Question about Microwave Ovens
GE Profile Microwave Model #PEB2060SM1SS Manufacture date is August 2007. Installed into our new home, that we moved into Feb 2008. The Glass plate will not turn very well and the glass plate has a crack in the center that keeps getting bigger and bigger. Inside the glass. The Microwave is also extremely Loud! It is a built in microwave. What is the problem, we can not get anywhere with the warranty provider.
  • William Miller
    William Miller May 11, 2010
    You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
    If yours
    is not set to be off via the control panel, and it won't rotate or it
    sounds like it's grinding, etc., you may have a bad motor or plastic
    coupler.
    To replace either, you need to unplug power, then remove the bottom cover of the oven.
    You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
    There should
    also be a "mini-manual" hidden inside the unit behind the control panel
    or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
    The turntable is probably cracked because it's not been turning.
    I always recommend that folks put food off-center on the turntable to assure more even heating.
    Also,when you put your food off-center, you're not putting it in the same spot every time.
    That will help prevent repeated heating of the the same spot on the glass, which can lead to weakness and cracking.
    The loud noise is another issue... what does it sound like and where does it sound like it's coming from?
    It may be a loud hood fan blower or a problem in the high voltage section.
SOURCE: GE Spacemaker - microwave works but the inside plate doesn't spin
you have a bad turntable motor or a bad control board.. start with the motor 9 time out of 10 this is your problem.. you can pick up this part at your local parts house or order online.. look for universal part. this will be alot cheaper then the oem.. just take the screws out of bottom panel under microwave. panel will drop down. you will see little round motor about 2in' make sure unit is unplugged.
Posted on May 09, 2008
tiway1
  • 100 Answers
SOURCE: Maytag Microwave Glass Plate that rotates
check with www.microwaveglasstrays.com
Posted on Jun 30, 2008
  • 63 Answers
SOURCE: Need to replace Panasonic NE8070 model, 15in dia,microwave plate
hi my name is mark, i found panasonics part website follow link http://www.pstc.panasonic.com/Epartr/PartsListChoice.asp?validate=1 if this helps please rate how i did. thanks for you question.
Posted on Mar 19, 2009
MicrowaveSvc
  • 9098 Answers
SOURCE: I need to replace my glass plate inside of the
For assistance with your Sunbeam® Microwave, please call 1-866-257-3336.
Posted on Jun 04, 2009
MNfisherman
  • 11896 Answers
SOURCE: hotpoint Over the Range Microwave is LOUD
It is very likely that the motor that spins the plate is wearing out. You can find a replacement on ebay and many other sites.
Posted on Jun 06, 2009
The glass turntable broke. Where can I find a replacement?
Go to www.ebay.com Type: make and model of microwave, and refine search to glass plate.
Apr 02, 2012 | GE Spacemaker JVM1540 Microwave Oven
My ge profile advantium microwave and convection oven started heating by it self. we were home and smelled smoke. it had melted the food cover to the glass turntable plate. We unplugged it and later...
That I can't answer! But I would replace your microwave/convection oven, it is completely unsafe and a major fire hazard, and I would get in touch with GE and lodge a formal complaint about their product, if there is a flaw in the design it needs to be brought to the table to warn others that have same item so they are not affected in the same way.
Feb 19, 2011 | GE Advantium 120 Convection/Microwave Oven
Panel periodically acting up - says there is a short in the panel
Hello there:
what this is trying to tell you is that your control panel is starting to go out due to a failure in the controle assembly
yes it is feasable to replacethe panel youwill just have to contact the manufacture of the microwave and get a replacement panel/ controle board ok
I hope that this is very helpful for you
Best regards Michael
Nov 21, 2009 | GE Profile Spacemaker Over-the-Range...
The spinning plate in my Microwave broke.
Hi there! Universal Glass plates are available from a good local appliance spares shop. Please note that size of the plate, the coupler (The centre connection point to the plate) and the ring size (on which the plate rests) are all important to the correct function of the plate. Take these along for correct matching if you can or they may even keep your particular Model and Brand. Best Wishes and Good Luck, JUS004
Aug 30, 2009 | GE Microwave Ovens
Everything works except heat
this is something you should probably call a repair technician for, due to the danger of the componentry.
Usually in ther case of this problem, even a technician will advise you to replace the unit, in the minds of cost effectiveness and safety...
Mar 21, 2009 | GE JE1540 Microwave Oven
GE Profile Microwave will not heat
Unfortunately, there is no way to tell which part the microwave needs without opening it up for examination. There are a few parts that, if defective, would prevent the oven from heating.
  • a high voltage transformer which passes energy to the magnetron
  • a magnetron which converts high-voltage electric energy to microwave radiation
  • a magnetron control circuit (usually with a microcontroller)
This is NOT a repair that you would want to attempt yourself. The labor for the repair would cost a minimum of $50 and shouldn't exceed $100. You'll also have to pay for the necessary part if it's still available from the manufacture or their parts distributor.
Feb 03, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave not working, please suggest
Your magnetron tube has failed. According to the warranty on the Profile Series microwave ovens, the magnetron is covered for 5 years from the date of purchase, but labor is not included. I would call GE Customer Service and when they ask for the model number (which begins with JVM) and the serial number, be sure to give the date of purchase as the date you closed on your house. If they insist upon charging you for a service call and labor, I would call my builder's Customer Service Department and demand (very nicely) that they intervene with GE to waive the service and labor charges. That worked for me (Lennar Homes).
Jun 15, 2008 | GE XL1800 1100 Watts Microwave Oven
Microwave Ovens Logo
1,376 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
