Question about Peg Perego Toys
We have a Peg Perego John Deere Buck 4-wheeler that will no go. I thought maybe the battery was bad so I replaced it with a fully charged new one and it moved about 300 feet and then wouldn't do anything when the pedal was pushed. When I plugged the battery back into charger, the light quickly went to green indicating a full charge. I checked for any loose connections but everything looks ok. What now???? Please help. Thanks!
    Genius:
  • Peg Perego Master
  • 1,508 Answers
Try jumpering the battery directly to the motors to see if the motors spin, if they don't then replace the motors as needed, if they do spin, then use a multimeter and check for 12 volts at the motor wires when the accelerator is pressed, if its showing no volts then work your way back to the shifter switch and check for volts, then to the foot pedal to find where the power isn't getting through then replace components as needed
Posted on Aug 17, 2017
4 Suggested Answers
  • 9 Answers
SOURCE: 4 wheeler by peg perego
its most likely bad. put the leads from a test light on the terminals of the motor and press the pedal. If the light DOES turn on, you have a bad motor, or at least bad brushes in the motor. Most likely, the light will not come on, and you should check all the wiring for loose connections or faults going from motor to the pedal switch, and from battery to switch. The switch should be a momentary contact switch, and cheap universal replacements can be found at hardware stores, auto parts stores(NAPA is your best bet), and radio shack. Bring the switch with you to the store! Also, use the test light on the wiring coming off the switch going to the motor right at the switch. If the light comes on, and the switch is good, that'll tell you that the wiring from the switch to the motor is faulty somewhere.
Posted on Oct 29, 2008
jackiaria
  • 350 Answers
SOURCE: Peg Perego Polaris 4 wheeler, won't move
May need battery or is just rusted!
I'd buy a can or two of WD 40 or similiar lubricant and spray it all over all the rusted metal I can get to then turn the wheels by hand as much as possible but that's just me!
Good Luck!
Posted on Jan 20, 2009
  • 670 Answers
SOURCE: We bought a Peg Perego john deere hpx. where can
You could try here. http://tigerimports.net/sunshop/
Posted on Dec 24, 2009
Battery is full on my sons peg perego john deere but it wont run
did you verify the battery voltage with a multimeter, could have a bad charger that gives a green light making one think that the battery is fully charged, also check the fuse on the battery
Dec 14, 2015 | Peg Perego John Deere Turf Tractor
Peg perego john deere tractor charger indicator light does not light up and tractor does not take a charge - brand new
first of all check for at least 12 volts from the battery and the charger, you can test this using a multimeter, if the battery doesn't show
any volts, lift up one side of the blue plastic housing on the top and verify that both the positive and negative wires are plugged in
Sep 02, 2012 | Peg Perego John Deere Gator HPX Ride on...
Our son's peg perego john deere gator stopped working and we thought it was the battery so we bought a new battery. We charged the new battery for 24 hours and hooked it up to the gator but it still gave...
It is most likely the Gearbox, it is easy to find and easy to replace. It is right under the gear shifter and is a "harness" with wires that will need replaced, if you call the tech support for Peg Perego they are very helpful and will get you on the right track. Your old battery is most likely fine, but keep it until you fix the gearbox switch. Afterward (when gator is again operational) I would imagine you could return the new battery since you really should not need it. Peg Perego support is 1800-728-2108 and you can also look for parts at www.mypegperegoparts.com
Feb 19, 2011 | Peg Perego John Deere Gator HPX Ride on...
I havent used by feber car for 5yers n i lost the adaptor to charge it so if i get a new gharger will it be fine to use it or should i remove the battrey n re-charge the battery? n where can i get the...
KidsWheels features a full line of Kids battery powered electric ride on vehicles, cars, pocket bikes, Kids battery powered electric toy cars, Kids cars, Kids ride on trucks, Kids ride toy Quads, Pedal Cars, Big Toy Ride Ons, Big Wheel, Jeeps, Peg Perego Battery Powered John Deere Gator, Honda Minimoto, Winther Tricycles, Peg Perego Vespa, Peg Perego battery powered John Deere Worksite Gator, Peg Perego Gaucho Super Power S Series, Peg Perego Gaucho Super Power S Series, Peg Perego Ranger RZR, Orange County Choppers, Power Wheels Ninja, Peg Perego Gaucho 4.0, Lightning PAC, Power Wheels MX3, Peg Perego John Deere Power Lift Gator, peg Perego Polaris 800 Twin, Power Wheels Nascar Ride On Jeff Gordon L7822, and more..
KidsWheels Ride On Toy Store
519 North Bell Blvd.
Cedar Park, TX 78613
800-396-9680 512-257-2399 Fax 512-257-0093
Store Hours:
10AM - 5 PM CST Monday - Friday
10AM - 4PM CST Saturday
Closed on Sunday
http://www.kidswheels.combenluis_1.jpgbenluis_0.jpg
Jan 17, 2011 | Toys
How do i know if the battery is fully charged 12volt peg Perego battery
the charger's L.E.D. ... when plugged to the charger will glow GREEN if fully charged, YELLOW if charging, if it is charged and gator still is not working it is probably the shifter switch is bad, this is verycommon and fairly cheap and easy to fix(under 40.00)
Oct 26, 2010 | Peg Perego John Deere Gator HPX Ride on...
My son had peg perego 4 wheeler electric and I had extra battery He only 1 cricle around the house and it stop even battery been charge please help
first of all check for at least 12 volts from the battery and the charger, you can test this using a multimeter, if the battery doesn't show any volts, lift up one side of the blue plastic housing on the top and verify that both the positive and negative wires are plugged in
Aug 30, 2010 | Peg Perego John Deere Gator HPX Ride on...
Battery is charged but car is still not working,
I have the switch go bad on the gas pedal. You can find a replacement here http://tigerimports.net/sunshop/
Nov 30, 2009 | Peg Perego John Deere Gator HPX Ride on...
Peg-perego John Deere buck EXT reads fully charged, but won't go.
I would replace the high/low switch and the reverse switch.
You can get the peg perego parts at http://www.shopjandl.com/
but I would first check the connections on the motors and foot switch. Sometimes they come loose.
Hope this helps
May 12, 2009 | Peg Perego Vespa Scooter
Toys Logo
71 people viewed this question
Top Peg Perego Toys Experts
romney2012
Adam Fjeld
Adam Fjeld
Lawrence Oravetz
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
