Question about Whirlpool Washing Machines
Purc'd 4/25/10, just recently cold or cool water is extremely slow fillimg. WHY?
  • 4,399 Answers
Thanks for choosing FixYa and welcome to the site. You may have a pump going bad or the water pump may be clogged. Try taken it out and cleaning the pump. More then likely, this will solve your problem. Articles can get down there and clog the machine up.
Posted on Apr 11, 2011
Kenmore stack washer dryer.cold water fills extremly slow,hot water fine
Check the strainer at cold water inlet where hose connects to washer solenoid valve in the back. It’s most likely clogged with rust, sediment , sand, etc... just shut water off, unscrew the hose and you will see the screen in there. Also check the hose as some (not many) have strainers built into them at the connections .
Jan 27, 2018 | Kenmore Washing Machines
Cold water flow is extremely slow. have checked
REMOVE THE COLD WATER HOSE FROM THE WASHER, AN LOOK INSIDE THE VALVE, AN CHECK THE SCREEN, FOR BLOCKAGE, SPECIALLY IF YOU HAVE HARD WATER IN YOUR AREA.,
I HOPE THIS FIX YOUR PROBLEM LEAVE SOME FEEDBACK!
Feb 03, 2010 | GE Profile WPRE6100G Top Load Washer
Ice maker is extremely slow. it will take days to
change the cooling contro indicator to freezer max ..... that will increase the speed of cooling in ur freezer ....
Jan 03, 2010 | Kenmore 52632 / 52634 / 52639 Side by Side...
Cold water filling of tub is extremely slow. No kinks
turn cold water off and remove hose from washer,next remove the screen from the water inlet and clean it and place it back in the valve, place hose back on the inlet,turn cold water back on and test cold setting,you should have good flow.
Dec 25, 2009 | Roper RTW4300SQ Top Load Washer
Hot water valve is on but hot water runs extremely
Look under the sink at the water line. If it has a kink or a loop with a kink in it, the hot water will choke off. Make sure that the valve at the wall is also wide open.
Best regards,
--W/D--
Aug 14, 2009 | Plumbing
Cold water is slow when filling for rinse cycle
Turn off the cold water.
Remove the cold water hose from the machine.
Look inside the cold water inlet on the machine and clean the debris from the screen.
Problem solved.
Feb 22, 2009 | GE WJRR4170E Top Load Washer
Slow rinse cycle fill
take the hose off the cold water valve and check the screen on the water valve ,make sure the cold water is on all the way and the hoses are on the right valves get a water bucket hold the cold water line in it open the cold water valve to check the pressure
Jan 30, 2008 | Kenmore 98702 Stacked Washer/Dryer
Fisher&Paykel Smart Drive 601 Both Hot and Cold Water Fill very slowly
Hey there. I've had the same problem recently. It would fill slowly, and then after a while, it wouldn't fill at all. So I got some a new valve. it cost about $NZ30 delivered. You'll need one each for hot and cold. You can get parts from http://www.primedistributors.co.nz/. I think the part you need is 426142. you can check an image of it on the website. Good luck.
Aug 17, 2007 | Fisher and Paykel GWL11 Top Load Washer
Washing Machines Logo
73 people viewed this question
Dan Webster
Dan Webster
Sal De
