Question about Sharp R-242 Microwave Oven
Sharp 800w microwave. R-242. how do i set clock & timer please ? Is it possible to purchase a insruction for this model ? Thank you.
  • 958 Answers
SOURCE: Sharp Microwave R-206 800W
open the housing, look where the bulb is located, unscrew the holder of the bulb and if the b.ulb is screwed at the holder, replace it. if the bulb is attached to the holder then replace the whole bulb assembly. i hope i was able to answer your problem
Posted on Feb 19, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Clock on Microwave
Normally on a Sharp, one of these key combinations will do it:
CLOCK > 1 > 2 > 3 > CLOCK
CLOCK > 1 > 2 > 3 > START
CLOCK > CLEAR > 1 > 2 > 3 > CLOCK
CLOCK > CLEAR > 1 > 2 > 3 > START
Let us know if this does not work.
Posted on Aug 10, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: sharps microwave
This is usually caused by either a bad door switch, a loose door switch mount, or occasionally a problem on the control panel.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
You can probably find exploded views and order parts by entering your model number (R-520JKF) here at the Sears parts site.
The best place to order Sharp parts is Tritronics.
Posted on Aug 21, 2008
PitVipermd
  • 54 Answers
SOURCE: Don't know how to set clock on it! Still working well, however.
http://www.usersmanualguide.com/sharp/microwave/r-242m
Theres your manual...
click Download
R-242M pdf user manual
Then either click view or download...
Posted on Apr 24, 2009
rhozel2010
  • 269 Answers
SOURCE: Emerson MW9111 will not heat- all timers & clock work
Hi! try checking the fuse that goes to the magnetron.
Posted on Sep 12, 2009
On the r559y sharp microwave,how do i set the clockl
press,timer/clock ,colon will flash ,enter correct time{i.e. 12:34},press clock/timer again,,all set,if it doesnt work,return it to where you bought it,
Jan 01, 2015 | Sharp Microwave Ovens
Sharp microwave 8888 is flashing and I cannot remove
see this steps and fix it. God bless you
Reset the clock. Press "Clock" and the correct time, using the number pads. Press "AM/PM" if applicable, and press "Start" or "Clock" to confirm.
  • 2 Press "Timer On/Off" to reset the timer if nothing on the touch pad will operate. Use the number pads to select a new timed amount, if desired, and press "Timer On/Off" to start. Press again to cancel.
  • 3 Press and hold "Clear/Off" for three seconds if the timer will not function or is blinking when you touch the pads. This will release the "Child Lock" feature. Make a new touch pad selection.
  • 4 Disconnect power to the microwave if following Steps 1 through 3 does not resolve the blinking timer. Wait a few minutes, and then restore power to reset the microwave.
  • However if the problem persist the display board
    main control board is faulty
    Oct 02, 2012 | Sharp Microwave Ovens
    I need to change the time on my microwave....and it will not work.
    Hi Melissa. Push the clock button then set the correct time AND then push the clock button a second time. THIS is such a common problem, and so easy to forget!
    Joe
    4 thumbs up please. ty.
    Nov 08, 2010 | Sharp R-242 Microwave Oven
    How to set the clock on my sharp carousel microwave
    Touch STOP/CLEAR pad.
    Touch TIMER/CLOCK pad.
    Enter the correct time of day by touching the numbers above in sequence.
    (for example: for 12:30, touch 1 2 3 0)
    Touch TIMER/CLOCK pad again.
    Sep 25, 2009 | Sharp Microwave Ovens
    How to set clock on sharp microwave
    normally you look for the clock ot watch icon. Pressing it once will give you the option for 24 hours setting. Press it twice and it will give you the opportunity to set to 12 hours setting. Using the no. keypad, punch in the time and then repress the clock icon again.
    Sep 21, 2009 | Sharp R-1480 Microwave Oven
    click Download
    Apr 24, 2009 | Sharp R-242 Microwave Oven
    No numbered touch pad for use setting clock
    I think on this one you press the CLOCK/TIMER pad, then enter the desired time using the 10 MINUTES, 1 MINUTE, AND 15 SECONDS pads then press CLOCK/TIMER again.
    If that doesn;t work, press STOP / CLEAR then try the above again.
    Let us know if it does not work.
    Mar 05, 2009 | Sharp Microwave Ovens
    Sharp Carousel Microwave Model R520-LK timer will run but carousel doesn't turn and food doesn't heat.
    I also have the Sharp Carosoul oven, symptoms - fan runs, controls are fine but the turntable stopped turning and it did not heat. It was not the switches, fuse, but in fact a sagging door that misaligned with the door switches. The true cause was a warn top hinge. As a temporary fix, I adjusted the bottom hinge (3 screws underneath), straightened the door, and now it works again.
    Dec 16, 2008 | Sharp Microwave Ovens
    Sharp R-242 Microwave Oven Logo
    70 people viewed this question
    Top Sharp Microwave Ovens Experts
    William Miller
    William Miller
    Devabhakthuni...
    Devabhakthuni...
    Ed Mac
    Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
