We have an airtech Elite ceiling fan. One of the kids got hold of the remote and changed the settings which is easy assesable once the battery cover has been removed. could you please assist me with the right settings for the switches or advise me where to go to have it fixed. I live in Cape Town South Africa so if I need to see somebody it would have to be here. Thanks for your time Karel
PungaA
  • 91 Answers
SOURCE: Phone Lock - Samsung SGH-X670
The Phone-Lock is a manually set code, this means that you or the previous owner set this code on the phone to prevent it from being stolen.
Consult the previous owner to get this code.
Second option is to have Samsung remove this code for you, but this option usually costs money.
SIM-lock can be removed by contacting the provider the phone is locked to.
Posted on Oct 11, 2007
otacon
  • 1944 Answers
SOURCE: MEMORY CARD ERROR
To recover the data on your card. I suggest using a memory card reader and not through the camera.
Posted on Dec 16, 2007
  • 230 Answers
SOURCE: I have a programmable thermostat.
There is a base plate that is screwed to the wall. The face of the thermostat should come off from the base. Usually the batteries can be found back there. Some times a little tug will get it off the wall. Other models have small plastic release clasps that when pushed in will allow the unit to come off.
Posted on Jun 30, 2008
alexpomar
  • 26 Answers
SOURCE: Kenwood Chef (model no.KM 300)
Hi, check in ebay.co.uk if the seller have worldwide delivery.
or check in kenwoodworld.com
remember for model km only fit A993 and A337
best Regards
Kenwood Chef Restore
Posted on Sep 01, 2008
Geno111
  • 183 Answers
SOURCE: Ribbon for Olympia de Luxe portable typewrter
go to "www.google.com", in the box type "olympia de lux typewriter ribbon" then hit "go" you should find plenty
Posted on Dec 02, 2008
My airtech elite ceiling fan no longer spins
The switch could be no good.
Motor could be shot or needs oiling as they do dry out sometimes.
Is there power to the fan if not could be a circuit breaker has tripped.
If your fan is hooked up to a light switch on the wall that switch might be turned off. Ive done that before.
Feb 04, 2015 | Dryers
Airtech elite ceiling fan remote/reciever not working!
Are you sure its not the remote that's failed? check the batteries first
Nov 14, 2012 | Dryers
Hunter Ceiling fan remote is operating all the other ceiling fans as well
Sounds like all the dip switches are set to factory still. Easy enough to fix.
Slide open the battery compartment on the back of the remote control and remove the fan's canopy against the ceiling. Then just change the switch to a different setting but make sure that the remote and fan have the same setting. Repeat this in each room so that all the fans have a different setting to each other.
Hope this makes sense.
Aug 02, 2012 | Hunter 52" Ceiling Fan With Light And...
Need to program Hampton Bay Ceiling fan remote control CHO88T7030T, HELP!
Change the battery. This is the first step when troubleshooting a ceiling fan remote. The easiest fix to any remote control problem begins with battery replacement. A 9-volt battery is needed to operate all Hampton Bay ceiling fan remotes.
Check the light switch used for the ceiling fan. The light switch found on the wall must be in the "on" position. This allows the ceiling fan to be operated by remote control
Re-program your remote. If battery replacement fails to get your remote working again, try to reprogram the remote. Open the battery cover you will see 4 dip switches. These switches must be set to the same position as the receiver on the fan. Use the screw driver to move the dip switches either up or down.
Follow the previous step to change the frequency if the ceiling fan is randomly turning on or off. Other electronic devices such as garage door openers can interfere with the ceiling fans receiver, causing it to randomly turn on or off.
Sep 10, 2011 | Televison & Video
Have hampton bay add on remote control kit on patio ceiling fan. Battery died in the remote, so kid turned fan off with pull chain. replced battery, now cant get fan to work on any pull chain settings....
The pull switch in the fan may be broken in the off position. Luckily these are easy to replace. Purchase a new switch. Obtain a wire stripper and phillips screwdriver. Lower the light (if installed) or the blank by removing the screws. Disconnect light if installed. Unscrew nurled knob on fan switch and remove switch. Make note of where the wires go, I take a picture with my cell phone. Cut wires off as close to the old switch as you can. Strip about 1/4 to 3/8 inch of the insulation off the end with the wire stripper. Insert into the appropriate hole in the switch. Nothing to tighten to lock down here, it will hold it. Reinstall switch and light and test for proper operation.
Jul 09, 2011 | Garden
The remote for the master bedroom is controlling two rooms at once, how do I change the code on the fan.
You need to remove the faceplate that covers the remote sensor on the fan - this is likely to be at the very top, closest to the ceiling. You should find a small 'box' that will probably have two or three switches that can be placed in one of two positions. For example 000, 100, 010, 011 etc. Just change one of the switches to another position and that will then be a different code to the one set on your remote.
If you want to operate the fan that you have just change you will need another remote wit the same code that you have just set.
Jan 22, 2011 | Hunter (25417) Ceiling Fan
Need instruction page for the Hunter light/fan remote control
There is a battery in the hand held remote and another battery in the receiver which gets tucked into the ceiling mount cover. Remove the ceiling cover and you will see the battery there, usually a 12 volt battery.
The upp/down slide is a dimmer.
In the event that changing the batteries doesn't solve your problems, Hunter makes replacement remote sets, available at Home Depot, lowes, etc and usually around twenty dollars.
May 31, 2009 | Hunter Ceiling Fan Remote Transmitter...
Airtech ceiling fan with remote, unit in fan not responding
Replace the globe with a LED that will last longer
Nov 20, 2017 | Dryers
Heating & Cooling Logo
152 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
