Question about LG WM1812C Front Load Washer
It stops mid cycle and at the digital display it flashes " LE " . What is wrong????
    Genius:
  • 1,044 Answers
The 'LE' error message indicates the control board has detected that the motor is either not turning, or has locked up for some reason. Monitoring the motor is the job of the hall effect sensor board which constantly determines the direction and speed of the motor and feeds that information back to the control board. If there is a problem between what the motor should be doing and what the hall effect sensor says the motor is doing, the 'LE' will be displayed and the cycle will be stopped.
Motor lock can be caused by several things from a loose connector, to a bad motor, or even the hall effect sensor failing or dislodging from it's mount. Any one or more of these components could have caused this error.
This error can sometimes present because of a miscommunication between the control panel and the wash motor. In this instance, the washer simply needs to be reset.
Step 1: Unplug the washing machine.
Step 2: While the washer remains unplugged, press and hold the [Start/Pause] button on the front panel for 5 seconds.
Step 3: Plug the unit back in, and run a rinse and spin cycle to test if the LE code is cleared.
Posted on Apr 11, 2011
IE is appearing on my washer? Stop is mid cycle. Whats wrong
sorry but no make ,no model ,no help can be given
Feb 22, 2015 | Washing Machines
Stop mid cycle
Hello Nick - Based on the symptoms you are describing, you may either have a communication error from the main control board or the timer itself may not be operating correctly. If you noticed a humming noise, it could either be a clogged drainage hose or pump that needs to be cleaned, or it could possibly have another issue with the door lock assembly. I would personally contact a professional to accurately diagnose the washer to determine the root cause to reduce the risk of unnecessary parts.
Jun 07, 2013 | Frigidaire FAFW3801LW Washer
2005/2006 model LG Troon washing machine. Washing cycle ok, spin cycle stops incomplete and LE shows on didgital display.
Hello & Welcome to FixYa
LE error in your LG front load washer is displayed when either the motor is not working or the control board thinks that the motor is locked up. A Hall Effect sensor is used in these washers which monitors the speed and direction of the motor and then forwards this information to the control board. Hope you understand by now that this LE error is displayed when there is an issue with the motor or when the Hall Effect sensor sends wrong signal to the control. Conclusion is you'll have to check both motor and hall sensor and replace the part# that is bad, usually I have seen the sensor going bad. Please get back to me if you have any other questions.
Kevin
Jun 14, 2011 | LG Washing Machines
Le light on stops mid cycle
'le' stands for Lock Error. There is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor. Both require a service engineer's attention I suggest ;-0(
Good luck,
John C
Mar 29, 2011 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Stops mid cycle. Light flashes, cant get it to move on so have to start all over again
Hi there.
I have the same problem with my machine. Whatever program I select, the machine runs fine until it reaches 54 mins of the cycle remaining. To overcome the problem just to select a cycle that will not stop mid cycle, select a program which is less than 54 mins. I think the 40 degrees and quick wash select is the one to run with. The cycle is 45 mins, obviously less that 54 mins. The LED timer will display the cycle time. No problems with this cycle whatsoever. Not the total solution, but at least you're able to complete a cycle. After it's completed, I also run the spin program at 1200rpm. I hope this helps.
Regards, Ian.
Nov 22, 2010 | AEG Lavamat 72640 Front Load Washer
Dishwashing cycle starts for about 3 minutes then flashing LE light comes on and the machine stops. Why?
Display Condition LE = Motor Error
Possible Cause For Error Occurrence:
Wiring connection is OK?
The Impeller of Washing Pump is locked.
The rotor of Washing Motor is locked.
The Blade is locked.
Remedy:
Check the wiring connection.
Replace the cause of restriction.
Replace the Washing Motor.
Replace the PCB.
Try the following steps:
Unplug the washing machine if you see an LE error on the two-digit display electronic readout. This error indicates a miscommunication between the control panel and wash motor.
Press and hold the "Start/Pause" button on the front panel for five seconds.
Plug the LG dishwasher back in.
Run a cycle. The LE code will clear.
Aug 31, 2010 | LG 24 in. LDF 7811 Stainless Steel...
LG WM3677HW combo unit sets a LE code and stops in mid cycle. Motor was replaced but still does it.
Sensor maybe???
Here is a tip about the LE code that gives other thoughts also...
heatman101
Apr 23, 2010 | LG WM3677HW 3.7 cu.ft. Front Load Washer...
I'm getting a code "LE".
LE IS A LOCKED MOTOR CODE CHECK FOR OBJECTS IN PUMP BUT THE HAD THAT PROBLEM IS THE PAST
Sep 26, 2009 | LG LDF6810ST Stainless Steel Built-in...
LG Washer / WM2487H*MA...2 days old. Wash setting...."Bulky/Large QUESTION:::When attempting to select additional "wash options" from the Option Buttons panel, I keep getting a display...
My LG Tromm washing machine just stopped in the middle of the cycle, It started flashing the letters LE, what does that mean. I have had it for 4 years and this has never happened.
Jul 27, 2008 | Washing Machines
LG WM1812C Front Load Washer Logo
302 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
