Question about Kitchen Ranges
We are looking for a Martin Fireplace Installation Manual. It was installed during construction of our home in 2003 and we never received the manual from the builder. The burner needs to be replaced now and we have discovered that the company is out of business. We are in need of the manual or a parts listing for Model Number DV4500MH Serial No. AA-03-024364. It is a vented indoor gas fireplace. Any help to locate a manual would be greatly appreciated. We live in Onsted, MI zip code 49265. Thanks in advance.
catriver
  • 878 Answers
SOURCE: STOVE TOP CONTINUOSLY SPARKS
Thrasher, Sorry I cant help with the diagram but one of your burner switches is grounding out. Each burner valve has a switch and one of them is finding it's way to ground, therefor the contstant clicking. Good luck on this deal...Catriver..post back.
Posted on Sep 07, 2006
SOURCE: 2001-2002 GE Spectra XL44 Gas Range Parts search
it is your lucky day.....I have 4 grates/burners in gray .....make an offer before I put them on Ebay.
Posted on May 23, 2008
eagle338
  • 4889 Answers
SOURCE: Fireplace Fan Replacement
Well a blower replacement requires some knowledge of electricals. i have found a manual showing the blower replacement. Its not the same model as yours but i think it will be helpful.
12.153.20.72/tech/manuals/108321-01A.pdf
Posted on Jul 11, 2008
aborcass
  • 2651 Answers
SOURCE: trying to find model number of an old Magic chef gas oven
depending on age, sometimes on back, or even under the main top if it lifts up, sounds as uf you would need to replace the door hinges
Posted on Nov 25, 2008
SOURCE: Need Help
I have a 14 year old GTI fireplace the pilot is lite but when i push the button to turn it on , the fire place does not come on help please
Posted on Dec 14, 2009
Martin DV4500MH fireplace manual.
Try going to manualsbrain.com I seen that they had Martin fireplace manuals just not sure if i had the correct model from you.
Jan 08, 2018 | Heating & Cooling
Looking for a picture diagram of a Bm36Hc fireplace
[PDF]deluxe 36 manufactured home fireplaces - Hansen Wholesale
www.hansenwholesale.com/images/fireplaces/.../Intertherm_BM36HCII.pdf
36" Wood Burning Fireplaces. P/N 800,019M REV. B 04/2002. BM36HC. BM36HCD..... Refer to the minimum system height chart. WARNING: DO NOT PACK ...Missing: picture
Intertherm BM36HC Installation Instructions Manual
www.manualslib.com > ... > Indoor Fireplace > BM36HC
View and Download Intertherm BM36HC installation instructions manual online. DELUXE 36. BM36HC Indoor Fireplace pdf manual download.
Dec 20, 2015 | Heating & Cooling
Can I burn wood in my Martin Industries Gas log fireplace model number DBB36?
probably not as the unit is not constructed for wood fires
read you operators manual
Nov 28, 2015 | Home
Ambient remote control 5884 won't turn fireplace on and off
  • Make sure your valve is in the "on" position and not "pilot".
  • Install fresh batteries in both remote and receiver (remotes are finicky about good batteries.
  • Ensure the switch on your receiver is in the "remote" position.
  • Follow manual to re-sync handheld to receiver if necessary.
  • A burner not lighting could also be the fault of the appliance (bad thermopile). Check this too, and replace if needed.
  • Replace remote if necessary: Universal Fireplace Remotes
Dec 28, 2012 | Ambient Tech. Rcmt Manual Fireplace Remote...
Owners manual heat-n-glo smart-stat
Try searching through this:
http://www.heatnglo.com/Resources/Customer-Care/Installation-Manuals.aspx
Nov 11, 2012 | Skytech Smart Stat Fireplace Remote for...
Receiver was beeping... Jiggled it ... Stopped beeping... Now not working ...tried to reset transmitter with receiver but will not work .... Did replace batteries and recharged receiver as well ... Remote...
There's no quick answer to your problem, as it may be your gas fireplace that's causing the problem. If you still have your Owners Installation Manual look at page # 7 (Trouble Shooting), this should help you solve your problem. If you don't have your Owners Manual, you can download it online from SkyTech's website. If all else fails contact SkyTech's Technical Service Dept @ 888-672-8929
They are friendly and knowledgeable folks to work with.
Jan 11, 2011 | Skytech 3301-BE Gray Five Button...
How do we install a burner on a fireplace?
Thinking of adding a fireplace or wood stove to your home? If so, proper installation and maintenance is absolutely critical to ensuring the fire stays inside your freestanding fireplace or wood stove and doesn't venture outside of it.
If your manufactured home already has a fireplace or wood stove, it's a good idea to go look over these safety guidelines to confirm that it was installed correctly. If you plan to install a fireplace or wood stove, follow these safety guidelines carefully.
First, don't try to tackle this project yourself. While installation manuals usually provide all the instructions necessary for a manufactured home owner to install a wood-burning fireplace or wood stove, the consequences of a mistake are so disastrous, it's a task best left to experts.
It's a good idea to first check with your insurance company for their guidelines before installing these items. Your insurance policy may not cover damages if a fireplace or wood stove was not professionally installed. Plus, the manufacturer's warranty on the fireplace or wood stove may not apply unless the unit is installed by a professional.
Also can check this ARTICLE for other details.
Hope helps.
Jun 02, 2010 | Heating & Cooling
I am looking for an installation manual for Model FUBSK blower motor kit. We bought a new home and the Lennox Superior wood burning fireplace Model BC-36 has a switch that should force heat out into the...
The fan should be installed behind the bottom grill, and then it should blow air around the firebox which then exits out the top grill. Now saying that, let me explain the actual problem you will face. Because you have a open faced wood fireplace, you will not get the heat your looking for, the fire needs 400 cubic feet of air per hour and that air is taken from your opening. Also the inner box doesn't heat up enuff to produce alot of heat on the skin so if you have the fan blowing full blast, it will only cycle the air and not allow it time to heat up as it cycles around the box. I suggest turning the fan speed down so its 1/2 way on or lower, this allows the air time to heat while cycling around the box, but in the end you still won't have a good heater as the fireplace itself isn't one, you should look at having it converted to direct vent gas or ripping it out and replacing it with a airtight wood.
Jan 03, 2010 | Superior Lennox Blower Thermal Sensor -...
Kitchen Ranges Logo
82 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
