My TV picture went out, I only have sound. What can I do to fix it? How much would it cost to take it somewhere?
  • 927 Answers
GOOD DAY, MALCOMJALLANI;
FIRST TRY RESETTING THE TV BY UNPLUGGING THE TV FROM THE WALL FOR 3 -5 MINUTES. THE COST (AVERAGE) OF REPAIR FOR A PROJECTION TV RUNS FROM $300.00 TO $700.00. ($550.00).
GOOD LUCK ON YOUR NEW PURCHASE, BIG IRISH.
PS; ALWAYS ASK FOR AN WRITTEN ESTIMATE AND ALWAYS USE AN FACTORY AUTHORIZED SERVICE CENTER.
Posted on Aug 07, 2008
My sylvania lcd tv screen went white and still has sound
Hi taralee? my tv did the same thing last night. can you tell me what you found out? can it be repaired? thanks
Aug 23, 2009 | Televison & Video
Magnavox 42mf231d/37 - no picture
Common problem on this tv, ceramic capacitor beside horizontal transistor.Need be Replace . 561K 2KV
Aug 06, 2009 | Philips Magnavox 27MS343S 27" TV
RCA 32 in TV no picture no sound just a beeping noise TV power is on
Hello cote,
This indicates a problem in the power supply either the low voltage switching supply or the High voltage power supply. The sounds you hear is the shutdown circuit activating, I would not suggest that you try to repair this problem because of the dangers involved. I would suggest that you take it to a qualified TV repair shop. This problem should not cost you much, however it is the best choice for the problem you described.
I hope this helps,
Thank you,
Shuttle83
Mar 14, 2008 | RCA 32V524T TV
Tv went black and no sound standby light falsh twice and paused and flashed twice again
This indicates a short happened somewhere in the set, causing the set to go into "safe mode" where it won't let itself turn on. Oftentimes it's the convergence board. Depending on what that will cost you, you may want to just replace the set.
Mar 01, 2008 | Sony KP-61HS10 61" Rear Projection...
No picture, but it does have sound. HLN617W
This sounds similar to the same problem I had with my TV. I went out and purchased a new light thinking it was the source of the problem, but I was wrong. It turns out the color wheel and fan went bad and it cost roughly $575.00 for the parts and labor to fix it. My tv was the hlr6167w
Feb 24, 2008 | Samsung HLN617W 61" Rear Projection HDTV
Phillips 29" TV
Sounds like it has an intermittant connection somewhere which is very common now a days due to the lead-free solder all the makers went to. Resolder everything that looks suspicious, especially the bigger components. It could also be a failure of the flyback transformer though which often times fail like this.
Hope Ya Fix It.
Feb 13, 2008 | Philips 27PT6441 27" TV
Curtis mathis TV
With the price of this screen size below $150.00 (well known makes and models) no you can't get it fixed for less.
Jul 11, 2017 | Curtis CM25101S 25" TV
No Picture
mbrave , Your set has cold solder joints this means you have poor connections on your chassis / resolder around flyback and all poor connections this should fix it,if not then look for leaky capacitor 100uf 160volts.rember solder first! laubaker YOUR TV if at my shop repair cost 85.00 you have 1 or 2 things wrong if only shorted hori out 85.00. you have lost of high voltaged.
Nov 03, 2007 | RCA F27242GY 27" TV
No picture / No Sound / No nothing
that sounds like the Hi voltage transformer went bad.. If your a tech simply disconnect the horizontal output transistor and see if thats shorted. If it is then it is for sure the HV transformer. If its not shorted look in the main power supply. Its cost is around 40 bucks or so and the transistor is about 15 to 20 bucks. This entire repair should cost ya around 150 to 175. So if you decide this tv is the one you like then have it fixed. Good Luck
Jun 01, 2006 | Sony KV-36FS100 36" TV
Televison & Video Logo
35 people viewed this question
Top Televison & Video Experts
Electro Med Services...
