Question about Dishwashers
Dishwasher teka uN-dw655fi not working after power failure, first 4 function lights just flash and beep
SOURCE: Baumatic 23 in. BDW5 Built
Does this when it can't drain properly - check there's no debris in the collecting basket.
Posted on Sep 13, 2007
  • 9 Answers
SOURCE: beeping dishwasher
I've not changed a control unit before, so I don't know how easy it is. I would suggest you get a fixed price engineer to come out and tell him in advance what the problem seems to be. Or call a Baumatic engineer and have the control unit sent by the spares department to your address in advance of the engineer's call out. Otherwise it will become around a month long wait and will require 2 visits. If you already have the part - then pehaps the repair won't be stretched over 2 visits?
Posted on Jan 25, 2009
SOURCE: cda cw 496 dishwasher runs cycle till rinse light
cda cw496 stops after a few minuts then just beeps help me with my problem please
Posted on Feb 16, 2010
  • 77 Answers
SOURCE: flashing start button, beeps, no other button functions
does it flash say 8 times then a little break then flash again 8 times or 9 or 10 . The flashes are giving the type of fault you have. Say 3 flashes then a tiny break then 3 flashes and a tiny break so on...
Posted on Mar 20, 2010
SOURCE: my rogram 2000 dishwasher is beeping and not
Hi
Did anyone answer you on this, my program 2000 dishwasher is doing the same thing. Any help?
Posted on Oct 05, 2011
All five lights are flashing on teka dishwasher
The control board could be at fault
Mar 26, 2013 | Dishwashers
L65X Dishwasher problem
has there been a soultion mine is doing the same?
Jan 10, 2012 | Dishwashers
The PC does not start.Only it beeps and a red light blinks,also fen is not working.
here are some of the basic codes, depending on which BIOS you have...
Also you do not indicate which fan? I would guess you mean the main Power Supply (PS)? In which case it could just be you need to replace the PS.
Here is a link to some other codes as well...
http://www.computerhope.com/beep.htm
AMI BIOS ERROR BEEP CODES
  • 1 Beep - Memory Refresh Failure (check memory)
  • 2 Beeps - Memory Parity Error in first 64KB block (check memory)
  • 3 Beeps - Memory Read/Write Error in first 64KB block (check memory)
  • 4 Beeps - Motherboard timer not functioning (possible motherboard replacement)
  • 5 Beeps - Processor Error (may need replacement Processor)
  • 6 Beeps - Gate A20/keyboard controller failure (possible motherboard replacement)
  • 7 Beeps - Processor Exception Interrupt Error (may need replacement Processor)
  • 8 Beeps - Display Memory Read/Write Failure (reseat or replace video card)
  • 9 Beeps - ROM checksum Error (replace BIOS chip or motherboard)
  • 10 Beeps - CMOS shutdown Read/Write error (possible motherboard replacement)
  • 11 Beeps - Bad Cache Memory - test failed (replace cache memory)
Phoenix BIOS ERROR BEEP CODES
Phoenix BIOS beep codes are a series of beeps separated by a pause, for example:
beep --- beep beep --- beep --- beep beep would be 1-2-1-2
  • 1-1-4-1 - Cache Error (level 2)
  • 1-2-2-3 - BIOS ROM Checksum
  • 1-3-1-1 - DRAM Refresh Test
  • 1-3-1-3 - Keyboard controller test
  • 1-3-4-1 - RAM Failure on address line xxxx (check memory)
  • 1-3-4-3 - RAM Failure on data bits xxxx of low byte of memory bus
  • 1-4-1-1 - RAM Failure on data bits xxxx of high byte of memory bus
  • 2-1-2-3 - ROM copyright notice
  • 2-2-3-1 - Test for unexpected interrupts
I hope this helps.
Mar 29, 2011 | HP Computers & Internet
The Drying light flashes and the unit beeps about once per second. At the same time the unit acts like it is washing (sounds of water washing insiide. The bottom is oompletely full of water.
so its beeping and flashing once per second correct this beeping and flashing is an error code that your unit is giving blinking lights or beeping sounds may indicate a problem with the dishwasher caused by power surges. To correct the problem, try pressing the "Start/Reset" pad to reset the dishwasher. If the problem persists, reset (reboot) the control by turning off the circuit breaker supplying the dishwasher for 30 seconds. Turn the circuit breaker back on and the dishwasher should function normally if you still have the flashing and beeping message me back Im going through the error code book as I type this if it still persists after you turned off the power then back on message me back with the number of beeps within 60 seconds as well as the number of flashing lights for instance if it does it every second or once every 5 seconds also if you have any further questions message me back them as well and please remember when our chat has fully concluded to rank how this opinion has helped it allows me to help others in similar situaitons Thanks Rick
Feb 04, 2011 | GE 24 in. Profile PDW9880JSS Built-in...
My Dell Inspirion Mini 10 is beeping 8 times when I turn it on. Nothing on the screen.
Try holding Fn + End with battery and power cord out and while still pressing Fn + End plug only power cable back in and try to power on.
Oct 12, 2010 | Computers & Internet
How do u clean the pump and drain hose on a teka dishwasher? please help
buy Finish dishwasher cleaning kit from the super market and follow the instructions on how to use it. The cleaning kit should be run with empty dishwasher.
THis should help clean the pump and drain hose.
It would help if you mention the model number of your dishwasher. It is hard to get an english manual for Teka.
I tried this site
http://instructionsmanuals.com/lista2-20-49-en-Dishwashers-Teka.htm
but they all seem to be in European languages.
May 25, 2010 | Dishwashers
My rogram 2000 dishwasher is beeping and not
Hi
Dec 07, 2009 | Dishwashers
Kitchenaid KUDS25SH
Hold the button down until it beeps and the light goes off. Eric
Sep 03, 2009 | KitchenAid 24 in. KUDS25SH Built-in...
Continuous beeping sound
Do you get video? If so then it could be a stuck key on the keyboard.
Do you get no video? If so then reseat the RAM.
Feb 10, 2009 | Sony VAIO PCV-RX370DS PC Desktop
Dishwashers Logo
122 people viewed this question
Top Dishwashers Experts
