Question about Sewing Machines
Sewing needle for model 4562 sewing machine
What size needle works best in a model 4562?
    Problem Solver:
  • 7 Answers
Posted on Sep 02, 2009
I am having a difficult time finding pressure feet for my Singer 4562 such as button hole, button sewing, embroidery, walking foot, quilting foot, etc.
You should be able to find presser feet for your machine as long as you know what type of shank your machine takes. Just confirm that whatever you choose will fit a Singer model 4562. You can even purchase a snap-on shank adapter and then purchase snap-on feet for your machine.
Product Quick Search 318 335 4567
Sewing Parts Online Search (look for 4562)
Apr 23, 2016 | Singer Sewing Machines
Euro-Pro 998A Sewing Machine needles
the size & type needle depend on the fabric you use to sew,
try these sites for parts
May 29, 2012 | Euro-Pro Sewing Machines
I have a Singer Sewing Machine Model 4562. The machine will not pick up the bobbin thread. I was told by a local sewing repairman that the timing was off. Can anyone tell me how to fix it myself, a
have you tried changing the needle? usually flat side goes to the back of the machine
rethread the machine top & bobbin
make sure the bobbin is inserted correctly into the bobbin case
clean under the needle plate & in the bobbin area for lint or loose threads
try these sites about timing
Apr 10, 2012 | Singer Sewing Machines
Need to locate a source of blue tipped sewing machine needles. the manual in euro-pro denim machine states needles are best for mending and other fabrics.
Schmetz make a blue coated needle, usually best for denim fabrics as the coating aids the needle in slipping between tightly woven fibres such as denim. It may also be called a Denim needle.
But you shouldn't need to use that needle for most fabrics, just the most appropriate sized needle and either sharp point for wovens or ball point for knits. Perhaps get a mixed pack of both sharps and ball points to start with.
Try this website if you want to shop for needles on line, they carry a wide range of types, sizes and brands. Klasse and Schmetz are both high quality needle brands. You want the 130/705H system of needles for your domestic sewing machine. These are the norm for 99% of domestic sewing machines.
There are other needle systems for industrial machines (round tops) and EL705 for overlockers, these are extra long but identical shank design at the top. So just make sure you get the regular needles 130/705H.
In terms of what size to use, here is good reference guide on sewing machine needles.
The important thing is to change the needle for each new project, ie about 4-6 sewing hours, as a blunt needle will never give good results. If you always start with a new one, and its the right sized needle for the fabric you are sewing, then you should ensure best possible stitching results from your machine.
If the needle is too big, it will leave holes in the fabric, too small and it will break. If you use a sharp point on stretch fabrics, you'll get skipped stitches. If you sew a lycra knit with a ballpoint and it still skips, then change to a "Stretch" needle, this will also be blue coated ballpoint and helps with skipping and needle deflection.
Then there is twin needles, twin stretch needles, winged needles and leather needles, all for special techniques. Never worth trying to scrimp on needles, I have probably have in excess of 40 packs of different sizes and types in my sewing cabinet.
Hope this helps you out.
and they sho
Sep 24, 2011 | Euro-Pro Denim Sewlution 380 Mechanical...
I have a Singer model 4562 T sewing machine, and threading the bobbin, the bobbin case just kind of popped out. I've tried just sliding it back in, but no matter which way I put it in it doesn't seem to...
The bobbin case is designed to be removed for cleaning. Take off the needle plate if it is still on the sewing machine. Make sure that the needle and presser foot are fully up. Guide the forked end of the bobbin case under the feed (more or less centered). Then pull the bobbin case under the rim of the position plate. Pull on the side opposite the forked end of the bobbin case. With a small screw driver, turn the lever (at about 10 o'clock on a 12-hour analog clock) towards you. This will lock the bobbin case into place. Make sure that the bobbin case isn't locked too tightly. It still needs to move slightly as the bobbin turns and the needle comes through that plate.
Replace the needle plate and lock it down. Then insert the bobbin and close the slide plate. The manual shows the procedure to remove and replace the bobbin case on the 4562 on page 39. Singer has the manual on the support page: . The direct link to the manual is .
I hope this helps.
(I hope that the locking lever hasn't broken. That may require a service person to solve the problem. I'm not entirely sure where that lever is connected to the machine. Some Singer part diagrams are here: . The 4562 may use the same diagram as the 4572, .)
Jul 01, 2017 | Singer Sewing Machines
I have a white sewing machine model 415 and cant find needles to fit the machine
Hi. Sewing machine needles are standard sizes, so you shouldn't have a problem finding needles to fit. You use different size needles depending on what weight and type of fabric you plan to sew (I posted a chart that explains what size needle to use with what fabric).
What do you want to sew?
Feb 26, 2010 | White Sewing 1866 Mechanical Sewing...
I have a Singer Sewing Machine Model 4562 T I
yes you can get help from youtube.
How to Fix / Repair the Hook Timing on a Sewing Machine
Oct 16, 2009 | Singer 132QRFB Mechanical Sewing Machine
I don't not have the Instructions on how the bobben should be threaded in the bottom of my sewing machine. I have tried everything that i can think of but it well not thread. If it dose come up it dose not...
The manual for this sewing machine (Model 4562) is available and may be downloaded at no cost from Singer.  The Link to that page is:
Inserting a wound bobbin is found on page 15.
Aug 09, 2008 | Singer 7462 Mechanical Sewing Machine
Sewing Machines Logo
121 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
