Question about Panasonic SC-HT920 System
Model scht940 error code f61 - Panasonic SC-HT920 System
    Brigadier General:
  • 8,546 Answers
F61 usually means the amp has detected a short or a severe microprocessor error.
Generally speaking, an amp protects itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as a root cause for intermittent shutdown.
Posted on Apr 11, 2011
AFTER A FEW SECONDS MY SYSTEM SHUT DOWN AND SHOWS ME F61 ON THE SCREEM
  1. AFTER A FEW SECONDS MY SISTEM SHUT DOWN AND SHOW ME F61 ON THE SCREEN
Oct 25, 2010 | Panasonic SC-AK300 CD Shelf System
Stereo error code
There are numbers of possibilities that can make your Panasonic stereo system indicates an F61 error code. Almost 100%, the system may not be able to recover from that error code, thus, it is advisable to bring your stereo system to your nearest Panasonic repair center.
By the way, May I know the model number? ...
Mar 14, 2010 | Panasonic Audio Players & Recorders
F61 Error message on screen. We can't get the player to even turn on.
Most likly needs an output or voltage IC. Could be other things like a bad fan or other componant. With Panasonic models F61 is a bad voltage code.
Feb 01, 2010 | Panasonic Home Theater System System
Error code F61
Please describe your f61 error code problem:
Aug 09, 2008 | Audio Players & Recorders
Panasonic home cinema model sa-ht75 . shows f61 disconnet output ic ,still shows f61
F61 error codes could either be IC501 or the regulator (IC502) in the power supply section.
For reference, pls view these two (2) posts here and here of similar concern on other models.
Other possibilities are:
1. fan not turning;
2. cold solder;
3. looses connections;
4. one of the other components/systems hooked up to the power supply is causing a fault (tuner, disc player).
Hope this be of additional help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Apr 26, 2008 | Televison & Video
F61 error code
i have an error code coming up on my panasonic sa-ak640 it's saying error code f61 can you help me please
Apr 02, 2008 | Panasonic SC-AK640 Shelf System
F61
i had the same problem with the error code f61.There are 2 fans,1 external and 1 internal and were both working but were very clogged up with dust thus working harder.Try cleaning them both it worked for me on the SA-HT 990 model
Jan 10, 2008 | Panasonic sa-ht800V Home Theater Audio...
Panasonic SC-HT920 System Logo
100 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
