connection is not bien made sum where to complete the circut
Apr 12, 2009 | AudioBahn DUB Mag Audio DUB1002 Car Audio...
Dub 2502 not in protect mode but not putting out
i dnt knowwat type of speaks u got but ifits low then it cud be tht u have too open up the second coil on ur speakers...dnt sound like the amp since its on & not in protect mode,other than tht i'll recheck the wiring
Apr 07, 2009 | AudioBahn DUB Mag Audio DUB2502 Car Audio...
DUB 2502 Protection Mode help
The most common reason for an amp to go into or remain in protect mode is shorted output transistors. To eliminate other possible causes, read through the following page. Let me know if you have any other questions.
Aug 07, 2008 | AudioBahn DUB Mag Audio DUB2502 Car Audio...
DUB 2502 550WATT
check you rca in put into the am with out spkr wire connect to amp if protection light still on amp is damage
May 25, 2008 | AudioBahn DUB Mag Audio DUB2502 Car Audio...
Problem with my amp
the proble could be that the negative cable is not touching ground, or that the remote is not tide enough.
Mar 13, 2008 | AudioBahn DUB Mag Audio DUB2502 Car Audio...
I have a dub 4001 amp
Take it step wise.
Unplug the inputs and outputs from the amp (be sure to mark the wires so you can hook them back up), leaving only the ground, +12, and remote wire hooked up. Now, turn it on. If the amp light goes red, the amp is broken. If it goes green, turn if off, plug in the speakers, then turn it on. if it's red, its a speaker problem, if green, do the same with the inputs, and you'll have your answer.
Jan 22, 2008 | AudioBahn DUB Mag Audio DUB4001 Car Audio...
No Sound coming out of amp to subwoofer
check the fuse box and make sure there is no loose connection there. also check the wire that feeds power to that amp. good luck
May 23, 2007 | AudioBahn DUB Mag Audio DUB1002 Car Audio...
Car Audio & Video Logo
534 people viewed this question
Top AudioBahn Car Audio & Video Experts
Professor_V
Professor_V
matthew walsh
Level 1 Expert
Iron
Iron
Are you an AudioBahn Car Audio and Video Expert? Answer questions, earn points and help others
