Question about Toshiba B-SA4TP Printer
I enable to print FRID tag with B-SA4T printer. Can you advise me how to enable RFID printing in the printer
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • Toshiba Expert
  • 142 Answers
You need to send the correct codes to the printer.
Use Caodesoft RFID or Batender automation to program the RFID
Else you should send the programming codes depending on the RFtags.
Posted on May 04, 2011
Fatal error 231 error 3
RFID Reader I/F Error An interface error was detected
with the RFID reader device.
01: communication error between
the RFID reader and the engine
PCB.
02: the transceiver circuit error of
the RFID reader.
03: communication error between
the RFID reader and the Tag
chip.
04: the RFID Tag detection error
Jul 17, 2014 | OKI C6100n Laser Printer
How can I fix oki c3530 231: fatal error 03?
PCB.
the RFID reader.
chip.
Jun 21, 2014 | OKI C5800Ldn Led Printer
Error 231 E3
PCB.
the RFID reader.
chip.
(more than 4 chips).
Apr 07, 2014 | OKI B4600 Printer
Printing barcode + overwriting RFID tag
no most bar codes will print out but it must be printed in black and wite as for changing the barcode no you have to download a special program that lets you make bar codes. not sure how though
Jun 17, 2013 | Office Equipment & Supplies
My datacard sp35 will only print in yellow. What
Do you get any errors?
1 st unplug and plug in to reset power
2nd replace print ribbon with new one, could be bad ribbon or bad RFID tag on the ribbon
3rd try printing a different card
if still not working i would recommend sending in for service.
Contact MidWestIdSolutions.com for more info.
Jan 06, 2010 | Datacard SP35 Plus Printer
Lables getting printed alternatively
This is due to :
Wrong size of label.
You must give a page size and the gap size
It is very important to give the correct height and ga dimensions
The detecting sensor chosen is not the right one
Nov 27, 2009 | Toshiba B-SA4TP Printer
Datacard sp35 is saying it has a k ribbon but really has the color ribbon. It will only print in monochrome
Most likly problems in order of most common,
Bad RFID radio tag in take up spool of printer ribbon,
Bad RFID reader in printer
Printer need firmware upgrade to help in reading weak tags.
Fist would try a new ribbon, if that does not get it will need service. Contact MIdWestIDSolutions.com
Oct 12, 2009 | Datacard SP35 Printer
SP55 Datacard
The printer does not know the the model of the ribbon installed and thinks it is a monochrome (single color) Print ribbon. You can verify this in the Driver toolbox under the supply tab, or in the advanced printing options.
The Datacard SP series printers use an RFID Radio freq. tag in the take up spool end of the ribbon. This identify s the ribbon model and supply use settings for the printer.
Make sure you have the most recent driver and firmware from Datacard, There is a firmware Update Available to help reading "weak" RFID tag's
Next try removing the RFID tag from another (old) ribbon and see if it that fixes the problem)
Aside from that you:
May have a counterfeit (non-Datacard) ribbon
A bad RFID tag
Someone removed your RFID tag
You need a firmware update (weak RFID tag)
A bad RFID reviver in the printer, which is a fairly cheap repair.
Basically try a new print ribbon if that does not correct the issue, have the printer serviced.
www.TulsaBiz.net
Apr 07, 2009 | Datacard SP55 Plus Printer
Ribbon out displayed
Your RFID tag might be bad. You might want to replace RFID board.
Feb 16, 2009 | Fargo Office Equipment & Supplies
Pebble 4 miss ribon setup from time to time
Sounds like a failed/failing ribbon sensor. Each color ribbon has an embedded RFID tag. The PC/driver requests the ribbon tag info from the printer, and sets the driver according to the reply (R3011-YMCKO, for example). The mono-chrome/black R2011 and R2211 ribbons don't have RFID tags. If the PC/driver requests the ribbon tag info, and gets a response of "none found", then the driver will be set for "K" ribbon.
This can also be a fault due to spotty communications with the PC - bad USB cord; USB port; printer logic board issues; etc. Try a different USB cord, port & a different PC to see if the problem will resolve. If not, then it seems the problem is with the printer itself.
May 02, 2017 | Evolis Dualys Thermal Card Printer
Toshiba B-SA4TP Printer Logo
81 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
