Question about Sharp CS-2850 Calculator
Keeps rounding up or down, i don't want it to round at all
Can you help my son on his rounding numbers
Yes, you can post any question here. Ignore any grumpy unhelpful replies. Best to post in this Forum
http://www.fixya.com/troubleshoot/browse/homework
Alternatively have a read of these sites
http://www.factmonster.com/math/numbers/rounding.html
https://www.mathsisfun.com/rounding-numbers.html
Feb 28, 2017 | HIS Computers & Internet
How to round to the nearest ten dollars?
example....11,12,13,14,15 round down to 10 16,17,18,19 round up to twenty. In the middle anything over 15 (like 15.25) rounds up to 20. Anything under 15 (like 14.75) rounds down to 10.
Sep 22, 2014 | Office Equipment & Supplies
Gas cap stuck
If the gas cap just spins round and round . PUSH IN WHERE THE KEY GOES AND AT THE SAME TIME TURN CAP , IT WILL COME OFF.
Jan 27, 2014 | 1999 Lincoln Navigator
Rules for rounding numbers
If the rightmost digit o be changed (rounded) is 1,2,3,4 replace it by 0 (round down). If it is 6,7,8, or 9 increase by 1 the penultimate digit (round up).
What to do if the last digit is 5? Most people round up. Some purists recommend to round up and down alternatively.
Nov 26, 2013 | Computers & Internet
How to round numbers up or down on ti-84 plus silver edition
The calculator is programmed to round up oe down as the case may be. Just select the number of decimal digits you want to keep and the calculator will perform the necessary rounding.
Open the MODE screen. On the line that says FLOAT select the number of digits. you want to keep.
Dec 12, 2012 | Texas Instruments TI-84 Plus Silver...
Script era on xbox game
Basically the server thinks you are cheating. If you stop laying down claymores and try not using them every round. Or using a bunch of ballistic knives and not picking them up! I'm guessing you're doing the claymore stock up trick. Don't do it!!! I use to do that too, just in case I ran out of ammo, I've got an enormous amount of claymores to use later on. But every time I'd hit round 25-27, me and my teammates would get kicked. The servers think that you're glitching or cheating and boots everyone from the game. Don't do it, and you should be fine. I'm guessing there was a patch to stop players from exploiting the loop hole.
Jun 01, 2012 | Microsoft Xbox Console
Keeps comming up service or script era
Basically the server thinks you are cheating. Stop laying down claymores and try not using them every round. Or using a bunch of ballistic knives and not picking them up! I'm guessing you're doing the claymore stock up trick. Don't do it!!! I use to do that too, just in case I ran out of ammo, I've got an enormous amount of claymores to use later on. But every time I'd hit round 25-27, me and my teammates would get kicked. The servers think that you're glitching or cheating and boots everyone from the game. Don't do it, and you should be fine. I'm guessing there was a patch to stop players from exploiting the loop hole.
Good Luck!
Jun 01, 2012 | Microsoft Xbox 360 Console
I need help fixing a rounded shaft on a gearcase for a washing machine. The coupler, which has two flat portions will not catch properly on the shaft which has rounded. Replacing the entire gearcase is...
I am not a big believer in cobbling, but they always brag up JB Weld to be able to repair anything metal. It may be worth a try, build it up and file it down so the coupler will fit on. The other option would be a MIG welder and keep spot welding till it is built up. Extreme caution would have to be taken so you don't get the shaft too hot and ruin the seal.
Dec 28, 2011 | Kenmore Washing Machines
How to round up decimal to 2 decimal
I don't think the calculator has that function, but what you can do is round on your own. If the decimal .005 or greater, you'd round it up to .01. Simple as that!
Hope this helped.
Jun 18, 2011 | Casio MS-80TV Scientific Calculator
I must of hit a button, now my calculator rounds all my numbers how do i fix that?
There should be a switch that has 5/4 on it. This is the rounding switch. Place it in the Up position to round all numbers up, 5/4 to round down when the next digit is less than 5 and round up when 5 or greater, and the down position to always round down.
Feb 26, 2010 | Basix BX-PC102 Calculator
Sharp CS-2850 Calculator Logo
123 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
