Dryers Logo
MARY QUINTERO Posted on Apr 11, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
MY LG TROMM GAS DRYER DLG7188RM WILL NOT DRY MY CLOTHES AND WHILE DRYING THE COOLING LIGHT STAYS ON.
Anonymous
Level 3:
  • LG Master 1,902 Answers
  • Posted on Apr 11, 2011
Anonymous
LG Master
Level 3:
Answers
1902
Questions
0
Helped
533800
Points
5669
Hello & Welcome to FixYa
If you have already tried cleaning the vent then the problem is with the Thermal fuse. When the thermal fuse goes bad it cannot be reset and replacing it is recommended repair.It is located on the blower wheel housing inside the rear panel to the exhaust duct. You can test the fuse for continuity before replacing, if the fuse is fine then please get back to me if you have any other questions.
Kevin
My dryer Lg Tromm model number DLG5988 is blowing cold air, changed sensor bars still not drying- also the check filter light stays on and it's in cool mode and dry keeps blinking, what could it be?
sensor bars just measure humidity so dryer knows when close are dry, so will have no effect on heating. the check filter light is just a reminder, not connecter to any sensor or anything. could be several issues: gas valve solenoids, thermal fuses, etc. but for a quick try that might work, try just unplugging the dryer, push and hold the on button for about 20 seconds and then plug back in and see if the dryer is reset. works sometimes. good luck
Aug 24, 2015 • LG Dryers
37helpful
My lg tromm DLG69885 gas dryer is not heating; otherwise it works fine. Dry light flashes cooling light stays on solid
I am using LG Tromm DLE2514 washer dryer. It 's running but didn't dried the clothes. I clean it's lint but still it's not working. The one thing i notice now is it's drying light is blinking and cooling light is turn on all the time during the cycle. So what's the problem with my dryer?
2answers
Not enough heat
You may need to adjust the air flow on your dryer vent.
When an LG dryer is functioning normally---the time required to dry laundry is determined by the *Sensor* located on the drum side of the lint filter housing and by the main control board.
When laundry is near dry--any Time Remaining on the control panel that is *not* needed will be eliminated---except for the last 6 minutes.
The final 6 minutes of any LG automatic cycle is for cooling down the laundry before the dryer ends the cycle.
If a dryer *counts down* to the last 6 minutes but the laundry is still not dry--the computer will allow the dryer to run until the laundry has dried or defaults (not drying within the additional time allowed).
Dryer vents that are longer than 8 feet with more than (2) 90 degree turns--can affect drying performance.
Setting the DRY LEVEL selector to *Very Dry* will solve most dryability issues. In homes with abnormally long vents--even the longer run time in the *Very Dry* setting is usually not sufficient to dry laundry loads.
Reducing the length of the vent or starting a second cycle becomes necessary to fully dry the clothing.
If a second cycle was started---only the amount of time that is needed to dry laundry will be used before dropping to 6 minutes and then the cycle will end with dry laundry.
LG gas dryers are more sensitive to venting length and air flow resistance. The gas burner can cause a rapid increase in temperature compared to an electric burner.
Rapid temperature rise in a gas dryer leads to premature burner shutdown (longer time required to dry laundry).
The gradual temperature increase of an electric element is more "forgiving" in homes where the dryer venting is less than ideal.
Problem:
The dryer has an auto dry feature which never fully dries the clothes so we wind up manually setting the dry time to an hour
Solution:
LG gas dryers are VERY temperamental in long vent set-ups. If fabric softener sheets are used in the dryer--clean the two stainless steel strips of metal on the lint filter housing with a SCOTCHBRITE PAD--scrub back & forth several times to remove the waxy residue from the fabric softener sheets. Most,if not all manufacturers do *not* recommend using sheets in dryers that have a moisture sensor (electrodes).
However--using a SCOTCHBRITE pad keeps the wax off those sensors which can be seen if looking *into* the dryer drum and at the lint filter housing.
If only *liquid* fabric softener is used in the washer--clean the dryer sensors once a month. Liquid softener also contains wax which can slowly accumulate on the dryer sensors from the laundry washed in the washer.
LG DRYER SERVICE MANUAL
LG PARTS
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
7helpful
The cooling light is always on, and it takes about 90 minutes to dry a load.
In normal operation as the dryer is drying the "drying" light flashes and the "cooling" light is on steady until the 5 minute cooldown at which time the "drying" light stays on steady and the "cooling" light flashes. click on this lg link
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6253
1helpful
LG TROMM Front Load Dryer / Not drying clothes
check the vent or condensor depending on what type of dryer.
Sep 28, 2009 • Dryers
1helpful
Not drying completely
try cleaning real good. also the heating unit might be bad
4helpful
Lg tromm front load dryer dlg5988w
dryer has two fuses check both circuit breakers one is for heating the other is for the plug this fixed my front load lg this gives you the heat that you need to dry your clothes
Top LG Dryers Experts
Paul Carew
Grand Canyon Tech
Grand Canyon Tech
Are you a LG Dryer Expert? Answer questions, earn points and help others
