Question about Honeywell HFS641P Stand (Pedestal) Fan
Honeywell HFS641P won't stay on.
We've had this fan for a while now, and all of a sudden, when we turn it on, it turns off about 10 - 15 seconds later. The breeze setting works, but I would rather have it on a steady flow. Any ideas, or do I just need a new fan?
5 Suggested Answers
SOURCE: No water running through the pad
I has same problem and was able to fix ti by taking off the selonoid (cylinder) and then removing both fittings (where the water line enters and then exits the selonoid. The fitting where the water enters has a small pinhole that I found clogged and just cleaned it with a toothpick. After cleaning and reattaching everything, it works fine.
If that doesn't work, you might need a new selonoid which are around $70-$80.
Posted on Dec 08, 2007
boanhtgclg
  • 34 Answers
SOURCE: Auto fan does not turn my furnace fan on-I have to use manual on
with the fan in the auto position, the fan only comes on during a demand for heat.  does it not come on during a demand for heat?
Posted on Nov 24, 2008
  • 25 Answers
SOURCE: is it possible to order a remote for hfs641p
yes....
Posted on Apr 16, 2009
  • 334 Answers
SOURCE: Honeywell digital thermostat stopped working
Sounds to me like you have a low voltage short. If the stat had no display until you installed the battery means there was no voltage for the stat to work. Putting the battery in proves the stat works, no motors turning on probably leads to a blown low voltage fuse generally a blade fuse on circuit board in indoor unit. Good Luck
Posted on Jun 11, 2009
  • 415 Answers
SOURCE: honeywell chronotherm iv fan keeps running even
Assuming you have the fan switch of your thermostat in AUTO, it sounds like a stuck Fan Relay. If the fan relay is stuck, your fan will continue to run as long as there is line voltage being fed to your unit. This relay could be an independent component or it could be an integral part of your control board. Have an experienced, qualified service technician check it out.
Posted on Mar 19, 2010
Winterizing a Johnson 115 HP outboard motor
Could not understand you problem. Please elaborate.
Oct 19, 2013 | Honeywell HFS641P Stand (Pedestal) Fan
Purchased a new stand fan but after few days started giving trouble by not running after stop. Few days used to open the covers fix up the blades and then restart. now it is not running at all. what to do?
The motor has gone bad... the best thing to do is to take it back and get another one... often if a motor is bad it will fail very quickly like that...
Heatman101
Aug 28, 2010 | Honeywell HFS641P Stand (Pedestal) Fan
Fan not working
Hi, I know you would know this, but I have to say this anyway. Make sure there is power to fan,...ok, I said it,LOL. Honeywell have top of the line products as I use controls by Honeywell through out my H.V.A.C.-R business. Does it try to start at all? If it does have some movement, or you can hear any sound at all at the enclosed motor on this fan, the motor is on its way out, or has already failed. It is possible the switch its self is at fault, but if it trys to do anything at all then power is getting through this control to the motor. Put you're hand on back of motor when turning it on and should be able to feel it being energized. It does sound as though you have a bad or open winding on this motor. It would be fair to say that the expense of changing out this motor, or even if the switch was faulty, it would be cheaper for you to replace this unit. If you want to keep it, and are inclined to take an electrical meter and check the switch, I can tell you what to do? Kill power to fan. See how switch is installed, should have 3-speeds. You would more then likely have to dissasemble the entire unit to get to the wiring on the fan switch. If you can do this, the power coming into the switch you will know by following the cord wires to switch. Black and white wires and maybe a ground. With a meter, check on each wire coming in from cord right where they 1st connect to switch, across the blk and wht. You will have 120 volts. There will be several colored wires as it is a 3- speed switch.Find one of the wires that go directly to the motor, except ground.With the switch on, touch any one of the wires that go to motor and touch the other lead to the ground wire. If the switch is good, you will have 120 volts going through one of the motor wires and ground. This will tell you the motor is bad. Be careful if you do make this test, as you can get shocked if you ground yourself out.I don't want to scare you, just use caution. Please keep me posted on what you have found.
Sincerely,
Shastalaker7
PS, I am positive the motor has failed you:(
Dec 17, 2009 | Honeywell HFS641P Stand (Pedestal) Fan
My Lasko Pedestal fan just stopped working completely
Its probably something simple, plug it into another outlet and make sure that outlet work also, if that dont work it will be in the control switch and i doubt the motor is burnt up. You can take srew driver and open up the control cover to see if there a fuse and check the wiring connection from the outlet to the control switch and make sure the fan is unplug before you open up the cover. Jiggle the wire inside the control unit than press and play with the button couple of time and plug it back into the outlet and see that will work. if not than have somone test the the motor with a volt meter making sure the motor still good. I believe it be more likely in the control swith unit. hope that work for ya
Jul 10, 2009 | Honeywell HFS641P Stand (Pedestal) Fan
Wall switch
I had this same problem (sort of) - my daughter lost the remote to our fan and it would not work from the wall switch. What you have to do is go up to where your fan is connected to the ceiling, slide the canopy down, and remove the remote transmitter. Then just rewire the fan normally - white to white, black and blue to black, and the ground wires together. Turn on the power and your fan light should work with the wall switch. You will have to pull the cord for the fan to work.
Jan 07, 2008 | Honeywell HFS641P Stand (Pedestal) Fan
Hi i am working as an electrical installer and would like to know where i can access all the electrical drawings for all the different heating systems Honeywell
http://www51.honeywell.com/aero/Products-Services/Avionics-Electronics/Egpws-Home3/InstallationInformation3/digs-draw-sw.html?c=21
try this.. all honewell drawings.. in it
Nov 13, 2007 | Honeywell HFS641P Stand (Pedestal) Fan
Medium setting no longer functions
Check the connections on the switch or test the switch with a multimeter.
Aug 10, 2006 | Honeywell HFS641P Stand (Pedestal) Fan
Honeywell HFS641P Stand (Pedestal) Fan Logo
Top Honeywell Dryers Experts
Jay Finke
Jay Finke
Iron
Iron
Are you a Honeywell Dryer Expert? Answer questions, earn points and help others
