Fuel pump going out. Once it gets warm after 15 mins the o rings loosen up and cause it to loose prime and shut off. After cooling for 15 mins they have shrunk enough to build pressure again.
try replacing batteries in remote nad try it again if that does not work you may have to disconnect the battery for about 15 mins to a half hour should resolve problem most probably security problem this should correct it.
the wooshing maybe the oil/freon migrating thru out the internal system...
The cycle depends on 2 things... t'stat operation and timer. The timer usually shuts off freezer every 6 or 8 hrs for 20 to 30 mins. But the t'stat (once it reaches desired temp. should shut off freezer every 15- 20 mins. for an average 10 -15. So 15 mins off min 15 mins on (that is if the doors is not open) you get my point something like that...
but the way you describe to me it sounds like the t'stat. set it at 1 if it dont shut off and you are absoultely sure you got zero degrees (use a temp. reader) then replace the t'stat
hope this was helpful
let me know if this didnt work then plan B
I found that I had that problem too with my Motorola RAZR. Because I was charging it every time I wasn't using it, it was affecting the battery. They suggested 1) that I charge it ONLY when it says LOW BATTERY 2) Shut OFF the phone ONCE a week for about 10 - 15 mins. But doing that, it resolved my issue. Hope this helps for you.
it is happennce because of bad batterys. please chnge it and enjoy more time with your mp3 player.(the battery capasity rduse by itself MAH.)
want more help.
nuwan
hold down the reset button for about 1 min then leave it for about 30 seconds. once you have done that try turning it on, if it does not turn on and it is completely dead leave it pluged in to your computer by using the usb cable, leave for about 30 mins it then might start to charge, if it does start to charge leave it till it is fully charged and then it should turn on. if none of that works then i don't know.
