Question about Brother Sewing Machines
I have a Brother SE 400 and the automatic needle threader lever is very hard to press down at the end to get the thread to go into the needle.
bargainbox
  • 1388 Answers
SOURCE: Needle Threader is not lined up
This is called the Needle Threader Plate.
If this is too small for you to read, or you want any more help with this, just post back here, or, drop a line through the "Contact Us" page at www.bargainbox.com.au
Posted on Feb 24, 2008
SOURCE: Brother SE 270D Cassette threader
When you push the cassette down, there is a little tiny wire hook that comes through the needle eye to catch the thread. The needle must be in perfect alignment for the wire hook to go through the eye of that needle. If the hook is bent a little OR the needle is bent a little or not all the way up, the needle won't get threaded. The wire will not go through an eye smaller than an 11/90. First thing I try is a new needle that is all the way up in the needle holder. If threading still fails, probably the wire hook is sliding to one side of the needle, not through the eye. The action happens so fast, it is hard to see exactly what the problem is.
Hope that helps. I am not a fan of the cassette system. A side arm needle threader is easier to problem shoot.
Posted on Jan 09, 2008
bargainbox
  • 1388 Answers
SOURCE: threading the needle of the embroidery machine
You may need a magnifying glass to see the tiny hook that should pass through the needle eye to catch the thread....
....if it is not aligned properly and does not go through the eye you will need to realign it....
...there may be a small screw attaching the mechanism, loosen slightly with jewelers screwdriver so you can move it but there is still some friction and gently engage the needle threader to see how far you need to move it, then gently, using a fine screwdriver, tweesers etc, nudge the tiny hook a little, check result and continue to adjust until remedied....re-tighten screw.
If there is no screw adjustment, a gentle bending will resolve the problem............but if there is no tiny hook, it will need replacing.
They are not easily broken, but only use gentle pressure to be sure.
Posted on May 23, 2008
RickE1
  • 202 Answers
SOURCE: Broke the hook off the automatic needle threader
You can get a new (grey) threader inexpensively that pushes on the bottom of the threader shaft from a dealership. Easy to do it yourself or they can do it in 5 or 10 minutes. Try taking the old one off and looking at it. It pulls right off.
Posted on Dec 01, 2008
talk2ginny
  • 34 Answers
SOURCE: automatic needle threader on brother se-350
Hi - first, make sure that you raise the needle to as far up as it will go. When you thread the machine, make sure you pass the thread through each number along the path - there is a hook on the threader mechanism that is really easy to miss. It is always a good idea to refer to the book when you are having a problem.
You might also try changing the needle. The threader has a teeny hook that goes in to the eye of the needle from behind, grabs the thread, and pulls it back thru the eye of the needle.
The threader can go out of alignment. If you got the machine last fall, it should still be under warranty. You can call Brother and ask where you can take the machine for repair. Or, you can go to Brother's website and look for information that might be helpful.
Good luck,
Ginny
Posted on Jan 31, 2009
Brother Se 400 sewing machine
The needle threader is a very delicate item on the machine. What is your question? As always, please have a trained technician make the repair for you, they have access to any parts you may need and they can do it safely too!
Cheers,
Embroidery Services
San Diego, CA
Sep 09, 2017 | Brother Sewing Machines
The automatic threader wont pick up and thread needle. Can do manually but thats not easy?
to make manual threading of a needle easy buy a needle threader
it is a instrument that has a very fine piece of wire in a loop that you push through the eye of the needle , put the thread in that loop and pull the loop back out of the eye and the needle is threaded
available from most any shop that sells material , cotton , thread or sewing machine shops
cost --pack of 2 for $1.00 or there abouts
Oct 05, 2016 | Sewing Machines
Automatic needle threader won't work on brother pe-770
Always make sure the hand wheel is at the exact top. Have you replaced the need recently? If it's bent, then the threader will not work. If the needle is loose or not all the way to the top in the holder, it will also cause the threader to not work.
Jan 06, 2013 | Brother PE770 Computerized Sewing Machine
I have a really hard time getting the needle to thread.l I cannot manually pass the thread through the needle eye: the eye is just too tiny; and I cannot even see the hook part of the automatic threader...
I have that machine, and am wondering if your needle has a burr on it, try a new needle, #11 or #80. You may also have no hook in your automatic threader to go throught needle eye. My first automatic threader was defective, no wire to go through the needle to catch the thread. Take a magnifying glass and look when you change your needle and watch when you pull your threader down, do you see a really fine wire come through the needle eye? If, not yours is defective because it has to pull the thread into a little loop for you to pull your thread through it after you release the lever quickly, Mine was a Singer and they sent me a new one right away, Brother will do the same for you, I am sure. Another thing you can do is go to your dealer and have them inspect it, I went to JoAnn fabrics and that is how I learned that I was not crazy, it was the machine,
Apr 20, 2011 | Brother CS-6000
AUTO THREADER CAME OUT
When you activated the threader, the needle was down and the threader came off or broke.
If it is not broken, you may be able to push it back into place.
Turn off the power and tip the machine back on some towels so it does not slip and with a flash light check the area where it fits and see if you can get it back into position.
If not, will have to thread the needle the old fashion way.
Check with your Brother dealer to see if they can look at the machine while you wait.
They may be able to get it back together or they will have to replace the threader.
It is possible they will have one in stock, or they may have to order it.
May 01, 2010 | Brother CS-8060 Computerized Sewing...
How do you thread a pfaff 7570
If only we could put video links in here! But here goes:
Raise the presser foot;
Turn the hand wheel until the take-up lever (the hook bit that goes up and down, above the needle ) has reached its highest position;
Remove the small spool holder from the horizontal thread holder that is under the lid. Put thread reel onto spool, replace spool holder;
Pull thread behind first thread guide - it is the cream flat plastic bit towards the back - about 1" x 3/4" (i.e. the thread takes the first exit at the back);
Bring it down the left-hand long slot on the front of the machine, back up the right-hand slot, over the hook of the take-up lever, back down the right-hand slot and pass it from the side between the thread guide (silver metal bit just above the needle - looks a bit like curled metal). I found this last guide the most difficult to figure out - tried to get the thread into the curled bit - but you don't do that - it just slips in behind;
Thread goes through the eye of the needle. You can use the needle threader or not. Instructions for needle threader:
Lower sewing foot (makes more room and clamps the thread in the upper tension discs so it is less likely to keep spooling off while you are trying to thread);
Turn handwheel until the needle is in highest position;
Pull the needle threader straight down and then twist it to the front so the tiny hook on the threader goes through the eye of the needle;
Take thread under the larger metal hook on the left, put your thumb on it to stop it coming off, thread goes back towards the needle and under the small hook that is poking through the needle from the back;
Twist the needle threader towards the rear, releasing the thread carefully and allow the threader to move upwards. There should be a loop of thread left in the eye of the needle and you can now pull it all through to the back.
That sounds really complicated but I find the Pfaff needle threader works really well, unlike that of some other machines. I also have a Husqvarna Designer 1 whose needle threader works great, but the one on my friend's Designer SE is useless. Go figure!
Feb 02, 2010 | PfaFF Creative 7570
Automatic needle threader on brother se-350
Good luck,
Ginny
Dec 21, 2008 | Brother XL-3500
Auto threader
The parts for any autothreader are necessarily delcate considering the nature of its task. Check (without thread) to make sure the tongue that passes through the eye of the needle isn't bent a tiny bit causing it to strike next to the ****. Have seen this more than once.
Sep 07, 2008 | Brother NX-400
I too have a christmas gift causing headaches - loopy embroidery. But at least this one I found a work around for... I thread the cassette according to the arrows but when I get to "6" I loop up around the left side and over the top of the bend but DON'T go far enough to cut the thread. I leave about 4 or 5 inches loose and hold the end at the top-right of the thread cassette at about the 2 o'clock position. I push the cassette down into the machine normally and right about when the 6 is below the window the thread will cut leaving you holding the left over piece. Continue pushing down until click and needle will thread. Have not had any threading problems since learning to leave a tail on the thread. Hope this helps.
Jan 05, 2008 | Brother SE-270D Computerized Sewing...
Sewing Machines Logo
691 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
