Question about Kenmore 74602 Gas Dryer
Kenmore dryer 11097591240 gas ignites some times igniter is goodflame sensor is good dryer runs. Coils?
  • 1028 Answers
SOURCE: kenmore elite gas dryer won't fire up
replace the coils on burner valve ..they will fail sometimes after initial heat up both are in kit change both
Posted on Jun 06, 2008
Illeagle
  • 525 Answers
SOURCE: dryer wont heat
About all that is left to replace is the flame sensor mounted at 9o'clock on burner flame tube, but I would double check your airflow, This is CRUCIAL to the normal operation of the dryer.
Also, a lint filter with an invisible coating from fabric sheets can cause an airflow disruption, try running without clothes and the filter removed.
Tip: Always provide the complete information provided on the manufacturers product information data tag, located on the unit, and not in the user’s manual. This will help you acquire a more accurate and expeditious response to your complaint.
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jun 23, 2008
  • 686 Answers
SOURCE: kenmore gas dryer [changed to propane] will not heat
Does it ignite? tell more plz
Posted on Mar 01, 2009
SOURCE: Kenmore Gas Dryer not heating. (74602)
i have a kenmore dryer the outside air vnet was cloged real bad , ive since cleaned it out but the only resone i found out was becoues my dryer will not heat up , is there a over heat swich ? can any one help .
Posted on Apr 01, 2009
MNfisherman
  • 11896 Answers
SOURCE: my kenmore gas dryer ignites and the flame shuts off after 10 sec
The valve on the pilot may need to be replaced. The springs get worn and wont stay up. Otherwise you could replace the entire pilot unit with a kit.
Posted on Jul 20, 2009
Kenmore Elite He3 gas dryer (110-92832100) not heating. Igniter glows red for a min or so, drum spins, hear a loud 'buzzing' noise....
The problem could be flame radiant sensor or in most cases the gas valve solenoid coils sitting on top of the gas valves. The radiant sensor must be aligned perfectly with the igniter. The radiant sensor contacts bypasses one of the gas valve solenoid coils and as the igniter heats up it makes the sensor contact trips unbypassing the coil and allowing the gas to flow and be ignited.
The problem is with the solenoid coils,
one with 2-prongs and the other has 3, if the radiant sensor is aligned with igniter and working perfectly but no gas is ignited. The buzzing sound is coming from the coils trying to operate the valves. Replacing both coils is the simple and only viable solution.
Jul 18, 2011 | Kenmore Elite HE4 Electric Dryer
Kenmore gas dryer 70932, 70942, 70952 won't heat. Dryer turns on and tumbles but won't heat.
Check the following areas to combat this issue. the most common problem spot will be a blown Thermal fuse.
1. Gas valve coils
Igniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
Note: Sometimes the whole gas valve may be defective, thus not letting the gas out. However, this problem is not common.
2. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
3. Igniter
Igniter may burn out or break. Replace the igniter if found defective.
Note: Igniters are very fragile and break easily. It is recommended to handle the igniter only touching the ceramic part of it (usually white in color).
4. Flame sensor (or radiant heat sensor)
Replace the sensor (located near the igniter) if found defective.
Oct 04, 2009 | Kenmore Dryers
My dryer runs but does not heat Kenmore 110.74722400
1. Gas valve coils
2. Thermal fuse
3. Igniter
Sep 05, 2009 | Kenmore Dryers
Kenmore gas dryer wont heat up
1. Gas valve coils
2. Thermal fuse
3. Igniter
Aug 11, 2009 | Kenmore 73952 Gas Dryer
My kenmore gas dryer is not heating.I have taken apart and cleaned the lint trap as well as run a shop vac through the vent.
1. Gas valve coils
2. Thermal fuse
3. Igniter
Jun 17, 2009 | Kenmore Dryers
Kenmore Gas Dryer runs no heat were do I Start first
Check the following to address your issue. check each section of the dryer thoroughly.
1. Gas valve coils
2. Thermal fuse
3. Igniter
Jun 15, 2009 | Kenmore 74602 Gas Dryer
No heat burner comes on for a few minutes and then goes out
Check the following to address this issue.
1. Gas valve coils
2. Thermal fuse
3. Igniter
Jun 02, 2009 | Kenmore 72062 Gas Dryer
My Kenmore series 80 dryer quit heating. It was intermitent for a few days then quit. I checked the inspection window and didn't see any light. The gas it on and it seems like there is a "click" after I...
The heat is regulated with a Klixon mounted next to the blower housing near the vent pipe so it can judge the temperature of the air coming out of the drum.Right next to it is a melting type fuse.6aed02c.jpg If the dryer runs and gets too hot the fuse will melt.But the dryer will still run. So if the fuse is good(continuity) and the dryer control(cycle) thermostat is also good then you should have power going to the gas valve assembly when the machine is running unless the timer is in the no heat or wrinkle free/cool down mode. When the gas valve assembly is energized the flame sensor a%20flame%20sensor%202.bmp flame sensor mounted outside the burner chamber detects the heat from the ignitor. When the heat is very intense then the sensor shuts down the igniter
a%20igniter.jpg Igniter and that frees up the power so that the coils can be fully energised and open the gas gates. The gas comes out and hits the red hot igniter and you have ignition. It stays on for maybe 2 or 3 minutes or until the control thermostat is satisfied and shuts down power to the gas valve assembly.
If your gas dryer has a good flame sensor and a good igniter AND the dryer will work some and quit, replace these: dryer%20coil%20kit.jpg Gas operator coils The coils get hot and quit on these machines when they get a little age on them. It is aggrevating because it is a hard to diagnose thing. But well worth the 20 bucks.
Dec 22, 2008 | Kenmore 659 Electric Dryer
Kenmore gas dryer model 110.76814690 will not heat up
The bottom panel is held on by spring clips. Use a putty knife to access the bottom. The heat is regulated with a Klixon mounted next to the blower housing near the vent pipe so it can judge the temperature of the air coming out of the drum.Right next to it is a melting type fuse.8f17134.jpg If the dryer runs and gets too hot the fuse will melt.But the dryer will still run. So if the fuse is good(continuity) and the dryer control(cycle) thermostat is also good then you should have power going to the gas valve assembly when the machine is running unless the timer is in the no heat or wrinkle free/cool down mode. When the gas valve assembly is energized the flame sensor a%20flame%20sensor%202.bmp flame sensor mounted outside the burner chamber detects the heat from the ignitor. When the heat is very intense then the sensor shuts down the igniter
a%20igniter.jpg Igniter and that frees up the power so that the coils can be fully energised and open the gas gates. The gas comes out and hits the red hot igniter and you have ignition. It stays on for maybe 2 or 3 minutes or until the control thermostat is satisfied and shuts down power to the gas valve assembly. So... If your gas dryer has a good flame sensor and a good igniter AND the dryer will work some and quit, replace these: dryer%20coil%20kit.jpg Gas operator coils NOTE: The coils get hot and quit on these machines when they get a little age on them. It is aggrevating because it is a hard to diagnose thing. But well worth the 20 bucks.
Dec 21, 2008 | Kenmore 63942 Dryer
No second ignition
still suspect coils they have been known to not pull in on restart especially after a warm up if sensor bad probably wouldn't start first time both coils come in a kit replace both
May 22, 2008 | Kenmore 74602 Gas Dryer
Kenmore 74602 Gas Dryer Logo
55 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
