Question about Brother LS-2125 Mechanical Sewing Machine
Where can I order a bobbin case for a ls2125 sewing machine it just that a small piece broke
    Genius:
  • 1,788 Answers
There are a few places online such as www.sewingpartsonline.com, or sometimes places like JoAnn fabrics, Sears local repair shops sell them. It is a class 15 bobbin case,
Posted on Apr 13, 2011
The black plastic piece the bobbin fit in is broken.
You may have a timing problem or bent needle. You will need to replace the bobbin basket if it is damaged.
Jan 28, 2014 | Singer 7466 Mechanical Sewing Machine
Sewing computer bobbin problems
you may need to take it to a sewing machine shop to see about getting it fixed
Apr 25, 2012 | Sewing Machines
My bobbin case came out of my sewing machine and I can't get it back in correctly. The bobbin case moves around. I have a singer cg-500/550
I just had this same problem and although i could not find the answer online, I managed to fix it.
If you look at the bobbin case there are 3 different tabs sticking out.
First you need to have tab #1 under the main part of the machine, and #3 over top of the small twisted metal piece below the bottom fabric gripper.
The hard part is to get the second tab into the proper spot. I circled the piece that you need to move in red. If you move the little piece by pushing it with a flat screw driver, you can line up the bobbin case so that tab #2 is under the metal piece and the bobbin case will be properly set.
Don't give up! It wasn't easy to get it back but I did it, I'm sure you can too!
Apr 27, 2011 | Singer CG754 Mechanical Sewing Machine
My daughter tried to remove a jammed bobbin on my singer machine. The bobbin holding mechanism fell apart. Is there a diagram to show how the parts fit together?
looking straight on at the area where assembly goes, First clean and oil area, the jam was likely caused by accumulated dust or a small piece of thread . You should have three pieces, four including the bobbin itself. first piece to be replaced has a center post this piece goes into the machine by fitting it to the bobbin area, it will only go in one way so when it fits into place you will know. the next piece is a ring this piece has a small piece of metal attached to the top when looking at it correctly the two screws will be on top and there should be two indentions. first one is at 3 oclock and the other is at 9 oclock fit this piece into machine and there should be a lever on either side that turns around and rests in to indentions. replace your bobbin in the bobbin case ,be sure to thread the case correctly and load into newly assembled bobbin area making sure that it clicks into pplace
Nov 06, 2010 | Singer 1120 Mechanical Sewing Machine
Hand wheel is stuck and machine will not sew
You will probably find that there is a small piece of mthread stuck in the raceway area, either turn the balance wheel backwards so it frees off or take the bobbin and bobbin case out and have a good look, when you take the bobbin and bobbin case out if the machine does not move then you have a problem elsewhere.
Jun 26, 2010 | Sewing Machines
Bobbin compartment trouble
Put the needle in the up position. Tilt the machine back with one hand and lay the hook in its position on what is called the hookrace. The little ledge inside the the circle opposite the other part that moves. Then take the outer ring and lay that in over top of it. There is a small pin on the bottom that fits into a notch. The two small nubs should be on the outside, then click the two black knobs over those. Put the bobbin in the case and the thread through the notch up under the tension spring on the case. Looking at the back of the case, pull the thread and in most machines the bobbin should turn clock-wise. Now snap it onto the post.
Your good to go.
Good luck.
Jul 31, 2008 | Brother XL-5130 Mechanical Sewing Machine
Brother sewing machine ls2125
Don't go directly from the thread spool to the bobbin.
You have to go via the thread quide, (near the end of the head at left side) and under the small roller.
Pass your thread to the bobbin turn your thread 3 turns to the right, clockwise,
then pass the end of the thread, under the coming thread and give it another 3 turns to the right.
For better results, always remove old thread from bobbin before filling it up.
Push the thread winder lever to lock the bobbin.
Start winding slowly. If the thread is loading in the down position,
put your finger under the thread between the bobbin and the the thread quide, untill you see that the thread is feeding evenly.
Jun 14, 2008 | Brother LS-2125 Mechanical Sewing Machine
Bobbin case is moving out of place
I was having the same problem with my machine and finally the spring broke. I couldn't find any parts for this so my husband made me a new spring out of a coke can! LOL!! Anyway, he messed with it for a while and it kept doing it. He figured out that it was not the spring but the other piece under the spring was not pushed up far enough to keep the bobbin case in place so he took a screw driver and pushed it forward toward the bobbin case and now my bobbin case does not move!! And the machine is sewing perfect! At least for now. Anyway, it's not the spring or the thread adjusting screw!
Jun 06, 2008 | Brother CS6000i Computerized Sewing...
Brother LS-2125 Mechanical Sewing Machine Logo
54 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
