Question about Imation : Apollo Portable USB 2.0, 320GB -:- Sold as 2 Packs of - 1 - / - Total of 2 Each Hard Drive
Its a code 10 error on my imation 320gb apollo hdd will trouble shooting help the problem? and will it also delete information
  • Imation Master
  • 27,725 Answers
if this error is a registry problem
click start control panel administrive tools computer management then select event viewer depending on what operating sytem you have this may vary
extend the events there you will ((see errors in red)) you will no what exactly what the error was and at what time it occured you might be able to uninstall then reinstall some of these files/software or only if you don't need to
also you might download and use this registry cleaner it is totally free to use
http://download.cnet.com/ccleaner/
also you could
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive or
click start control panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
do not do anything while the chkdsk utility is in progress any input may damage your computer
then defragment your hard drive
a code 10 error is a cd/dvd drive error
make sure that the cd rom is getting enough consistent power test all leads that are attached to the cd rom including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd rom then plug them back in this will activate found new hardware wizard
hope this helps or
you might have to uninstall then restart your computer then reinstall your cd rom or uninstall the driver then reinstall for this device
also
click start control panel administrive tools computer management device manager scroll down cd dvd rom drives right click you can you will have options to update driver roll back driver select properties general troubleshoot select driver click to reinstall drivers click update driver uninstall then reinstall
you need only do the registry check if you cant see the drive/s in windows explorer/my computer
it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
Posted on Apr 11, 2011
Imation apollo 2.5 portable HDD 250 GB driver missing?
Just download it from Imation.com. Install it and your on your way.
Feb 16, 2014 | Imation Apollo (27223) 250 GB USB Hard...
Imation Apollo M100
https://www.imation.com/en/consumer/external-hard-drives/ External Hard Drives
Jan 29, 2014 | Imation Apollo UX 2.5" USB Portable (250...
I need to install the driver information to a new computer for the Imation Apollo Pro UX external hard drive
What operating system are you using? There is usually no need for drivers on external HDD. The computer usually recognizes it and installs the necessary software for it.. Let me know if this answers your question and good luck..
Sep 09, 2011 | Imation Apollo UX 2.5" USB Portable (250...
Hi, Brand : Imation Model : Apollo M250 Capacity
Hi, The hard drive Apollo M250 does not have any locking mechanism. It only has backup software. If your computer does not detect the HDD, it only means that the HDD is already broken.
Aug 15, 2011 | Computers & Internet
I need driver for imation apollo external HDD, where could i find free driver for this?
External Hard Drives generally do not need drivers. If the hard drive came with 2 usbs, then plug them both in. Your drive maay require more power to work properly. Again you may need two USB port to power it as 1 single USB does not carry that much power with it.
Jun 25, 2011 | Imation Apollo (27223) 250 GB USB Hard...
Hi.My Imation Apollo 2.5" 500GB
With any luck, it may just be due to a loose cable or connection inside. You need to open the unit and make sure everything is properly connected.
Mar 14, 2011 | Imation Apollo UX 2.5" USB Portable (250...
How to partition in two or three logical parts ?
you can create and delete partitions on a drive using Disk Management, which you can open by right-clicking on My Computer and selecting Manage. Disk Management will be toward the bottom. Just right-click on the USB drive in Disk Management to delete/create partitions on it
Feb 28, 2011 | Imation : Apollo Portable USB 2.0, 320GB...
I have an imation /Apollo 2.5PHDD 160GB and it is not recognised on my computer...how do i reinstall if i dont have the disc etc.what else could be the problem
Hi there.
I have this same HDD and I don't think your problem is related with any "installation" or softwares. It should work just as a plug-n-play hardware, as mine does. Maybe Ooq Affiat's advice would do, by changing the USB cable. Best luck!
Feb 10, 2011 | Imation Apollo UX 2.5" USB Portable (250...
I need an Owners manual for an Imation Apollo UX 2.5" HDD 250 gb
Hello Anaheimflash!
Imation has a User Manual and a Quick Install Guide for the Apollo UX available for download on their website. The link to the download page is Apollo UX
Nov 22, 2010 | Computers & Internet
Imation : Apollo Portable USB 2.0, 320GB -:- Sold as 2 Packs of - 1 - / - Total of 2 Each Hard Drive Logo
450 people viewed this question
Top Imation Computers & Internet Experts
Raj Patel
carey w mason
carey w mason
Jax Planet
Jax Planet
Are you an Imation Computer and Internet Expert? Answer questions, earn points and help others
