Question about Lexmark T632 Laser Printer
Hi. I have a Lexmark T632 printer. Sometimes it will print just fine and at other times I get a message that says 32 unsupported print cartridge. We have always used the same kind of cartridge to my knowledge. Can you tell me how to correct this problem? Thank you.
    Champion:
  • 254 Answers
You must clean the contacts on the top right hand side
Posted on Aug 19, 2011
How to work around the error message "unsupported print cartridge"
Hi
Try to use your search procedures to locate or "find" your printer. See if there is an exception to cartridges and change it.
May work
Mar 23, 2016 | Lexmark C510 Laser Printer
Hi, I have a lexmark x7170 and keep getting an error message "unsupported cartridge". Help please!!
If you receive an error message that tells you that you have an unsupported cartridge, then you need to remove the cartridge. After installing the appropriate type of ink cartridge you should no longer receive the error message and you can then perform a print test.
Instruction on how avoid unsupprted cartridge message.
  1. Lift up the scanner unit (with the power on). The printer cartridge carrier will move to the top of the printer into the loading position.
  2. Press down on the lever above the cartridge and then raise the cartridge lid. Remove the cartridge and make sure the cartridge supports no more than four colors (cyan, yellow, magenta and black) and a speed of 22 parts per notation.
  3. Insert the compatible ink cartridge into the carrier and then lower the cartridge lid. Close the scanner unit, then make sure plain white paper is inserted into the paper loader.
  4. Press the "OK" button on the control panel and the unsupported cartridge message should be gone. Press the "Select" button and a test alignment page will print.
Nov 21, 2010 | Lexmark X7170 All-In-One InkJet Printer
Lexmark T632 printing about 1/32" too high on form.
Hi, the only way to solve your problem is to change the layout of your form on your system. Good luck, Gerrit Jan
Jul 29, 2009 | Lexmark T632 Laser Printer
Lexmark T62 Error 32- Unsupported print cartridge
Hi Sue,
Firstly, switch on the printer without a cartridge inside. Put in the old cartridge and if you get the Error 32, it could be poor contact. Clean the contacts in the printer (contact with the chip on the cartridge). If you don't get Error 32, there could be a problem with the chip contacts on the new OEM Lexmark cartridge or a faulty chip. As for other brands or remanufactured cartridges, it could be compatible parts they used. The chip and toner wheel have to be compatible.
Good luck.
Dec 15, 2008 | Lexmark Optra T620 Laser Printer
Print head replacement lexmark t632
You will have to remove the top cover, both side covers and the rear door and redrive to get to it. Once these covers are removed you will need to remove three screws to release the printhead and disconnect a couple of cables.
I usually have to clip a couple of zip ties and use needle nosed pliers to get the cables out.
It is do-able if you are patient.
Nov 24, 2008 | Lexmark T632 Laser Printer
32 Unsupported print cartridge
This is caused by an unsupported chip on the toner. If its a reman toner ie. Office depot/nice day then you should ring them up and et them to arrange for a new one. if they say its not possible to have a faulty one they will be trying to fob you off. just as a guide lexmark have around a 7% failure on toners so your not the only one. if it gets to the point where youd like to put the toner in a certain place of the office depot's worker then you can always find a chip online from people such as static or delacamp. and they just pull out and slide in.
need any more help just email me:
pete@wedotoners.com
Oct 06, 2008 | Lexmark T630 Laser Printer
Unsupported cartridge message
I was having this problem with a Z730. The printer was finally working again after removing and inserting ink cartridge like 40-50 times. No pun intended. After installing cartridge try turning off printer and then back on.
Aug 19, 2008 | Lexmark X2470 All-In-One InkJet Printer
Incompatible print cartridges?
just click on them to say ok, and accept the unsupported cartridges ( if applicable ) do you get the choice.
certain printers, have an option in printer prefs, to change cartridges. check the cartridges are the same ( or compatable )
if the cartridges have a chip fitted, they need to be reset if recently filled.
hope this helps mike @ Compurepair.
Feb 20, 2008 | Lexmark X2550 All-In-One Printer
Unsupported cartridge error
I have an X5495 Lexmark and have recently been getting this **** "unsupported cartridge" rubbish. OS is XP SP2.
My history with this printer has been:
-when new, the printer worked fine until I needed to replace the original ink tanks. I refilled them, but could not get the printer functional again....nil print at all. After much frustration, I was informed by a little birdie that the cartridges that originally come with the printer will not work if refilled. Great. They are one use only.
-replaced with genuine high yield tanks. Then worked fine. Refilled once, possibly twice with suitable non genuine ink. Still working fine.
-once black ink tank ran low this time, refilled it and symptoms of no print from Word docs, not all parts of a web page would print. Surprisingly, photos off hard disc print ok.(??????)
-replaced black with genuine tank and colour with remanufactured tank. Error message of "unsupported tank". Now no print at all.
-left new genuine black cartridge in and refitted genuine colour cartridge that I have previously refilled.
-all print now ok.....finally.
Maybe they have a copy limit or the integrated print head in the black has crapped itself????????
During this process, I have uninstalled and reinstalled the driver several times.
I have found that it has to be COMPLETELY uninstalled. Using the Lexmark uninstall function does not remove all parts of the software (Lexmark toolbar for one). If the software is not completely uninstalled, you will get a spurious unrelated and rubbish pop up that installation cannot continue because of "insufficient processor speed" with a spurious set of numbers after it. This message bears no relation to the solution.
I have found that you need to search and delete ALL Lexmark files that you can find after the uninstall. I have also deleted entries from registry.....1 entry only from memory (be CAREFUL with registry). Then reboot system.
The driver should then reinstall correctly and fully.
Why do they make it so damn hard? Don't think I'll buy a Lexmark next time.......
Sep 05, 2007 | Lexmark X2350 All-In-One InkJet Printer
Lexmark T632 Laser Printer Logo
240 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
