Question about Hotpoint WMA46 Front Load Washer
WMA46 WASHING MACHINE DRUM WONT TURN AT ALL? - Hotpoint WMA46 Front Load Washer
    Brigadier General:
  • 6,277 Answers
This sounds very much like the belt is broken or the motor is malfunctioning.
Belt first.
Belts are not expensive- sorry I do not know how much yours would cost- and are easy to be changed by a competent person:-
REMOVE POWER FROM THE MACHINE AND REMOVE THE BACK.
The motor support bolts should be loosened and the old belt removed. Often putting the new belt on is a bit of a struggle, even with the motor 'loose', because it is new and smaller!
Once on it should be tensioned by pulling the motor against the belt firmly- but not over tight- and the motor support bolts tightened.
ON NO ACCOUNT SHOULD ANY FORM OF LEVERAGE BE USED TO TENSION THE BELT. THAT COULD LEAD TO DAMAGE TO THE BELT, MOTOR AND BEARINGS- EXPENSIVE!
If it turns out to be the motor, it is false economy to just have the brushes changed although financially very attractive. Experience of others is that the brushes may only last months unless, that is, the motor is totally refurbished at the same time. It depends on how old the motor is and how much wear the commutator has had. New motors are not cheap, though. It's your choice!
Hope this is your problem solved.
Good luck,
John C
If this has assisted you please score accordingly. Thanks!
Posted on Apr 11, 2011
The drum will not spin
The drive belt may have come off, or broken, have a look underneath the machine...
Nov 08, 2010 | Hotpoint WMA46 Front Load Washer
Noisy machine? What could be the problem
  1. machine not level
  2. bearings hammered
  3. broken shaft
  4. loose counter weights
  5. noisy pump
  6. something stuck between inner and outter drum
Sep 28, 2010 | Hotpoint WMA46 Front Load Washer
Please could you tell me where the filter is on my wma46
The filter is located at the rear of the washer.
Remove the lower rear panel of washer.
Remove large black hose fastened to bottom of drum.
Remove and clean filter inside hose.
Refit and test.
Please rate my solution.
Thankyou.
Feb 09, 2010 | Hotpoint WMA46 Front Load Washer
Fills water goes through program drum dose not
Remove the motor, and check the brushes in the motor, if o/k, then could be a board prob, or something as simple as a broken or bad connection.
Pleasre rate my solution.
Thanks.
Oct 10, 2009 | Hotpoint WMA46 Front Load Washer
WMA46 washing machine not draining, filter blocked but can't locate filter
the filter is underneath on the pipe going to the pump, you wiull need to remove a hose clip.
Jul 11, 2009 | Hotpoint WMA46 Front Load Washer
No drum movement during wash/spin cycle, although it fills/drains
brushes need replacing in motor. Usually cheap enough to buy and do yourself.
Jun 02, 2009 | Hotpoint WMA46 Front Load Washer
I have a Hotpoint WMA46 washing machine that it is very noisy
it sound like the main bearing at the back of the drum, you can get them for aroung £50 but an engineer may want a lot more. If you have had the machine for more than 5 years i would look at a new one.
Mar 04, 2009 | Hotpoint WMA46 Front Load Washer
WMA46
check that the outflow pipe is not blocked. Turn off power supply get a bucket ready, disconnect the outflow pipe from the u-bend under the sink and check that it is not blocked.
Mar 15, 2008 | Hotpoint WMA46 Front Load Washer
Washing machine fill but won't go through cycle.
Too empty your machine reset the programmer to Final spin. the machine should empty normally.
If you have a fast flashing light its most likely to be 1 of 2 things.
1. The belt from the motor has broken. (price for belt is less than 20 pounds.)
2. The brushes in the motor have worn down too much to make the drum turn. Look underneath the washing machine to see if black power (Carbon) is deposited under the motor.
(Price for set of brushes is less than 20 pounds)
Labour should be no more than half an hour by anyone decent.
Regards
Feb 22, 2008 | Hotpoint WMA46 Front Load Washer
WMA46 stopped woking power off mid cycle
hi there the problem you have sounds like the motor has shorted out causing the pcb to blow, sadly this is a costly repair and is usualy not worth repairing as you will need a new motor and pcb
murdozzz
Dec 09, 2007 | Hotpoint WMA46 Front Load Washer
Hotpoint WMA46 Front Load Washer Logo
71 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
freddyfox
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
