Question about Briggs & Stratton Briggs Stratton Lawnmower Lawn Mower Short Block
I need the spark plug gap for a MTD mower model # 11A038A729. It has a Briggs 12M902 0451 E1. Thanks.
    President:
  • Briggs & Str... Master
  • 1,545 Answers
The proper gap is ..030" Here is the Briggs application chart for L-Head engines like yours.
http://www.manddsmallengine.com/briggs/info/plug7.html
Posted on Apr 11, 2011
What is the spark plug gap supposed to be?
Hi
If you enter your model number (and serial number if you have it) at the link below, you'll have access to your owner's manual which will tell you what your spark plug gap should be.
Hope this helps.
-Steve
Operators Manual
Apr 26, 2015 | Mtd 22" Yard Machine Push Mower
Briggs & stratton engine 500 series 158cc + spark plug gap
Look up your engine on the Briggs&Stratton website.They have all the specs. Or call MTD.
May 18, 2014 | Mtd 22" Yard Machine Push Mower
No spark on a 126T020675B2 Briggs 6.75 hp mower engine
gap needs to be 10 thousands of a inch done with a brass feeler gauge ..mag/flywheel has a spot with a magnetic field if you look you can see it it should make a 1/2 wrench stick to it if not replace mag/flywheel ..check key way also
Jun 05, 2013 | Mtd 22" Yard Machine Push Mower
What spark plug does my yard man lawn mower take? here are the numbers off the engine 110602-0131-e1
According to my data, you'll need a Briggs and Stratton Part No. 692051 for that machine. Cross reference to Champion Plug RC12YC. Note that this plug shows a recommended gap of only .020, as opposed to the .030, most Briggs plugs use. Best of luck to you.
Jun 29, 2011 | Mtd Yard - Man 160cc, 21" Self - Propelled...
No fire mtd 21inch 3.5hp
You should have a strong, blue sparlk. Make sure plug is grounded to engine when you test. Don't do it in the air. Check the flywheel/coil air gap. I think on Briggs it should be about the thickness of a standard business card. If after setting the air gap and there is no spark...plug is bad or ingition coil module is defective. When you adjust the gap, make sure the magnets in the flywheel are lined up with the "legs" on the coil to assure the correct setting.
Aug 11, 2010 | Briggs & Stratton Garden
Start and immediately stops
spark plug gap would be .030 and magnito gap would be .010. I would clean carberaor. Sounds like the main jet is plugged. Hope this helps you.
May 07, 2010 | Mtd 22" Yard Machine Push Mower
Need a spark plug size for a yardpro self propelled lawn mower model number yp6y22cha briggs and stratton 6hp
If your mower does not have "OHV", overhead valves. You can use a Champion j19lm spark plug.
If you discover you do have overhead valves; A Champion RC12YC, will work.
Apr 28, 2009 | Mtd 22" Yard Machine Push Mower
Briggs & Stratton Briggs  Stratton Lawnmower Lawn Mower Short Block Logo
786 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
