Question about Karcher K2.26 Electric Power Washer
No power when switched on new switch fitted - Karcher K2.26 Electric Power Washer
  • 92 Answers
Dear Sir,
The power washer stops when the gun is closed. This happens because pressure is exerted on a control valve (Spill Valve)...which in turn touches a micro switch and cuts electricity. Now most probably your machine is dead because the spill valve is stuck down and closing the micro switch. This happens when one stores away the machine with pressure still in it. NEVER store a power washer with pressure in it. The spill valve also gets gammed because left with soap and machine not rinsed. I rarely service spill valves...I change with a new one.
To locate the spill valve open cover (using a TORX T15screw driver)...and where you see 2 wires coming out...there is the spill valve. If you can manage to do this..you can try if you want to lubricate it by spraying SILICON spray. If you get it out..you use silicon grease.
Sometimes these machines have the spill valve incoporated with the head....in that case the whole head must be renewed.
Regards,
Fulltech.
Posted on Apr 24, 2011
  • Martin Grech Apr 24, 2011
    Please note that I am not responsible, for any misuse, misinterpretation, damage caused to inexperience work, incompetent workmanship and damage or harm caused by irresponsible use of this advice. This is just advice and cannot be held responsible for work being done when myself I am not present.
    Fullteh.
How to replace the switch on a delta shopmaster
Sorry I can't give you a definite answer but most power tools of this type have long been fitted with a safety switch which tends to be much bigger than it appears from the outside of the casing requiring the switch to be removed from the inside. If your new switch is identical to the original close examination should provide a few clues to the removal procedure.
Domestic and semi-professional semi-portable machinery is often of a generic far-eastern manufacture and such spare parts as are available for this type of machine tend to be generic parts and the design changes over time so the new switch might not be identical to the original so some adaption might be needed to fit the new switch.
Older and/or heavier type shop machines often have a switch that is also a motor starting switch. This type of switch generally contains a thermal breaker to protect the motor and must be adjusted to suit the motor current before fitting. This type of switch is considerably larger than the previous type.
Old semi-portable type machines do not usually have a safety switch but fitting one would be a very sensible upgrade.
Mar 13, 2016 | Delta Saws
I have power steering fluid leaking from the sensor's plug-in to the power steering pump. Where the 2 wires connect into the housing. Is it the pressure sensor? If so, how do I fix it?
TO REPLACE THE POWER STEERING PRESSURE SWITCH.REMOVE SIPHON OUT POWER STEERING FLUID BELOW THE PRESSURE SWITCH.UNSCREW THE OLD PRESSURE SWITCH AND SCREW IN THE NEW POWER STEERING PRESSURE SWITCH.MAKE PRESSURE SWITCH HAS THREAD SEALER ON IT.IF NEW PRESSURE SWITCH THREADS ALREADY HAVE SEALER ON THE THREAD DONT NEED TO USE TEFLON TAPE TO SEAL THE THREADS.BLEED POWER STEERING SYSTEM.
May 09, 2011 | 2001 Ford Escape
Case switch connected to motherboard is messed up. i need a new switch for the case or the configuration for the pins on the motherboard to be able to use a new case/new switch
The Power On switch is located inside the plastic Power On button assembly.
It is a Momentary Contact Switch, and is named an ATX power on switch.
This ATX Power On switch I have found fits many computers,
http://www.directron.com/atxswitch.html
The plastic front panel of a desktop computer is the Front Panel.
The pin area on the motherboard, that the cables (Wires) from the Front Panel connect to, is the Front Panel header.
Tell me the manufacturer name, and Model Number of the computer, or tell me the manufacturer name, and Model Number of the motherboard, and let me see if I can find a Pinout for it's Front Panel header.
(What pins the cables connect to)
Post in a Comment.
Nov 12, 2010 | Computers & Internet
The power button is broken
We used this monitor for two years with no problems then we also experienced the same power problem. Using my electronics background I was able the verify that the problem was with the actual power switch. I ordered a replacement switch and installed it. The monitor now works like new again. The switch is available via online electronic suppliers. The part number I used was a TL2285EE made by E-SWITCH. I found that it is actually a little bigger then the original and believe that the original switch is actually a TL2230EE. The bigger switch fit with a little persuading and should last a little longer but the 2230 would fit much better. This job is not to hard for someone with some soldering experience.
Good Luck...We love our monitor again (we own two)
Apr 20, 2010 | Summer Infant 02580 Color Flat Screen...
How do i replace a pull cord with light switch
Ok so, L (line) N (Neutral) and E (Earth ground), and no idea what this rose is. I suppose you mean Junction Box when you say JB. You can use the original junction box for the wall switch connector, but the Black and white wires coming from the switch must be disconnected from power to be used, if power is already present in your light's original junction box (which is usually the case when using a pull switch light). Then you connect the white and black wires to your wall switch and use them to break the circuit at the light itself by wiring it between the light and the power lead.
Mar 24, 2010 | Plumbing
Im fitting a new light fitting i have 3 cables from the ceiling the orginal power cable , the switch cable and another cable to feed another light in my light fitting i have live neutral and loop what...
The grounds go together and perhaps to the fixture.
The white/ neutrals are also all tied together and one goes to the light. Note that one neutral may not actually be that, but is simply one of the pair of wires going down to the switch.
Then you need power connected to one leg going down to the switch (maybe a white one) and the return leg from the switch goes to the light.
Hope this helps. Let me know if not
Nov 06, 2009 | Hardware & Accessories
On/off switch on new tub install stuck in the on position; pushed until it turned off, but now it won't turn on
Order a new switch from the manufacturer, cut of the main power from the circuit box, and remove the old switch.
The new one should fit right in and the wires clip on.
Apr 27, 2009 | Whirlpool Hydrosystems 72 X 36 Biscuit ...
How to fit the power switch
you have to (obviously) open it up and solder in a new one. I've done it, but it's not trivial. I have lots of experience soldering and it went well, but I would not anticipate that someone without lots of time spent with a soldering iron will be able to do it without burning or lifting traces off the circuit board. The switch is available from many places. I bought mine here: http://www.powergamingparts.com/nintendo-ds-and-nds-lite-on--off-power-switch.html
Apr 04, 2008 | Nintendo DS Console
Power up problem
the power switch of your fone is grounded.replace a new one.
Feb 21, 2008 | Samsung SGH-E900 Cellular Phone
Power Switch for this PC?
I've read your question & am still confused about which switch you need. I'm guessing that it's the power switch on your case that is broke? If so you can go to just about any auto parts store & buy a push-button two wire off/on switch. Even in a Low's store. It may or may not fit just perfactly on your case but it's better then turning the power off with a pen directly off the motherboard. Been down the road your on. It's either this or buy another case. You will not find your case a new switch. You can use your case's wiring connector to plug into the board listed on pg. 1-18 in your manual. It's two pins. You can splice the two pin connector from your case to a new switch's wires. As far as connectors go. You can buy a small pack of single connectors for a computer from radio shack to connect to the boards (power) ATX power switch. All the parts shouldn't cost you more than $10.00. Cheeper than a new case!
Feb 15, 2008 | ASUS A7V333-X (A7V333-X/L) Motherboard
Karcher K2.26 Electric Power Washer Logo
168 people viewed this question
Top Karcher Garden Experts
John Trevino
andy just round the...
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
