Question about Freestyle Mongoose Bmx & Owners Manual - Bike / Bicycle
Cannot get to shift into gear 7. will do 1-6 just fine. Mongoose paver model R4874Wm. How do I adjust
    Brigadier General:
  • 8,546 Answers
When i shift to 2nd gear and let off it shifts back on its own
Travis:
Put the rear derailleur into second gear and stop the bike before it shifts back down. Look carefully at the derailleur and you will see two small screws next to each other. These are stop screws. The stop screw for high gear may be out of adjustment, or the front derailleur is out of alignment putting sideways torsion on the chain forcing the chain to drop back into first gear.
May 04, 2014 | Mongoose Maneuver Mountain Bike
How do i adjust the gears on a mongoose xr 200 mountain bike
Take this "how do i adjust the gears" to a standard search engine for instant video advice.
Aug 04, 2011 | Mongoose Cycling
The gears are not changing to the right gear but i tried to change the gears to see if it will change back where it should be but it didnt. on my handle bars gears dile is saying 3 and 7 but the gears are...
Release your gear selector cables; position your chain on the 1st.or lowest gear
for both the derailer and, pedal gears.
Adjust your cables tighten and, test (some bikes use the highest gear to adjust from.
Jul 03, 2011 | Mongoose Exile 26 Men's Full-Suspension...
How does the gears work on the mongoose xr500 moutain bike
There are search engines that will find the answer so much faster than flushing this through Fixya.
There is nothing unique to Mongoose regarding shifting.
Use your favorite search engine and look for "how to shift gears on a bike". You will find many videos.
Jun 04, 2011 | Mongoose Tech 4 Full Suspension Mountain...
New Mongoose 700c Men's Paver bike: Mongoose 700
Local bike shop determined that both wheels were defective. I took the junk back to Walmart and got a refund... PROBLEM SOLVED!!
Dec 28, 2009 | Mongoose Cycling
How to adjust front and rear shifting gear
there are two small screws located on the derailleur. Hi/Low
http://www.parktool.com/repair/
this might help too
Dec 04, 2008 | Mongoose Exile 26 Men's Full-Suspension...
Chain Rubbing
Kevin:
I'm not sure if it's rubbing on the front or rear shifter. The front is more common, so I'll try that first. The shifter pushes the chain left (lower gear) and right (higher gear) to shift - if it's rubbing, then it may be trying to shift. If it can't be fixed by using the shifter directly, which you've probably tried already, you'll probably need to adjust the cable.
There are two ways to adjust the cable, with a barrel adjuster and with a wrench. The barrel is the piece between the cable housing (plastic tube the cable goes through, usually black) and the shifter. If it's the front shifter, it will be the one one the left of your handlebars. Try 'unscrewing' the barrel a little bit at a time. It may be off in either direction, but 'unscrewing' will tighten the cable, and since you bought the bike in the summer, it's likely that the cable has stretched and become loose since then.
Count the number of turns and try only 1 at a time, watching to see if the rubbing goes away. If not, return it to where it was by turning the same number of turns the other way.
Without knowing whether it's the front or rear, which gear it's in and which side it's rubbing on, this is my best answer. Let me know and I'll adjust my advice!
Dan
Nov 19, 2008 | Mongoose Exile 26 Men's Full-Suspension...
Freestyle Mongoose Bmx &  Owners Manual - Bike / Bicycle Logo
193 people viewed this question
Top Freestyle Cycling Experts
Rommel Balcita
Christian Samuelsen
Christian Samuelsen
Level 1 Expert
Are you a Freestyle Cycling Expert? Answer questions, earn points and help others
