Question about Samsung PCL541R 54" Rear Projection Television
Sumsung rogrction tv color is yellowed - Samsung PCL541R 54" Rear Projection Television
  • 2 more comments
  • mommaduke131 Apr 11, 2011
    Is the PCL541R the same as the SUMSUNG HC-R4755W Projection tv cause thats what I'm needing help fixing the color is yellowing
  • mommaduke131 Apr 12, 2011
    I got white but it looks like the sides are off in color it's blue in the middle and green or yellow on the sides
    I tried that and it didn't work either
  • mommaduke131 Apr 13, 2011
    I tried adjusting the convergence that didnt work either
    President:
  • 1,961 Answers
There are 3 color cathode in your TV red,green,blue cathode.The blue cathode might not working in your set that is why you have a yellow screen.Open the back cover of your TV you can immediately see the 3 cathode lamp at the back.Power up you tv and see whether tha 3 lamps are lit.If one lamp do not light up,check the circuit board where this lamp is connected resolder all the components in this lamp.there is also an individual screen adjustment fo r the lamps it is located at the front pannel and labeled RGB screen...try this frist and let me know how it goes..
Posted on Apr 11, 2011
  • 2 more comments
  • Danilo Baraquiel
    Danilo Baraquiel Apr 12, 2011
    hello sir I think you did not read my solution .The problem of your TV is just adjusting the brightness of the 3 cathode there is an adjustment at the front panel you need to adjust it manually.the adjustment for the screen brightness of each 3 colors are labeled red,green and blue .to adjust this screen you must have a still image on the screen or a color bar so that you can mix the 3 color perfectly.
    heres the steps,
    turn the green cathode adjustment clockwise your screen must look greenish.
    reduce the green adjust ment by turning it counter clockwise..
    do the same to the two other screen adjust ment..
    now look at the picture notice the white image spot at the screen like a white coat or a clouds.this image must appear totally white
    adjust the 3 screen adjustment mix then until the clouds or a coat appear perfectly white.
    now your done adjusting...good luck!
  • Danilo Baraquiel
    Hold on please...
  • Danilo Baraquiel
    that is another set of adjustment sir a convergence adjustment.try using the auto convergence adjustment on your remote.If auto adjustment did not work you can do manual adjustment...I'll give you the steps on manual adjustment for the meantime try first the auto convergence..
  • Danilo Baraquiel
    does the pincushion adjustment of your TV is functioning?is the picture appear to be like an hour glass?if yes, locate the convergence ICs which will be large black ICs attacked to a heatsink. Try resoldering the pins on these ICs first. If that does not resolve the problem, replace the ICs. These should be marked STKxxx.if you do not have any knowledge in electronics repair .I would advice to ask a techncian to do the job for you because this is not a DIY issue.
Can't figure out which color cables go where on tv to dvd
follow the color code, red white and yellow from dvd output to red white and yellow tv input, match the color of cable end to color inside the jacks of the units
Mar 10, 2013 | Philips Televison & Video
Sony Trinitron's colors have turned green yellow
Only yellow color denotes the absence of Blue color. Check it. Check its video output card for any loose solder terminals at the blue color output section circuits.
Jan 12, 2013 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Our tv just started having a fuzzy image and the auto focus function aborts during the red color alignment. is there a manual alignment I can do to fix it.
What does this fuzzy image look like? Does it have ghosting shadows. Of course it is possible to align red manually from the convergence menu. But first lets confirm that it is indeed a convergence related problem.
Aug 18, 2010 | Samsung HCL552W 55" Rear Projection...
Yellow color
Ur tv is missig the red color,when it turn into yellow color.Take ur tv to another location,put it into another coalax incomming signal cable use it for awhile see,if have the same problems?Not,than it ur coalax incomming signal cable is defective.Yes,take ur tv aparts the video board that connected to the CRT socket holes are cold solders,resolders those CRT socket holes to have good conductivity.Will not lose red agian.Or take it to the shop,they will resolders it for you.Ask they'll charge u maybe $40-50 get it service,more than that don't they're cheating u.
May 08, 2010 | Insignia NS-24 TV TV
Wii Console: We just bought mario bros for the wii. We have a s...
The wii doesnt go black and white by itself. It's your t.v.
May 05, 2010 | Nintendo Wii Console
Does anyone know how to hook up a sumsung nv3, which comes with a yellow and white cord, one that hooks up to the TV) or is there another cord that was lost. I don't know, but if you can help I'd...
Thank you for using Fixya. Does the yellow and white cord have a round end with a metal tip on the middle? If it does that is the RCA cable, and it is meant for the Audio and Video inputs of the TV. If it is not round, please let us know the exact model of the camera so that we will be able to find out how the cables should be connected.
With regard to the camera being connected to your computer,, generally what camera uses is a USB cable.
Jan 04, 2009 | Cameras
Recording TV
Hi.. it looks as if that particular dvd/vcr is not compatible with the coding digital signals that the hdmi is putting out so it's not converting the signal over correctly.. if you try just using the regular analog cable instead of the hdmi, that might solve your problem.. i hope this helps..d
Jan 24, 2008 | Samsung DVD-VR357
Blue and yellow color
Blue should converge on top of "yellow".Bad connection(s)
on blue convergence IC.Replace both IC's for durable repair.
Check pico fuses.Reset convergence alignment.
Oct 17, 2007 | Samsung HCL552W 55" Rear Projection...
Samsung PCL541R 54" Rear Projection Television Logo
49 people viewed this question
Jerry Greenberg
Jerry Greenberg
