when
you said it suddenly died, do you means after putting in new
batteries,it did not turn on at all? If yes, below are some reasons for
this problem;
Check the batter seat. I mean the position where
the battery stays, look if you will find any rust of the battery
terminal (metal). Rust can prevent the battery from contacting the unit,
preventing it from receiving power. Get a flat screw driver, scratch
the rust off, fix the battery back in and try again.
If there is
no rust, then there is probably some disconnection inside the unit. This
can be between the battery terminal and the board. Get a screw driver
and remove all the screw. Take the unit apart and check for any lose
contact between the battery terminal and the board.
I hope the above makes sense to you.......
Regards.
