Question about Toro Garden
Toro 1642z riding mower/briggs & Stratton..new battery and plug..suddenly stopped starting ...turn key get only one loud click and then nothing
  • 57 Answers
SOURCE: Need linkage hookup diagram for Toro Super
Go to TORO.com and view parts for your model.
Posted on May 19, 2009
  • 583 Answers
SOURCE: Briggs & Stratton Briggs Stratton Intek V -
these are common for doing this ,if you dont want to pull it down and hone the cyl. then i would use a heavier oil say 20w/50and that will probabley solve your problem
Posted on Oct 25, 2009
SOURCE: Troy-Bilt Briggs & Stratton 550 restarting
Troy, Unless you are using old fuel (it breaks down after 1 week) it sounds like you have a faulty spark plug. Replace this first, drain any old fuel and replace with fresh fuel (premium unleaded). A faulty plug will work one minute but then fail like you have described.
SOURCE: rally ride on lawn mower not starting. briggs and
i have a rally lawn tractor when i hook up the battery it wants to start key is off only thing i did was change the belt. was working fine before .
Posted on Jul 29, 2010
  • 2239 Answers
SOURCE: Briggs & Stratton R mower/14.5 hp. Starter engages. Engine stops on compression. Has new starter & battery. Cabels are good. Sometimes it will start & run.
Incorrect valve tappet clearances, this will stop the auto deco valve in the engine working.
Posted on Apr 14, 2012
Bolens 42 in riding mower with briggs and stratton
Check the battery and battery lead terminals are clean (wire brush or a scotchbrite) and tight.
Still not working: - then check the battery lead connections to earth (chassis), starter solenoid and starter motor.
Feb 05, 2014 | Briggs & Stratton Garden
I have a riding yard machine mower. Had trouble starting without jumping the battery. Bought a new battery & it started right up. Mowed the front & side of the yard & shut it off to open my...
Now you are describing 2 different problems... If you have nothing I doubt the battery is dead but would check for a safety switch problem. If it clicks or turns over slowly then we need to be looking at a bad connection or other issues... Please describe your problem better to let us help you solve it
Nov 13, 2013 | Yard Machines 155 Torque Briggs Stratton...
Scotts by john deere riding mower - 220 hours, 17.5 HP, 42" cut, Briggs & stratton engine -- New Strarter, new battery, good fuel... will turn over but engine will slow down then stop, will not...
Very high likelihood you have fuel line problems. Disconnect primary fuel line from bottom of fuel filter and blow compressed air back up the fuel line to the gas tank. This will clear the line of any trash. Reconnect fuel line to filter. Then remove spark plug and spray a couple of sprays of WD-40 into the cylinder.. Re-install spark plug and then restart. WD-4- will act as a starter fuel and will start the engine for enough rounds to get fuel pump to working to normal run.. Good luck.
May 15, 2011 | Briggs & Stratton Garden
Have a Yard Machine riding mower with 21hp Briggs Stratton engine OHV/IC V-Twin. when I turn on key nothing happens. How many switches control the start motor from the ignition and where are they located....
It depends on the model but most riders have the following;
1. Seat switch
2. Brake pedal switch
3. PTO switch
4. Neutral switch (if its a shift model)
All need to be closed in order to start engine.
Jun 03, 2010 | Briggs & Stratton Briggs Stratton Intek V...
PLEASE HELP! My husband is driving me crazy about Riding Mower
Sounds like the gear on top of the starter is stuck or broken. Inspect starter. If it's broken, the starter must be removed to replace the starter drive. You may need to buy a Starter Drive Kit. If you starter has a flat piece on top held on by a retaining ring, it's part # 696541. If you have the older type starter with roll pin holding the drive on, you need part # 696540. You probably have the first one. To install the retaining ring, use a 3/8 socket to tap it into the groove. Dwain
Jun 17, 2009 | Briggs & Stratton Garden
Murray Riding Motor Running but not Starting
does it have spark & gas let me know at wadembly@aol.com thanks,wade
Jun 07, 2009 | Garden
Starter energizes, won't turn engine.
your battery is in a weak state also the solenoid is shorting out replace the solenoid
Jun 06, 2009 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Toro ride on mower won't start
Try replacing your spark plug. If that fails then go to the engine, cheak your carb, lines, and gas. cheak for gum in the engine/carb. If gummed then get carb cleaner and spray twice, wait 1 hour then try again. If my solution fails then you might need expert help. Good Luck!
May 23, 2009 | Parks Optical 13.5hp Briggs And Stratton...
Garden Logo
99 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
Mike Squire
Roland W VanLue
Roland W VanLue
Are you a Toro Garden Expert? Answer questions, earn points and help others
