My hp photosmart C7200 fax machine not recieving fax, it said blocked calls are not displayed on this report
Not going fax and not inoming fax
Posted on Jul 23, 2012
5 Suggested Answers
  • 9 Answers
SOURCE: HP 1250 fax machine
Check if your fax machine is in Fax Mode or Auto-Fax.
Posted on Dec 30, 2007
leroyal
  • 2120 Answers
SOURCE: I have a new hp
Look for something in the menus called JOURNAL PRINT
Posted on Nov 21, 2008
SOURCE: Fax machine giving error message.
I thought you would help me with my problem not try to sell me a service plan. The problem is resolved and the machine is now working properly. If you want to know how it was achieved send $19.95 for the answer.
Posted on Dec 17, 2008
SOURCE: cannot recieve a fax
i have a H P 3050 THREE IN ONE AND I CANNOT RECEIVE FAXES I HAVE COMCAST AND HAVE ALL MY SERVICES IN ONE, CABLE, PHONE AND INTERNET. DOES ANYONE KNOW HOW TO PLUG THIS IN CORRECTLY
Posted on Jan 13, 2009
I have a HP Photosmart All-in-One series C7200. I keep getting an error message saying "Image on Fax Teport is set to Off". Error 388. The proble occurs when we try & send long distance. What should I...
Definition
There is too much noise on the line for a valid connection between two fax machines to complete. The noise problem might go away over time.
Solution
Retry the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve.
to check the error codes and there solution
click on the following link Hope you its satisfactory
ERROR CODES C7200 Series
http://h10025.www1.hp.com/ewfrf/wc/document?docname=buu02549&cc=us&lc=en&dlc=en&product=3382185#Error386
Jan 03, 2010 | HP Office Equipment & Supplies
When recieving a fax the print speed is at a snail pace. It takes for ever for the printer to print a page of the recieving fax.
try this and let us know. do fax diagonastics.
Test the fax setup from the control panel Follow the steps below to perform a fax diagnostics test.
  1. Set up the all-in-one for faxing according to the setup instructions found in the product's User's Guide .
  2. Make sure you have inserted the print cartridges and loaded paper before starting the test.
  3. Press Setup , 6 , and then 6 . This displays the Tools menu and then select Run Fax Test . The HP all-in-one displays the status of the test on the color graphics display and prints a report.
  4. Review the report.
    • If the test passes and you are still having problems faxing, check the fax settings listed in the report to verify the settings are correct. A blank or incorrect fax setting can cause faxing problems.
    • If the test fails, review the report for more information on how to fix any problems found.
  5. After you pick up the fax report from the all-in-one, press OK . Then turn the printer off, and then on again. If necessary, resolve any problems found and rerun the test.
Accessing the Diagnostic Utility from HP Solution Center The fax Diagnostic Utility can also be accessed from the HP Solution Center software, by selecting the HP Fax enabled product in the drop down box, and then following these steps:
  1. Select Settings , Fax Settings & Setup , Fax Setup Wizard .
  2. Tab through the Fax Setup Wizard to get to the end of the process. This is a good opportunity to ensure that your fax machine is setup correctly.
  3. Click Click here to run the Fax Test . The HP all-in-one displays the status of the test on the color graphics display and prints a report.
Sep 14, 2009 | HP Officejet J5780 All-In-One InkJet...
My C7200 Photosmart Printer/fax says " Origininsl Jam" .
If you are using DSL I suggest you to use filter. that will resolve your issue
Aug 19, 2009 | HP Photosmart C7280 Printer
BLOCKED CALLS
If you subscribe to a caller ID service through your phone provider, you can block
specific fax numbers so the device does not print faxes received from those numbers.
When an incoming fax call is received, the device compares the number to the list of
junk fax numbers to determine if the call should be blocked. If the number matches a
number in the blocked fax numbers list, the fax is not printed.
Set the junk fax mode
By default, Block Junk Fax mode is turned On. If you do not subscribe to a caller ID
service through your phone provider, or do not want to use this feature, you can turn
off this setting.
To set the junk fax mode
▲ Some models have a Block Junk Fax button. Depending on the model you have,
do one of the following:
Block Junk Fax button: Press the Junk Fax Blocker button, select the Block
Junk Fax option, and then select On or Off.
Color display menu: Press Setup, select Basic Fax Menu, select Junk Fax
Blocker Setup, select Block Junk Fax, and then select On or Off.
Add numbers to the junk fax list
There are two ways to add a number to your junk list. You can select numbers from
your caller ID history, or you can enter new numbers. The numbers in your junk list are
blocked if Block Junk Fax mode is set to On.
Feb 11, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
How to do multiple copies on HP Photosmart C7200 All-in-One series
Instead of pressing the shortcut to print, go to file>print> and type in the amount of copies that you require then press print.
Nov 24, 2008 | HP Office Equipment & Supplies
Hp photosmart 2610 all in one series. I can receive faxes but can't send them
First, in the FAX mode, scroll to PRINT REPORTS on your HP's display. You can then print out all fax activity, including failed SENDS. There should be an error code associated with the failure, and this may help to point you in the right direction. Using the HOOK button on your fax, call your cell phone. If your cell rings, answer it, and listen for the FAX TONES. If your cell does not ring, press the MENU button on your HP, and scroll to either FAX SETTINGS, FAX SETUP, INITIAL SETUP, or FAX SEND MODE. Try changing , one-by-one, any settings related to sending faxes. Be sure to write down the original setting before you change it.
Sep 10, 2008 | HP Office Equipment & Supplies
I have a new HP Photosmart C7200 All-in-One Series printer, scanner, copier, fax. I can send faxes, but am not able to receive incoming faxes. According to the fax log, several faxes per day have tried...
Is the phone line for the fax dedicated? an answering machine? it would need to be plugged into the fax machine. Set the number of rings very low,
If you have another phone line, call the fax & see what it does, alternatively, have a friend call with a fax machine & monitor the progress.
Jul 18, 2008 | HP Office Equipment & Supplies
Fax confirmation set up
document.tlSearch.tx.value=unescape("") s.gif s.gif HP LaserJet 3050, 3055, 3390, 3392 AiO Product - How to Print a FAX Confirmation Report Description By default, a Fax Confirmation report (Fax Call Report) will only print when a fax error occurs. However, this option can be changed using the printer control panel.
  1. Press the right arrow until Reports appears in the display, press the checkmark.
  2. Press the right arrow until Fax Call Report appears in the display, press the checkmark.
  3. Press the right arrow until Print Report appears in the display, press the checkmark.
  4. Right arrow to the option of choice, press the checkmark to save the change.
FAX call report options
  • Send Fax Only - a confirmation sheet will only print when a fax is sent
  • Never - no fax confirmation sheets
  • Every Error - default setting
  • Send Error - a fax confirmation prints when the fax transmission encounters an error
  • Every Fax - a fax confirmation sheet will print for incoming and outgoing faxes
Mar 31, 2008 | HP LaserJet 3050 All-In-One Printer
59 people viewed this question
k24674
jasbo
jasbo
