Question about Minolta EP1083 CS/PRO Copier
C0200 on develop - Minolta EP1083 CS/PRO Copier
  • Minolta Master
  • 6,161 Answers
Below the drum is an assy. that houses two very fine gold plated wires that do two things since the paper goes between these two wires and the drum the first wire transfers the image on to the paper from the drum, the second one prevent the paper from sticking to the drum. One is or both are bad, BROKEN? Remove the assy. and replace both. They are very fine and fragile do not lose the springs. If that does not work you might have bad ends on the assy. after a while the plastic breakdowns and allow the voltage to go to ground. The wire carry around 2000 volts during the copy process. None during power off :) Open close the front door resets the code.
web site for parts
try below Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Posted on Feb 22, 2015
How to remove error C0200 on bizhub c350?
C0200 - Cyan PC Drum Charge Corona Malfunction. Did you mess with this imaging unit? You won't be able to reset if the malfunction is still present.
Konica Minolta Error Codes & Solutions - http://www.kmcodes.com
Drum, Transfer Belt and Fusing Unit Firmware Reset - http://www.bizhubreset.com
Drum and Toner Chip Reset - http://www.chipreset.eu
Transfer Belt and Fusing Unit Reset Kit - http://www.resetkit.eu
Aug 15, 2014 | Konica Minolta Office Equipment & Supplies
How to remove error C0200 on Minolta bizhub c350?
Error code c0200 minolta EP 4000
Sir, right below the drum area when you open the machine front door is a assy. with two very fragile gold plated wires that transfer the image from the drum to the paper. The paper moves over this wires during the copy process. They mite have broken giving you a C0200. Or the same type of wires are above the drum on the drum unit which must be removed to see them mite be bad. did you open close the front door to see if the machine will reset?
Jun 25, 2014 | Minolta EP4000/5000 CS/PRO Copier
Error code c0200
The error code C0200 deals with the transfer or separation charge corona wires. I would replace the two wires and see what happens. The code can not be rest till the problem is fixed. Good Luck
Nov 08, 2013 | Minolta EP4000/5000 CS/PRO Copier
I see this message on the screen. A malfunction was detected. please call technical Rep code: C0200 what should i do if i don't want to call?
Code C0200
Description
PC Drum Charge, Image Transfer, Paper Separator Corona malfunction
Detection Timing
The leak signal (SCD) turns ON after the PC
Drum Charge and Image Transfer/Paper Separator
Corona output has been turned ON.
Try this:
C0200: Corona Malfunctions
Relevant Electrical Parts
  • High Voltage Unit HV1
  • Master Board PWB-A
Jul 06, 2011 | Minolta EP4000/5000 CS/PRO Copier
C0200
Corona wires are used in the transfer/sep assy and drum charge. C0200 is code if they fault. To reset the machine open and close the front door, if ithe code comes back the corona wires and or assy need replacement
Feb 19, 2010 | Konica Minolta DiALTA CF910 Copier
C0200
Where do i find Carona in minolta machine?
Aug 06, 2008 | Minolta EP1083 CS/PRO Copier
Malfunction code C0200
A C0200 is a Charge Corona problem and it is a Minolta error code.
Jan 23, 2008 | Office Equipment & Supplies
How to fix
It's a corona error, C200
First unplug the main charge corona take up motor as it may break the corona wire. next the wire is very thin and tends to oscilate out of control and cause the C0200 code. If a new wire spool, or grid doesn't alleviate this problem simply use electrical tape on the inside housing of the main charge corona assembly.
C200
There is a new part # for the charge corona. The old style has a problem with the wire cutting the block and breaking. The new ones have a brass post to prevent this. part# 1139-0313-01.
Nov 19, 2007 | Office Equipment & Supplies
49 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
