Question about Lands Phones
I have a BT Freestyle 1025 phone. I have replaced the battery in the handset,however a flashing c appeared on the base and the handset will not charge. Do you have any ideas?
You need to reset the date and time you an get details from the manual, which is available on-line
Posted on Oct 01, 2008
SOURCE:
How do I rescue my BT Freestyle 750 from being stuck "Searching" and remedies that are "Not Possible"?
Have you tried removing the batteries and letting the internal power decay for an hour or so - in other words try to get them to forget what they were. Then replace batteries and try again. I guess you've consulted the user manual, is there a reset button hole anywhere on the base unit? The sort you stick a pin into.
May 19, 2015 | BT FREESTYLE 750 TWIN DIG CORDLESS PHONE
Hanged batteries in handset but phone will not ring
Check to see if ringer is set to hi. make sure ringer is turned on. Check to see if the base and the phone are syncronized.
Jan 03, 2015 | BT FREESTYLE 750 TWIN DIG CORDLESS PHONE
How can I get new batteries
Normally in the BT range the batteries are rechargable, hence the base charger, so do not use ordinary batteries. If the phones are not charging, go to boots or tesco and buy AAA rechargeables 2 per handset. Once replaced allow at least 6 hours charge before use. After that just carry on as normal.
Jul 23, 2014 | BT Freestyle 750 Digital Cordless Handsets
Bt freestyle 1025
Clear the cables from any other cables (power cables etc) Try moving the base station slightly, it is most likely interference
Nov 04, 2013 | Lands Phones
BT Freestyle 750 is working but although the screen is bright nothing appears on it
Just restart your BT and try to access it again or else try to access your B.T within the range of your phone.
Apr 11, 2011 | British Telecom BT Freestyle 7100 Cordless...
BT Studio 3100 handset 1. Display flashing base 1, cannot go to setup menu, not changed pin code, turned off and on, removed batteries, turned off base unit, waited 20-30secs for all of above and still...
Help
My Bt Studio 3100 cordless telephone ( 2 Pack ). I have carried out the setting up procedures as per instructions.
Handset batteries are fully charged, but I am not getting the dialling tone.
Jul 11, 2008 | Lands Phones
BT Studio 1000 4 handsets
To Mrs Sue Groom,
You probably need to register the handsets to the base.This is the user manual for the BT Studio 1500
http://www.shop.bt.com/content/uni2/documentation/43py/023626.pdf
Mar 21, 2008 | Xact Communication XG2200 Cordless Phone
Signal indicator flashes constantly
The following worked when I had what appears to be the same problem. Solution :- Remove batteries, remove power connection, wait 30 minutes, re-connect power and replace batteries then press button on base until it beeps. Both handsets started continuous beeping which eventually stopped and everything was returned to normal. Admittdly this sounds almost identical to the process used by 'versailles' above, but at least it confirms that the technical info given by the BT Helpline does work
Nov 28, 2006 | British Telecom Freestyle 2200 Trio...
BT Freestyle 2200 I am having problems obtaining a dialing tone on both of my handsets. When I press the green button for a line out it just beeps 3 times and cuts off. There is charge in both the...
hi just want to help others as desciption aint complete above
Registering a BT Freestyle 2200 handset
1. If there is a handset in the base remove it whilst you are registering the new handset.
2. Press and hold the PAGE button on the base for about 10 seconds until you hear a beep and the In Use light starts flashing.
3. On the handset to be registered, press and hold redial & CALLSd buttons together until display shows 65-.
4. Enter the base number. If this is a new handset then the base number is 1, the display shows 65-1 then PIN. which is normally 0000
5. Enter and registration starts. When the handset beeps and returns to standby registration is complete.
Nov 08, 2006 | British Telecom Freestyle 2200 Trio...
Lands Phones Logo
160 people viewed this question
Top Lands Phones Experts
Ekse
Marvin
Marvin
Are you a Lands Phone Expert? Answer questions, earn points and help others
