Question about Canon PIXMA™ MP810 All-In-One InkJet Printer
Mp 810 just changed the ink and now will not print.   item will line up as in print que and shows as in progress and nothing prints.  I have reset computer and reset printer and still no avail.
  • andrealane Aug 11, 2008
    Thanks,  It is now printing unfortunately it was an old print order.  I go to see what is in the que and it has start jobs and hold at the same time - cant seem to get it to restart from being on hold automaticly.
  • 659 Answers
Gonna need to do a nozzle check pattern printout should do that about 3x and should work
if not.
The printhead nozzles may be clogged.
The printhead may need to be replaced
so might have to do a print head cleaning as well. ushally found on the matinence menu on your unit.
Posted on Aug 07, 2008
Changing the print size on a Canon MP 810
Using Gimp , I imagine you are using Linux not Windows. Download the latest driver from the Canon website and make sure its the correct one for Linux. I am not aware of any settings within the 810 that can be changed as print size is governed by the driver and not the printer. Make sure you UNINSTALL the old driver and don't just DELETE it .Good luck
Sep 05, 2016 | Canon PIXMA MP810 All-In-One InkJet...
Print que on hp 4300 says "printing" but nothing happens and I cannot clear que
This is a common problem with Windows machines. If a print job gets corrupted in the print que it will stop and block all other jobs from printing. It will also block the job from being deleted normally. You have to stop the print que service and then delete the print jobs from the que. Here is a link to a full article that shows how to stop the que, delete the print jobs and restart the que to restore printing.
http://www.ccl-la.com/blog/index.php/how-to-delete-print-jobs-that-are-stuck-in-your-print-queue/
Nov 29, 2012 | HP LaserJet 4300 Printer
Error code 16
Hi there .the error e1.6 on Canon Multifuntionals ( MP, MG , MX ) is :
DESCRIPTION:
Ink has run out.
SOLUTION:
Replace the ink cartridge and close the Scanning Unit (Printer Cover).
If printing is in progress and you want to continue printing, press the Stop/Reset button for at least 5 seconds with the ink cartridge installed.
Then printing can continue under the ink out condition.
The function for detecting the remaining ink level will be disabled.
Replace the empty ink cartridge immediately after the printing.
The resulting print quality is not satisfactory, if printing is continued under the ink out condition.
I hope this information will help you
Dec 22, 2011 | Canon Office Equipment & Supplies
Printer will not print the ink packages are new but the indicator on print que shows (?) on both black and color indicators. the que shows printer 1 to 3 % progress then stops. thank you for your help
It could be that the print spooler service on your computer has stopped. - Browse to Start -> Run... and type in "NET STOP SPOOLER" (this will stop the print spooler service)
- type in "NET START SPOOLER" (this will restart the print spooler service)
Try to print again.
May 23, 2011 | Lexmark X4650 InkJet Printer
My TX 100 will not print. I have replaced black cartridge thinking it would change things but no. The green button shows and the red one shows (the red one shouldn't) and when I press 'print' it...
Epson ink cartridges have memory chips. If you refill a cartridge it will still show as empty until the memory chip has been reset. The printer will not normally print if it thinks the ink is empty. This is to protect the printer as the ink is energized as it is used.
Refill ink sellers on line usually have the Chip Reset tool available to buy (SK168-II).
Apr 14, 2011 | Epson Stylus Multifunction Inkjet Printer/...
Printer will not print. Ink is fine, paper loaded,press print,....nothing happens. What can I do? I have had the HP Check what they could. All was OK except the items I tried to print were in what they...
Click Start
Click Control Panel
Click Printers
Double-click the icon for your HP printer, to view the "queue" of files to be printed.l
Right-mouse click the icon for your HP printer, and click "use online" (if "offline" currently is "checked").
Dec 20, 2010 | HP Office Equipment & Supplies
I have a canon MP 130 printer that is not printing. I have put in new ink cartridges, replaced Print Head, and reset the waste ink absorber counter. None of this worked. The printer does not print at all....
That printer has no parts or repair, during warranty Canon would only replace the entire printer. After the warranty runs out, you just buy a new printer. It sounds like the purge or cleaning unit is not working, but no parts are available to fix this model.
Feb 18, 2010 | Office Equipment & Supplies
Blinking teardrop light blinking
Blinking drop light on HP6122 signifies an ink cartridge is out of ink. There are two cartridges -- color (larger of two) and black (smaller of two). Blinking drop light only indicates either, but not which. HP6122 service software and print driver are available from HP website http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=83027&lc=en&cc=us&dlc=en&lang=en&cc=us. HP6122 service software has a printer maintenance utility which includes ink cartridge monitor. Use the maitenance service utility to determine which (or both) cartridge is out of ink. With cartridge replacement, printer should automatically print test page, then reset and be ready for printing from your computer. To clear printed documents from print que, open the HP6122 print que via control panel > printers > double-click on HP6122 driver to show que > select document tab > select cancel.
Mar 26, 2009 | HP DeskJet 6122 InkJet Printer
Sanning problems for multi function printer PIXMA MP 160
Just hold the stop and reset button until the warning goes away. Works like a charm
Feb 13, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Sanning problems for printer PIXMA MP 160
some printers can detect that the cartridges are refilled based ona barcode or scanning of the cartridges. Does this Cannon have ink tanks or ink cartridges. If it has intakes then the print head needs to be cleaned wth rubbing alcohol and a q-tip. If they are cartridges then it would be good just to buy the original cartidges. As far as the scanning goes this can be a direct connection to the printer going through maintenance. If it continues to not scan then you may need to uninstall the scanner. see if the scanner shows up in your scanners area. if not then it will need to be re-installed.
Feb 13, 2008 | Computers & Internet
Canon PIXMA™ MP810 All-In-One InkJet Printer Logo
98 people viewed this question
old marine
old marine
