Question about Kyocera FS-2000D Laser Printer
Will not print
USB connection to FS2000D was disconnected and linked up to Samsung printer for one job. When re-connected to Kyocera the computer stated it could not print because "USB printer status not available."
  • 163 Answers
Go to the Start menu and select "printers & Faxes". Ensure that the FS2000 is set as your default printer (right click on icon and select as default). If you still cannot print you will need to reinstall the printer drivers from disk or download from the Kyocera website.
Posted on Feb 18, 2009
My kyocera fs-1024 mfp can not connect with the computer due to some short circuit in the pcb of usb card as the computer can not detect the machine so can i get a spare part of usb part of the machin
Unfortunately, you won't get a spare part for the USB slot only. You have to replace the PWB CONTROL ASSY. Depending on the model you have (e.g: with FAX or without) and geographic region where are you located (e.g: USA or EU), there is a different part number that you must order. If the printer have other connectivity option (like LAN), try to connect using this option.
Dec 07, 2014 | Kyocera Office Equipment & Supplies
Tray 2 wont print kyocera fs2000d
you have to go into the print driver settings and tell the driver that tray 2 is installed. kyocera support website can help with instructions for print drivers
Jun 28, 2013 | Kyocera FS2000DN Laser Printer
SCX4824FN driver
Fixya doesn't have any drivers for any device, the only place to get the software is at the manufacturers support site, if they don't have the needed drivers to use Linux then it likely doesn't exist.
Feb 10, 2012 | Samsung SCX4824FN Mono All-in-One Laser...
Dear...i have kyocera printer FS2000D and error code 7410:233769... Can somebady give me some advice what can i do....Thanks in advance
Drum unit non- installing error
The drum unit is not installed or not
installed properly.
The drum PWB EEPROM does not communicate
normally.
Causes:
- The drum unit is not installed.
- Defective connection drum PWB (YC1) and connect-L PWB (YC3).
- Defective drum PWB EEPROM.
- Defective engine PWB.
Check procedures/corrective measures:
- Install the drum unit
- Check the connection of connectors drum
- Replace the drum unit
- Replace the engine PWB
Oct 05, 2010 | Kyocera FS-2000D Laser Printer
Kyocera FS2000D. Paper jam reported occassionally
this is problem with sensor you have to check all the sensors like
registration sensor
duplex jam sensor
paper exit sensor
face down tray paper full sensor........
easy way to solve this problem is remove Durmunit and toner box and rear unit then clean it useing a blower and refix all the componet and try...........
Oct 06, 2009 | Kyocera FS2000DN Laser Printer
Black line on prints from Kyocera fs2000d
remove the drum by opening the LHS of the printer & removing the toner waste bottle, then depress the grey button on the drum assembly & firmly pull the assembly out. Best done in a darkish room as the drum is light sensitive.
The black line couldn't be fixed as it is caused by a scratch less that 2mm long on the drum. Ether a new drun at £299 or a new printer ar £245..
Dec 03, 2008 | Kyocera FS-2000D Laser Printer
Looking for the part number of a Kyocera TK312 FS2000D printer. Any ideas on what that part number is ?
Dear,
This is (TK312) Black Toner Cartridge ,which is used in Kyocera FS2000D Printer.
Be Happy Always
Regards
Dec 03, 2008 | Kyocera Office Equipment & Supplies
Need printer driver
Hi. go www.driverguide.com then signup. all new and old drivers are there. hope it helps.
Oct 01, 2008 | Kyocera Mita FS 3800 Laser Printer
Kyocera FS-2000D Laser Printer Logo
166 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Henry Gertcher
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
