Question about Henry Numatic "" Canister Vacuum
Henry still sucks ok! but blows out dust from the top
Sucking and blowing
Shop-Vac® Brand. The Original Wet/Dry Vac™
https://www.shopvac.com/
Shop-Vac® is proud to be an American-based company. ... When we say the Shop-Vac® is powerful, we're talking debris cleaning, leaf-blowing, heavy-duty, wet or ... Many of our vacs are backed with a 3 to 5 year warranty, but we've seen ... I had just gotten back from work, so my arm was hurting, and I really didn't want to ...
My ShopVac Blows - WOOD Community
community.woodmagazine.com > Forums > Tools and Tool Buying
Nov 23, 2009 - My ShopVac suddenly started blowing dust out the exhaust ports. I don't mean a little dust, it blows almost as much dust as it sucks in!!!! ... ... I'd look it over very carefully looking for tears or splits. Might be a good idea just .... A few months ago I purchased a Dust Deputy and hooked it up to my shop vacuum.
10 Shop-Vac Vacuum Hacks For Around The House - Thrillist
https://www.thrillist.com/.../10-shop-vac-vacuum-hacks-for-around-the-...
Sep 14, 2015 - Simply flip the switch from suck to blow and blow leaves to your heart's... you really need to get your act together if you're using a Shop-Vac for ...
Shop Vacs...and dust control? - Home Forums - GardenWeb
ths.gardenweb.com > Home Forums > Cleaning Tips
Jan 09, 2016 | Shop Vac Vacuums
Charles hoover blowing dust out
http://hoover.com/support/video-instruction-guides
go adn see the instructional video for fix it. use the common sense. God bless you
Sep 19, 2012 | Numatic Henry Bagged Canister Vacuum
Not sucking up well.
Hi Pauline. This could be many things. Check the easy things first to diagnose. Blow into hose to check for a clog , then check the motor filter.It should be clean. If its still not sucking well make sure the vacuum is sealed when closing the machine. Please let me know if this does not help, Chris
Feb 21, 2011 | Henry Vacuums
Blowing insteading of sucking
Go online to HOOVER.com and locate your nearest repair facility. Take receipt with you to show it's a new purchase.
Feb 05, 2010 | Vacuums
Hi i have a henry vacuum which my daughter used on wood/coal ash and now does not work.
OK... You are suggesting that Henry doesn't work because of what your daughter did with him. This may or may not be fair on your daughter! Depending on the degree of filtration in your Henry, he should be able to cope with ash (as long as it wasn't hot) without difficulty. Provided that your Henry had an undamaged cloth or paper bag, and that his "top-hat" cloth filter is intact, I think it unlikely that the ash is the cause of the problem. Many people use their Henry without a bag - this is a false economy, as dust always always finds its way in to the motor and, ultimately, that's terminal. Look at the underside of Henry's motor compartment (the black part) where the air goes in, and at the exhaust where the air blows out - if it's obvious that he's been sucking or blowing dust, you probably need to replace him. However, if bag and filter are intact, you probably need to look elsewhere for the source of the problem, and the first place to look is the electric flex (particularly for damage where it enters the plug). I hope this helps - but if not, please post a comment again and we'll look further. Good luck!
Dec 14, 2009 | Numatic Henry Bagged Canister Vacuum
My henry hoover has stopped sucking
screw the pipe off and clean with cold water.
check dust bag or change,
check that nothing is abstructing the suckstion from the head & neck. of your hover,
Oct 29, 2009 | Numatic Henry Bagged Canister Vacuum
I have a dyson that is picking up just fine when on vacuum mode, however when I try to use the suction tube there is no suction at all. It is not blocked and the canister is empty. Help!
Hi, I have an upright DC03, brilliant machine. Mine wouldn't **** and had the following symptoms;
- it sucked ok from the top hole where the canister joins the unit - with the canister the dust didn't spin aroun inside the canister like it normally does and there was no **** at the hose end or brush end. - with the top of the canister attached (the cyclone) but not the bottom it sucked through the cyclone - the small valve on top of the cyclone unit was sucking heaps
this indicated to me the machine was sucking through the cyclone unit but when the canister was put on it was blocked - hence the tremendous sucking through the valve on the top of the cyclone. As far as I could see the cyclone wasn't blocked so I poked some wire down the tube inside the machine that runs from the bottom of the unit (where the hose sits) up to the bottom hole where the canister joins.
The DC03 has 2 holes where the canister attaches, it seems like it sucks air through the top hole, through the cyclone and through the lower hole sucks the dust up this inner tube into the canister. Check that tube, shine a torch from the top hole and you should be able to see the light at the bottom. Make sure you clear it completely.
Mine was very very blocked. I kept poking and removing dust until I could see light at through the tube. Works fine now.
Hopefully this helps someone as it took me awhile to work it out.
Good luck
Aug 12, 2008 | Vacuums
Henry hoover - occasionally it won't **** and I can usually sort it out. This time it just won't **** anything up.
Hi, Have you checked the hose for blockages and also the only main problem with these are you know when you take the top off then their is that big round filter that sits on the lip that holds the two parts together, Check this is in the correct way and that the seal is not damged check also the clips holding the top and bottom together are secure.
But blow down hose make sure not blocked then check the filter this might even need banging to remove dust in case its built up to much and not allowing the air to get through it ok
Let me know how you get on ok
Apr 23, 2008 | Vacuums
Henry Numatic "" Canister Vacuum Logo
Top Henry Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Henry Vacuum Expert? Answer questions, earn points and help others
