My Olivetti Underwood Lettera 22 Line Space and Carriage Return Lever has torn loose at the point where the device should be attached to the cylinder which rotates the platen moving the paper up to the next typing line. It seems that I could reattach the plate that rotates tbhe cylinder by drilling a hole into which I would then drive a screw rejoining the two. Or must i remove and replace the whole assembly, supposing the parts are available? What do you recommend? John Alberts
  • 635 Answers
You have a classic 1950's collectors item.I don't think you would get spare parts of this classic equipment nor service support from the parent company .
I would advice you not to remove the cradle unless you have clock repairing skills.At the end you might be left with a few springs and levers !!.
You could go ahead with the idea of using a small drill bit and and putting a small screw to hold the broken parts together. Best would be to push the cradle all the way out to get access.And instead of using nut and bolt you can buy a 2mm drill bit and threader so you can put in a bolt with out a nut into the thread itself.But remember what ever you do the force involved to push the carriage back and advance the paper to the next line is very high. Do the repair work only if you think this new joint will take the stress or your efforts will be in vain.
But I feel you should fix it at least to restore it to its old glory even if it is not practical and you are the original first hand owner !!!.
Posted on Apr 12, 2011
Olivetti Lettera 32 typwritter carriage doesn't move
If the locking lever is off, then the carriage is bound, or one of the tabs is hung, try releasing all the tabs, pushing the space bar or the tab key while gently moving the carriage.
Try all of the function like shift while gently pushing on the carriage always to the right..
also check the that the margins are not locked.
This could be a lot of different things...
Dec 18, 2009 | Olivetti Lettera 35 L Typewriter
Did anyone answer the problem of unlocking the carriage on the olivetti lettera 22? thankyou
There is a small lever on the right side of the machine under the carriage that is meant to lock the carriage for transport. Press this down.
Nov 08, 2009 | Olivetti Lettera 25 Typewriter
Olivetti Lettera 22 skipping spaces
Thje problem with this machine is that you need to use a fast pecking motion when typing. If you press and linger on the keys for too long this will cause an extra space.
Sep 13, 2009 | Olivetti Lettera 25 Typewriter
Olivetti Lettera 32 typwritter carriage will not move?
There is a lever in front of the right knob that is used to lock the carriage.
Aug 31, 2009 | Olivetti Lettera 35 L Typewriter
Can't find carriage lock on Olivetti Lettera 25
Learn how to unlock the carriage in Olivetti Lettera 22 Manual posted by Ed Cornish (Carriage Locking Lever 7). It is a different machine model, but the lock/unlock mechanism might be the same.
You can see the full manual at Ed’s Flickr account or you can download it from here: http://dl.getdropbox.com/u/1322442/Olivetti%20Lettera%2022%20Manual.pdf (temporary link)
Aug 28, 2009 | Olivetti Lettera 25 Typewriter
Olivetti Lettera 22 - carriage jammed
THERE IS A CARRIAGE LOCK ON THE MACHINE IF I REMEMBER RIGHT IT'S SO THE CARRIAGE DOSENT MOVE WHEN IT IN THE CARRING CASE. LOOK ON THE LEFT AND RIGHT END OF THE CARRIAGE JUST BELOW THE PLATEN KNOBS OR IT MAYBE A LEVER ON THE SIDE OF THE KEYBOARD
Aug 17, 2008 | Olivetti Lettera 25 Typewriter
Lettera 22 - sips and adds spaces on occassion
If it skips at the same place or skips every 10 or 12 spaces all the time it is a broken tooth on the escapement wheel or rack. It could be in typing you are lingering on the key causing it to spring back a little ans space over.
Apr 18, 2008 | Olivetti Lettera 25 Typewriter
Carriage release
try jiggling the carraige around a bit and then try using that lever thats on the right side of the carraige. you might even try both at once to see what frees it up. i had the same problem and it worked for me. That's the right tab, it may be in a jammed position so it wont open properly.
Apr 26, 2007 | Olivetti Lettera 25 Typewriter
How do you unlock a locked carriage?
The solution is not right--there is a carriage return release lever on the far right of the typewriter, that engages a notch on the underside of the roller/carriage return--push it forward to release the lever and you are in business--it has a spoon shaped end and its on the right side
Jan 24, 2006 | Olivetti Lettera 35 L Typewriter
k24674
jasbo
jasbo
