Question about Samsung Refrigerators
How long after i installed my side by side can i switch it on?
  • 438 Answers
Daryl,
You can switch it on immediately. Its getting late. Do it now and enjoy the benefits that much earlier.
There are no pre-power-on processes. Once plugged in it is ready to be used. But do give it enough time to cool the contents.
Posted on Apr 11, 2011
Passenger window wont roll down with either switch but motor is good and getting power
New switch for the passenger side. The drivers side switch may be wired through the passengers side switch witch will make it not work if the passengers side switch is bad. Just a thought. Hope this helps.
Nov 10, 2013 | 2005 Chevrolet TrailBlazer
Fan was installed but only one side of the wall switch works giving power
confirm from contractor otherwise replace with normal on/ off switch.
Oct 05, 2013 | Dryers
Passenger window is half way up installed new switch still not working does not appear to be off track
Problem could be broken wires running between pillar post and door. First check the wires on passengers side by pulling back the rubber covering that covers the wires between pillar and door. If the wires are okay on the passengers side check the drivers side wires because they all feed through the master switch.
Feb 27, 2013 | 2005 Chevrolet Cavalier Coupe
Hi, i have 1991 mazda protege. I accidentally broke my key in the ignition lock and now i was wondering how do you take off the ignition lock cylinder? p.s key was pretty worn down already
Ignition Switch/Lock Cylinder REMOVAL AND INSTALLATION CAUTION
Some models covered by this manual may be equipped with a Supplemental Restraint System (SRS), which uses an air bag. Whenever working near any of the SRS components, such as the impact sensors, the air bag module, steering column and instrument panel, disable the SRS, as described in Section 6. The ignition lock is an integral component of the steering lock mechanism. If the ignition lock must be replaced, perform the following procedure. Fig. 1: Exploded view of the ignition switch/lock cylinder assembly 89548g14.gif
Fig. 2: Remove the break-off head retaining bolts by chiseling a slot in the bolt, then removing them with a screwdriver 89548g15.gif
Millenia
  1. Disconnect the negative battery cable.
  2. Properly disarm the air bag system.
  3. Remove the rear console box, brake boot and center panel (disconnect the harness connectors).
  4. Remove the rear console.
  5. Remove the undercover, glove compartment and compartment cover.
  6. Remove the upper and lower steering column covers.
  7. Tilt the steering shaft down. Remove the cap and panel light control switch. Remove the meter hood mounting screws. Pull the meter hood forward to disengage the clips.
  8. Remove the instrument cluster,
  9. Remove the drivers side air bag and the steering wheel.
  10. Remove the combination switch.
  11. Remove the passenger side air bag mounting bolts, electrical connector and remove the air bag module.
  12. Remove the hood panel release lever. Pull the side panel forward to disengage the clips, remove the side panel.
  13. Remove the side covers.
  14. Remove the dashboard mounting bolts, pull the dashboard up and forward and remove.
  15. Remove the steering shaft.
  16. Remove the screw and the ignition switch and disconnect the ignition switch connector.
  17. Using a chisel and a hammer make a groove in the heads of the steering lock mounting bolts. Remove the bolts and the steering lock assembly. To install:
  18. Install the steering lock mechanism to the steering column jacket. Make sure that the lock operates correctly. Install new mounting bolts and tighten the bolts till the heads break off.
  19. Reconnect the ignition switch connector to the ignition switch and install the ignition switch to the steering lock mechanism with the screw.
  20. Replace the dashboard close to its mounts and connect all harness connectors. Install all mounting bolts. Torque to 14-18 ft. lbs. (19-25 Nm).
  21. Install the side covers.
  22. Instal the side panels.
  23. Install the steering shaft and torque the mounting bolts to 12-16 ft. lbs. (16-22 Nm).
  24. Connect the passenger side air bag module electrical connector and replace the module to the dash and install the mounting bolts.
  25. Install the combination switch on the steering column.
  26. Install the steering wheel and drivers side air bag module.
  27. Install the instrument cluster.
  28. Install the meter hood.
  29. Install the upper and lower steering column covers.
  30. Install the glove compartment cover, compartment and the undercover.
  31. Install the rear console, bracket, center panel, brake lever boot and the rear console box.
  32. Reconnect the negative battery cable,
  33. Place the steering column securely on a workbench. Use a chisel and hammer to make slots in the head of the lock screws. Remove the screws.
Except Millenia
  2. If equipped, disarm and remove the air bag.
  3. Remove the steering wheel and the combination switch.
  4. Remove the steering column by performing the following:
    1. Remove the driver's side under dash covers.
    2. If equipped, disconnect the key interlock cable from the steering column.
    3. Detach any remaining electrical wire harness connectors from the column.
    4. Remove the upper column-to-dash mounting bolts. Support the steering column.
    5. Remove the intermediate shaft-to-steering column shaft coupling bolt and remove the steering column-to-firewall bracket bolts/nuts.
    6. Remove the steering column from the vehicle.
  5. Place the steering column securely on a workbench. Use a chisel and hammer to make slots in the head of the lock screws. Remove the screws.
  6. Remove the ignition lock assembly. To install:
  7. Position the ignition lock and bracket on the steering column.
  8. Install the new screws until the head twists off. Make sure the lock operates properly while tightening the new locking screws.
  9. The remainder of the installation is the reverse of the removal procedure.
Feb 12, 2011 | 1993 Mazda Protege
I'm installing a garbage disposal. I've got everything done and I'm installing the switch. When I got the switch installed and tried to turn it on it tripped the breaker. When I bypass the switch it works...
When you are wireing switch are you hooking black wire on incoming side of switch then out going black wire on leaving side,with white wire wire nutted together in switch box. If not try it that way and it should work. Hope this helps you.Thanks
Nov 12, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Installing a combination switch
The three way will have more connections, whereas the Single Pole, should only have a few contacts the three way will have more.
May 27, 2010 | Leviton 002-1754-W Dual Rocker Switches
How do I replace the headlight switch?
Check this procedure for Ciera and Cruiser...
  2. Remove the left side instrument panel trim pad.
  3. Unbolt the switch from the instrument panel.
  4. Pull the switch rearward and remove it.
To install:
  1. Install the switch and engage the electrical connectors.
  2. Install the bolts attaching the switch to the instrument panel.
  3. Install the left side instrument panel trim pad.
  4. Connect the negative battery cable. Tighten the cable bolt to 11 ft. lbs. (15 Nm).
  5. Reset the radio, clock and any other applicable electronic devices.
Hope helped (remember comment and rated this).
Apr 24, 2010 | 1994 Oldsmobile Cutlass Ciera
2003 Lincoln Town Car - Power window switch removal/installation
SECTION 501-05: Interior Trim and Ornamentation 2003 Town Car Workshop Manual REMOVAL AND INSTALLATION Procedure revision date: 01/28/2002 Front Door Trim Panel adobe.gif Printable View (206 KB) Removal and Installation
NOTE: LH side shown, RH side similar.
  1. Disconnect the battery ground cable. For additional information, refer to Section 414-01.
  1. Remove the window switch plate.
  1. Disconnect the electrical connectors.
  1. ani_caut.gif CAUTION: Use care not to damage the trim panel covers.
    Open the screw covers.
  1. Remove the screws and the assist handle.
  1. Remove screws and the front door trim.
  1. To install, reverse the removal procedure.
2010&c18=modelyear&c20=n306887&c35=wsm%2cfront%20door%20trim%20panel%2cs3g%2c501-05%2cremoval%20and%20installation&s=1600x900&c=32&j=1.3&v=y&k=y&bw=1171&bh=582&ct=modem&hp=n&[aqe]
Apr 02, 2010 | 2003 Lincoln Town Car
The turn on lights does not flash
Check out this recall below:
Bulletin No.: 04098A
SPECIAL POLICY
Subject:
04098 - Special Policy Adjustment - Turn Signal/Hazard Warning Flashers
Condition
Some customers of 1999-2002 Chevrolet Malibu, Oldsmobile Alero, Pontiac Grand Am, and 1999 Oldsmobile Cutlass may have turn signal/hazard flashers that become inoperative.
This special policy covers the condition described above for a period of 10 years or 150,000 miles (240,000 km), whichever occurs first, from the date the vehicle was originally placed in service, regardless of ownership. The repairs will be made at no charge to the customer.
Good luck and hope this helps:
HAZARD WARNING SWITCH REPLACEMENT - ON VEHICLE
REMOVAL PROCEDURE
Remove the center air louver deflector. Refer to Air Deflector Louver Replacement - Center Vent.
Remove the instrument panel cluster.
Remove the hazard warning switch bezel from the instrument panel using a small-flat bladed tool to release the retainers.
Remove the left side bolt from the hazard warning switch through the instrument panel cluster pocket Remove the right side and center lower bolts from the hazard warning switch through the center air louver deflector pocket.
Reposition the hazard warning switch from the instrument panel to access the electrical connector.
Disconnect the electrical connectors from the hazard warning switch.
Remove the hazard warning switch from instrument panel.
INSTALLATION PROCEDURE
Connect the electrical connectors to the hazard warning switch.
Position the hazard warning switch to the mounting points in the instrument panel. NOTE: Refer to Fastener Notice in Service Precautions.
Install the left side bolt to the hazard warning switch through the instrument panel cluster pocket. Tighten Tighten the left side hazard warning switch bolt to 3 N.m (27 lb in) .
Install the right side and center lower bolts to the hazard warning switch through the center air louver deflector pocket. Tighten Tighten the left side hazard warning switch bolt to 3 N.m (27 lb in) .
Install the hazard warning switch bezel to the instrument panel pressing into place until fully seated. Install the instrument panel cluster.
Install the center air louver deflector. Refer to Air Deflector Louver Replacement - Center Vent.
May 24, 2009 | 2000 Oldsmobile Alero
96 ford windstar ignition probs
the ignition switch is the electrical part behind the lock cylinder where the key goes in.
Ignition Switch Lock Cylinder
Lock Cylinder Functional
Removal
  1. The following procedure applies to vehicles that have a functional ignition switch lock cylinder (11582) and keys. If the key numbers are known, the correct key can be made. Disconnect the battery ground cable (14301). For additional information, refer to Section 14-01 .
  1. Turn the ignition switch lock cylinder to the RUN position.
  1. Place a 3.17-mm (1/8-inch) diameter wire pin or small drift punch in the hole in the steering column shroud under the ignition switch lock cylinder. Depress the retaining pin while pulling out on the ignition switch lock cylinder to remove it from the housing of the steering column.
Installation
  1. Install the ignition switch lock cylinder by turning it to the RUN position and depressing the retaining pin. Insert the ignition switch lock cylinder into the steering column housing. Make sure the ignition switch lock cylinder is fully seated and aligned in the interlocking washer before turning the key to the OFF position. This will permit the retaining pin of the ignition switch lock cylinder to extend into the hole of the steering column.
  1. Using the key, rotate the ignition switch lock cylinder to make sure of correct mechanical operation in all positions.
  1. Connect the battery ground cable.
Ignition Switch Removal
  1. Disconnect battery ground cable (14301). Refer to Section 14-01 .
  1. Remove the upper steering column shroud (3530) by removing the four or five self-tapping screws. Remove key release lever (3F527) (if equipped).
  1. Remove lower steering column shroud.
  1. Disconnect the ignition switch electrical connector.
  1. Rotate ignition switch lock cylinder (11582) to the RUN position.
  1. Remove the two screws retaining ignition switch (11572).
  1. Disengage the ignition switch from the actuator.
Item Part Number Description 1 11572 Ignition Switch 2 — Ignition Switch Lock Cylinder Housing 3 — Slot in Lock/Column Assembly A — (Part of 11572) Pin B — Alignment Mark
Installation
NOTE: A new replacement ignition switch assembly will be set in the RUN position as received.
  1. Adjust the ignition switch by sliding the carrier to the ignition switch RUN position.
  1. Check to make sure that the ignition switch lock cylinder is in the RUN position. The RUN position is achieved by rotating the ignition switch lock cylinder approximately 90 degrees from the LOCK position.
  1. Install the ignition switch into the actuator. It may be necessary to move the ignition switch slightly back and forth to align the ignition switch mounting holes with the lock cylinder housing threaded holes.
  1. Install retaining screws. Tighten to 5.6-7.9 Nm (50-69 lb-in).
  1. Connect electrical connector to ignition switch.
  1. Connect battery ground cable. Refer to Section 14-01 .
  1. Check ignition switch for proper function, including START and ACC positions. Also, make certain that the column is in the LOCK position.
  1. Install upper steering column shroud.
  1. Install the lower steering column shroud and key release lever (if equipped).
Feb 27, 2009 | 1996 Ford Windstar
Refrigerators Logo
116 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
