The recording device reported the media error: Write error. (0x0C, 0x00.) What does this mean?
  • Computers & ... Master
  • 27,725 Answers
What brand of dvd rw are you using you might have got a bad batch of dvd rw discs or you are using a cheaper brand also you might use a lens cleaner for this dvd rw
make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or the drivers may have been corrupted or you might have a virus run your antivrus program you might have to physically unplug the leads for this cd/dvd burner then plug them back in this should activate the found new hardware wizard or you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Posted on Apr 11, 2011
Can someone help me with my external HDD (MY PASSPORT)
Lots of info there, but what exactly is the problem with the drive?
Dec 18, 2014 | Western Digital 1TB My Passport Essential...
Computer memory issue...PLEASE HELP?????
Intel[R]G41 EXPress chipset[vendor id=0X806,device id=0x2e32]
Feb 16, 2012 | Acer Veriton Computers & Internet
RIPPING MY HAIR OUT TRYING TO FIGURE OUT WHAT KIND OF R.A.M. I NEED? I HAVE ORDERED 6 DIFFERENT CONFIGURATIONS AND STILL GET BEEPING NOISE AND NO POWER ON FOR COMPUTER. PLEASE SOMEONE OUT THERE HAD T
you lost me you have a g41 and mixed memory and e6700acer and beep start test power supplysame memory typego to tigerdirect memory configurer one stick close to cpu in swap out pound del key see if bios check outgo for match set
Feb 16, 2012 | Acer Computers & Internet
I have a philips audio recorder cdr 760 When i try to record cd rw a blank audio tdk cd the machine said OPC FAIL What I have to do to record the cd rw on my Philips cdr 760 Thanks for your...
There are a lot of forums which discuss OPC failure and it strikes every hardware maker and brand of media.
The bottom line is that certain media and certain writers just don't get along.
The manual:
http://www.p4c.philips.com/files/c/cdr760_17/cdr760_17_dfu_aen.pdf
Discussion online:
http://homerecording.com/bbs/general-discussions/recording-techniques/phillips-cdr870-187247/
http://answers.google.com/answers/threadview/id/318687.html
"I don't buy expensive blanks. I buy modest quality blanks and watch
for sales so that I can them for about a dime a piece after the rebate
check comes in. If I have an OPC Fail message, I try another blank. If
I find that they consistently fail (about half a buck wasted) I move
the stack over to the computer (which seems to work fine with these)
and buy another stack of blanks of a different brand next time I see a
good price..."
an interesting workaround:
http://www.sweetwater.com/forums/showthread.php?10128-Tascam-CD-RW5000
"CDRW 5000 work around for OPC FAIL
Here's a work around for OPC FAIL on cdrw 5000 -
method 1: turn unit on at least 30 minutes or more before use (this seems to work best for me)
method 2: run OPC on an old cd that always works - after OPC passes, remove old cd and insert new CD (you only get 99 OPC runs per disc)
-or use a combination of the two methods
I've always used TDK and I recently bought a new batch and they stopped working. The old ones still work everytime. I don't know enough about the system to guess what the difference is.
side note: CDRW 2000 will finalise discs from the cdrw 5000 but not the other way around.
Hope that helps "
Jan 30, 2011 | Philips CDR760 CD Player
Burn fail or cd skip
Kind of sounds that way. They are pretty inexpensive now days, and simple to install.
Good luck
Mar 17, 2009 | Gateway M680X PC Notebook
Burn error
You unit is faulty.. replace the unit with a new one. The CD Write Laser has probably "Burnt Out" or perhaps the "Quadrant Detector" has faulted.. either way a new unit is only way solve ya problem ... sry :(
Sep 03, 2007 | HP Media Center m7250n (ED842AA) PC...
YAMAHA CRW8424 gives Track following error..
PROBLEM DEFINITION: Basically, it is a hardware error that occurs when a drive is not capable of following a data track on a CD-R or CDRW or on the other hand, poor power flow may cause the problem SOLUTION: 1. Try use another disc, a disc with a different band. 2. If one doesn't work, you may have to open your system and use a different power connector, making sure no other devices are using the power connector in the same strand. 3. Lastly, if neither the above doesn't work, you may have to send your drive in for servicing as the head may be dirty or misaligned.
Aug 05, 2007 | Yamaha CRW 8424 Burner
Computers & Internet Logo
95 people viewed this question
David Payne
David Payne
