Question about Miele CVA4070 Coffee Maker
I have a Miele CVA 4070 and the grinder recently stopped working. I disassembled it and found that when the unit starts the grinding phase, I hear a slight "click" that seems to come from the controller board but no voltage flows to the grinding motor. I'm assuming it's a problem with the controller board but since Miele wants $500 for a replacement board, I thought I'd check with the community for other possibilities. Thanks for your help.
  • 1 more comment
  • Bud Welsh
    Bud Welsh Mar 19, 2016
    Hi, There is a diode that connects just before the grinder, the parts runs $40.00. Mine didthe same thing, replaced thermal sensor, now all is good
  • roger p
    roger p Mar 04, 2017
    Where is the thermal located? by any chance you have a picture of it? anyway to bypass to test out?
  • Luigi Marazzi
    Luigi Marazzi Feb 15, 2018
    did you sort this out?
Hello lzp9,
I have seen this problem when I started using Google - we had better coffee this never happened when we had Lotus Notes
Posted on Apr 12, 2011
I have Miele coffee system CVA 4062 the grinder is not working properly? I have cleaned everything, Descaled all that good stuff.
Its likely to be the brushes in the Grinder motor. These are replaceable but Miele does not sell them as a spare part. You may be able top fabricate your own if your technically minded and experienced and can disassemble the machine. Otherwise grinder needs to be replaced. Regards
Jan 18, 2017 | Miele Coffee Makers & Espresso Machines
CVA 4070. Where can I get replacement gaskets and brew unit?
Check with local appliance parts distributor and/or Miele to determine availability and source.
Sep 01, 2015 | Miele Coffee Makers & Espresso Machines
My miele coffee maker CVA 4070 dispensing tubes are clogged
I had this problem ... you need to remove the dispenser from the rear of the door. Then once removed clean in running water. Its a sealed unit but you can squirt high pressure water inside to dislodge the coffee sludge. When clean .. fill with water and make sure the 2 spouts drain evenly. regards
Jul 09, 2014 | Miele CVA4070 Coffee Maker
My miele coffee maker CVA 4070 how do I reset when it's locked in descaling
When you start the cleaning cycle, Don't stop the process by pulling the plug! Turnthe unit off from inside wait 5+ seconds & turn back on and thecleaning cycle should restart... If you do not use a cleaning TAB..Open& shut the LOOSE coffee Door under the drawer (Top Left) and thecycle will continue.
I have miele CVA 4070 It just recently started only brewing about 1/2 to 2/3 cup of coffee or espresso and the rest of it goes into the waste container. So the waste container has a watery puck and...
Have you clean the brew unit with the cleaning tablets? This dissolves and rids the brew unit of the oils which in turn build up and clog the brew unit - the result being watery pucks and less product being disbursed.
Feb 21, 2014 | Miele Coffee System
Cva 4070 drip tray issue
Miele CVA 4066 -Empty drip tray warning would not go off even after draining the drip tray, cleaning contacts, and resetting power. Water was coming out from under the empty tray.
I pulled unit out and removed sheet metal in rear around water inlet. when I attached water line and power cord & turned on power, I could see water dripping out of one of the 2 solonoids on the water inlet valve. $168.00 from Miele and no expensive service call.
May 27, 2012 | Miele CVA4070 Coffee Maker
I have a three month old Miele CVA 4066. I have recently cleaned the unit twice (using little tablets in coffee grinder), as well as descled. The coffee, expresso, etc. is barely dripping out of the unit. ...
your brew unit is clogged. It will need to be removed and cleaned every 24 hours as per the owners manual. There is a yellow laminated card in the box with the accessories that shows step by step how to perform the 24 hour maintenance. To prolong the life of the brew unit, make sure the coffee grind size lever is in the middle or to the right of center, rather than the left (fine) side. Also, you only want to use dry beans, preferably espresso beans. Oily beans like french roast will clog that brew unit up very quickly.
Feb 10, 2011 | Miele CVA 4066 Stainless Steel
Miele CVA 4070 coffee system
I called Miele hot line & here is the solution to fixed the problem... 800-999-1360.
http://www.miele.com/
Whenyou start the cleaning cycle, Don't stop the process by pulling the plug! Turnthe unit off from inside wait 5+ seconds & turn back on and thecleaning cycle should restart... If you do not use a cleaning TAB..Open& shut the LOOSE coffee Door under the drawer (Top Left) and thecycle will continue.
Aug 25, 2008 | Miele CVA4070 Coffee Maker
Miele coffee maker cva 4070
OK. Here's the deal. I struggled with this CVA 4070 (F 73) problem also recently, and even posted a questions in the cyber world about it. I jiggled, re-cleaned the machine, re-read the Miele manual, and scoured the internet for schematic drawings of this brewing unit's insides. No luck. Finally after finding out I'd have to pay $199 just for a service clown to walk in my front door, I said NYET!!!  I must solve by myself. If I can take apart & fix my Dyson, etc, etc, I WILL DO THIS TOO!!  (MUST HAVE COFFEE>>>)
Pull out the brewer, turn it a quarter-turn to your right, and look at the spot where that small black plastic piece -- shaped like a block "M" or block "W" -- should be situated. Pull it out, if it isn't out already. Don't worry about yanking it out or harming these parts, said the Miele troubleshooter guy in New Jersey on the phone. They're "made from the same plastic used in football helmets."  Okey-dokey.
This approx. 1.5" wide, blocky plastic piece is part of the "slide" that takes the brewed coffee grounds into the waste container. When positioned correctly, it looks like a block "W,"  with the "wings" ointing up, and slides in just under a brown 1.5" flat piece. A small, down-facing tab on the brown piece clicks into the "W" piece and holds it in place. The "W" should feel fairly solid, although it is not rigidly in place, as the entire mechanism is a movable system to deposit the grounds in the waste receptacle.
Put everything back inside your CVA 4070 "love" machine, hit "on," and wait for it to go through its warm-up.  No F73 message?  Yeah!  Mission Accomplished. You, like I, have fixed your Miele, saved your family relationships, and saved yourself a bundle from unnecessary service calls.
Feb 27, 2008 | Miele CVA4070 Coffee Maker
Miele CVA4070 Coffee Maker Logo
607 people viewed this question
Top Miele Coffee Makers & Espresso Machines Experts
just-ice
Michael Galve
Michael Galve
Colin Stickland
Colin Stickland
Are you a Miele Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
