Question about Epson Stylus Photo R1800 InkJet Printer
Paper wont feed
Trash can symbol comes on and the paper just sits there
  • 5 more comments
  • brightleaf Aug 23, 2008
    Yeas I have the same problem of the trash can light turning red and won't turn off.  Help!
  • photokaren Aug 24, 2008
    printer does not grab the paper either with sheet feeder or with manual roll single sheet feeder when using correct paper--red paper light comes on and nothing more happens--printer utility says either " communication error"  or "paper out or media not loaded correctly"--Karen at
  • lralston Aug 29, 2008
    I have the same problem. I've tried putting in one sheet at a time. I've tried loading 10 sheets. "Media missing or not loaded properly" or "communication error". Neither of these are referenced in the printer user's guide. HELP!
  • kimmanleyort Sep 24, 2008
    Cannot get manual roll feeder to work. Also have problem when using odd sized paper, such as cards.
  • Anonymous Oct 22, 2008
    Odd sized paper (10.5x13) but I created a correct setting for it in page size, printed with that one, and correct printer selected. Still get "media out msg.
  • CarCM Nov 10, 2008
    Will not accept watercolor photo paper and really difficult to get to printer not to reject photo glossy.
  • suecraik Dec 09, 2008
    we have the same problem
  • 48 Answers
It's just one of four things............
1. The paper is not loaded correctly on the correct path.
2. The paper is loaded correctly on the correct path but the "PAPER PATH" selected in the printer driver box or printer preference or application used is not set correctly to grab the paper from the correct path.
3. The paper path sensor is defective which means that the printer needs to be taken to a servicer or you need to contact epson for warranty options
4. The paper being used is too thick for the printer to feed it
Posted on Sep 05, 2008
When I turn on the printer, the carriage roller keeps turning but nothing else happens. The power light does come on. This happens whether or not the USB cord is connected to a computer.
You might try to see if a piece of paper or trash is under the roller. There is a device on printers that lets it know when paper is fed to it and you may have a piece of trash fooling the device to think it has paper and needs to run the roller. Or feed paper into it and see if that will clear it up.
I f none of that helps, go to:
where they offer Live Chat help on your machine.
Jun 30, 2011 | Lexmark Z65 InkJet Printer
Second hand Ricoh FT7950. Paper wont feed from
Going strictly from memory as this is an older model.
With the machine sitting ready to make a copy open the finisher door and close it . Are there any signs of life ie rollers spin tray moves stpler homes up?
IF yes I would look at the finisher entrance sensor as these get pretty dirty ith paper dust(or could be out of alinment from moving.
IF No then I would look at the finisher connector inspect for any damage .
Hope this gets you in the right area
Apr 03, 2010 | Ricoh FT7950 Copier
HSM AMA 125HS-6 Starts to shreed and abuptly stops. Red light comes on next to a circl symbol.
Thickness of papers is too much. Feed only 1-2 pages at a time.
To clear, pull paper back out. Run reverse, then forward, then feed 1 page at a time using a clean edge.
Sep 13, 2009 | Office Equipment & Supplies
Large spring found in back paper tray, now paper wont feed thru.
You must open case first, dismantle paper feeder, and refit it. For printer diagram, try to find at
Aug 10, 2009 | Epson Stylus C86 InkJet Printer
Printer does not print
Trash and re-install the drivers.
Let me know if you need instructions in properly trashing the drivers and getting the proper driver compatible with your operating system. include the full version of the operating system you are using.
sherlyn c.
May 23, 2009 | Epson Stylus C86 InkJet Printer
Red light flashing, And little cartridge symbol on printer screen,
hi i,m iskandar how cant solve the trouble for flashing led resume hp deskjet f2180 thanks
i wait yor reply solution
Jan 23, 2009 | HP Deskjet F2180 All-In-One InkJet Printer
Sharp AL-800 Paper Feed
Is this something that has been getting worse or just happen at once? If it just appeared it good be something in the paper tray stopping it from liftting or something behind the paper tray or in the paper path of the copier. If it has been slowly happen try to clean the paper pickup rollers with WD-40 and a rag and clean the rubber only. If that works you done, but if it say's to add paper you may have a broken paper present sensor. The jams could also be the paper feed clutch is worn out. Worse case use the bypass tray. Good Luck!!
Feb 07, 2008 | Sharp AL 800 Copier
Hp paper feeder wont thu printer
paper feed rollers wont feed paper through and also paper tray is empty prompt comes up when there is paper in the tray tried small amounts of paper and still says tray is empty
Dec 27, 2007 | Canon PIXMA MP600 all-In-One InkJet...
Epson Stylus Photo R1800 InkJet Printer Logo
536 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
