Question about Car Audio & Video
I need a diagram of the fuel system as my fuel gauge registers empty all the time
  • 76 Answers
Wat type of car is it and model i could try to get one
Posted on Apr 11, 2011
Fuel pump wiring diagram
there is two things : fuel gauge and dash fuel gauge. The fuel gauge in tank rated to 0 to 90ohms.disconnect wire at the tank take a variable resistor connect it to wire .read the dash gauge if it move as you move the resistor. if ok fuel tank gauge is at fault
Aug 09, 2013 | 1998 Chevrolet K1500
Fuel gauge registers full when ignition is switched on
Bad fuel sender unit or fuel sender wiring
Feb 03, 2013 | 1989 Jeep Wrangler
My fuel gauge floats from full to empty when I stop at a light! And its stays on empty until I drive for about five minute why is that? I can't get an accurate fuel reading!!
I have the same vehicle and my car actually was full of gas, registered empty & left me on the side of the road..It was the sensor in the fuel line that had to be replaced.
Feb 03, 2012 | 2003 Buick Rendezvous
Gauge registers 3/4 full when full, then needle slowly goes down to empty. Flucuates between empty and 3/4 full while driving.
hi its either the fuel gauge playing up in the dash up or the fuel sender on the fuel pump in the tank
Jul 12, 2011 | 1995 Subaru Legacy
1996 ford ranger fuel gauge stuck on empty
It's not really easy to tell, you need to test for power and ground at the sending unit at the fuel tank, while someone is watching the fuel gauge inside the vehicle. 90% of the time (especially on Ford's) it's a faulty sending unit in the fuel tank, which is usually sold with the fuel pump...if not, I would replace the pump while I had the tank out anyway just as a precautionary measure.
. the "float' is the part that of the sending unit that registers fuel level and sends that
Dec 13, 2010 | 1996 Ford Ranger SuperCab
Fuel gauge reads E when first started, jumps to F after awhile
It is more likely to be the fuel guage sender which is faulty.
Aug 21, 2009 | 2002 Audi A6
My fuel gauge goes to full when i fill it but drops to E when i stop for something 83 ranger 2.3L
Sounds like it is time to replace the sending unit to the fuel gauge in side the tank. It registers until the fuel sloshes around in the tank and the movement causes the float to bounce around and then it shorts out the sending unit so it can 't register. The sending unit has two surfaces that must remain in contact to register. After years of moving around it develops play in the pivot point that causes a gap in the connection and thus a false reading. You will need to remove the fuel tank to accomplish this replacement. Remember be careful if you undertake this task. You will have fuel and vapor in the tank. Empty as much fuel as possible first.
Mar 05, 2009 | 1983 Ford Ranger
Full tank-fuel gague registers empty-need fuel light is on
There is a sending unit in the fuel tank that registers how much fuel there is. It is probably broken, giving you a funny reading on your gauge.
Feb 02, 2009 | 1993 Jeep Grand Cherokee
FUEL GAUGE AND LIGHT STAYS ON NEARLY EMPTY AFTER PUTTTING IN PETROL.WHATS THE MOST LIKLY FAULT. DODGY GAUGE OR FLOAT IN PETROL TANK.THANKS FLYNN.
Do you mean that the gauge registers as empty, even after the tank is filled? Probably the sending unit needs to be replaced (it's in the tank, likely partially attached to the fuel pump).
Jul 27, 2008 | 1997 BMW 318
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
