I search rubber belt and head for my philips d6350.
    Brigadier General:
  • 3,301 Answers
Http://www.support.philips.com they have a complete line of service products and a help line
Posted on Apr 11, 2011
Philips HTS 6600/12 Home Theatre System HDMI does not open the DVD door.
DVD sledges work by a rubber belt that in your case might have broke or come off. It's very easy to replace. Find the original belt. Measure the diameter in MM (approx) and do a Google search for "Drive belt XX MM".
Get the nearest to your size.
Jan 21, 2016 | Philips HTS 6600/12 Home Theatre...
Model AS655,cd midi system. records are playing ok then go into slow mode then good then slow again. i think i need new belt. do i just go with model no. to replace and i need description on how to access...
Hi Sue
This will almost certainly be a drive belt problem - they get worn and stretched over time- and will best be fixed by replacing the belt. You should be able to find one by searching on-line for Philips AS655 drive belt and including your country in the search criteria.
A temporary fix might be possible by using some 'belt dressing spray' - available from good tool shops. Squirt a little on the inner surface of the belt but take care not to get it on other components as it is rather sticky and messy. This will help the belt to grip the drive pulleys but you will need to keep repeating the treatment from time to time.
I don't know this particular model but with quite a lot of turntables you can get access to the drive belts by taking off the rubber mat on the platter - you may find some little windows you can get at it through with a pair of tweezers.
Otherwise you are going to have to get inside the case somehow. Some turntables have screws around the sides of their base-plate that allow you to separate them from the rest of the unit but be careful the wires are often short and it is easy to break them.
You can purchase a full service manual from here to download in pdf format, which should explain how to do it.
http://www.manuals-in-pdf.com/index.php?main_page=product_info&products_id=127430
Jan 29, 2011 | Philips Audio Players & Recorders
Cassette gets entangled, and does not play well
Cassette tape machines will occasional require maintenance after a certain period of usage. First open the cassette door and remove the tape and any broken tape remaining inside. Some models allow you to remove the cassette door allowing you to have better access to clean the unit. Next you will need to clean the capstan with alcohol and a Q-tip. The capstan is the metal post which the rubber wheel (pinch roller) pushes against to drive the tape across the tape head. Basically clean all the shiny metal parts including the tape head. Some of the tape residue may be difficult to clean, I use Tricloroetilene which has been regulated by the government, but you may try a product called Goof Off to clean the difficult parts, but it could eat the plastic and rubber parts so be careful. Next use a rubber cleaner on the pinch roller so you do not dry the rubber out, or it will become useless. The other problem is the cassette may be driven by a motor and belts. The belts may need to be replaced and the pulleys cleaned. For this you will need to disassemble the unit to access the belts but the cleaning of the pinch roller and capstan may fix your problem, if not you need to open it up to replace the main belt.
Jun 23, 2010 | Philips 3-Disc Changer FW320C Cassette/CD...
Brush will not turn
Assume that the belt is broken to the power brush /head. Did you happen to smell burning rubber or see small pieces of black rubber? Look in your manual for replacing power head/brushes belt! With the unit off , try turning the brushes by hand and clean them off of debris, etc., as well while there. See if you feel some tension or hear the motor moving inside, indication that the belt is still attrached and if it doesn't seem to have any resistance and you see small pieces of rubber and /or, the band/belt may have just broke from normal usage. WalMart sells most types or your local vacuum repair facility.. check the Yellow pages and let your fingers do the walking.. Good luck
Apr 30, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Brush not moving, suction working
This machine is made for Sears by Panasonic. The power head, depending on model has a "gear" / cog belt or a standard flat rubber belt. First turn the power head over and see if the brush roller turns easily, if so you do need a new belt. To access the belt you will have to remove the hood from the power head. There are 4 screws, one at each of the corners to take out. Once the hood is off you will see where the belt goes and find "teeth" in the motor shaft for the motor / brush roller if you need a gear belt. If both of these are flat you need a rubber belt.
You can go to sears.com and find the belt you need with the vacuums model number.
Apr 27, 2010 | Kenmore 22812 Bagged Canister Vacuum
My Generation 3 Kirby Vacuum is giving off a burnt rubber smell when I vacuum. I have tried to raise the height of the head but it still happens. Can you tell me what could be causing rubber to burn? ...
The belt driving the brush roller in the power head is slipping. It is really just a big thick rubber band. Where it wears out it slips and burns due to friction.
Look at the bottom of the power head. There is a cover plate held with 2 to 4 screws. Remove the plate and you will see the roller and drive belt. Slip the roller out and remove the belt.
Go to your local vacuum dealer and get a replacement.
Installation is the reverse of removal.
Mar 06, 2010 | Kirby Generation 3 Bagged Upright Vacuum
Need a drive belt for a philips dvp3040/37 its the belt that slides the door open and closed.
Hi: i search belt and head fo my tape recorder philips aq 6455 and philips d6350. Thanks.
Cryptato@gmail.com
Nov 01, 2009 | Philips DVP3040 DVD Player
Replacement Heads for Arcitec Shaver
Hi!
You're looking for the RQ10 heads, which should be found easily via Internet search.
Apr 20, 2009 | Philips Health & Beauty
Phillips dvp3340V parts
Did you try to call the manufacture? the # 1-888-411-5477
goodluck and i will see if i can find where you can find the rubber belt.
Jan 21, 2008 | Philips DVP3340V
57 people viewed this question
 Grubhead
Grubhead
