Question about Brother CS-6000
I had sewing machines E6 computer bother a few yeas . Now I sewing , it turn E6 . what does E6 mean? Can you help me . How to fix it? Thank you.
    Genius:
  • 1,788 Answers
Download a free manual from www.brother-usa.com and under support and put in your model number. E6, means that the thread is tangled, totally unthread it, now with the presser foot up, rethread, pull the top thread, now lower the presser foot and pull the thread, it should barely move. This will seat the thread in the tension discs. Read your manual before using, it will save you lots of grief. People love to skip this step, and wonder why the machine is not working right. This is one time you should take the time, it is worth it.
Posted on Apr 17, 2011
The bottom thread keeps bunching up and stalls the machine with the #E6. How can I fix?
Suspect the top thread is not seated completely in the tension disk.
Remove the top thread from the machine.
ALWAYS RAISE the presser foot and rethread from the beginning.
Verify the thread path is correct.
Test your machine.
You can also look in the troubleshooting section of the manual for what the E6 code means.
OR, search for:
Make Model E6
Jul 09, 2017 | Sewing Machines
Showing E6
You receive the error message E6 when the motor locked up because thread is tangled or the machine is seizing up.
Remove the tangled thread, it it still happens that means your machine is seizing and requires service.
Apr 30, 2014 | Brother CS-8060 Computerized Sewing...
E6 code for brother xr7700
E6 means the machine is seizing somewhere and the motor is working too hard to turn the hard-to-turn machine. Get is serviced before it seized completely and the cost of repair goes even higher.
Apr 03, 2014 | Brother XR7700
Brothercs6000i E5 E6 wont sew
could have a problem with the computer part of the machine, it would be a good idea to have it checked.
Nov 24, 2013 | Brother CS6000i Computerized Sewing...
My CE5000PRW the wheel well not move and it keeps coming up e6 but it just wont sew... HELP!!!
To find out what the error means, search for:
Make Model (error code)
Depending on what the error is and whether it can be user-corrected, it may need to be serviced.
Nov 13, 2017 | Brother Sewing Machines
Code Lo
Betcha there is a small battery inside that helps maintain the computer's ROM. Since this is a sears machine call Sears/Kenmore parts and see what they can offer you in the way of help.
Oct 02, 2012 | Kenmore 19110 Computerized Sewing Machine
I keep getting the E6 (tangled thread) message on my Brother CS600 when I try to sew. I have check for tangled thread and cannot find any. Could it be that the bobbin case needs to be replaced? It seems...
is the bobbin case damaged in any way?
try turning off the machine & unplugging it & then replug it back up & turn it on & see if that clears the computer parts of the machine
if it still shows a E6, then you can replace the bobbin case or you might even consider having it serviced
Aug 29, 2011 | Brother CS6000i Computerized Sewing...
Ihave anerror E6 and I can no find the problem
Hi! The E6 error means the thread is tangled. I suggest you completely unthread the machine, including the bobbin. clean out any lint or bits of thread in the bobbin area, and carefully rethread.
Hope this helps!
Robbie
Feb 15, 2010 | Brother CS-8060 Computerized Sewing...
Brother Sewing Machine CS-100
actually e2 is the button hole lever being down. e6 means that the thread is tangled and to prevent the motor from overheating the machine automatically stops. All you have to do is re-thread the machine and take the bobbin out, untangle it and put it back in and sew. This usually works. If it keeps happening, there could be a few things wrong.
1. if you are using thick fabric your tension should be lower. normal tension is 5.
2. your machine is out of alignment. take it in to a service center, they can fix it in 5 minutes. to find a service center near you go to http://www.brother-usa.com/service/
3. your needle is old or bent and should be replaced.
4. Your needle is too thick, standard is 80. The thicker the fabric, the thicker the needle.
May 19, 2007 | Brother CS-100-T Computerized Sewing...
Brother CS-6000 Logo
468 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
