Question about Mitsubishi WD-60735 Projection Television
RED LIGHT CAME ON WAS TOLD NEEDED NEW LAMP STAUS LIGHT NEED TO REPLACE IT HOW MANY SCREWS IN BACK DO I NEED TO REMOVE TO GET TO LAMP AND APPROXIMATELY HOW LONG SHOULD PUTTING NEW LMP IN TAKE AND DO U HAVE ANY VIDEOS TO SHOW ME
  • 325 Answers
You must locate your bulb (usually from the front lower cover of your tv). Some tvs the bulbs are reached from the back. Bulb replacement is about a 30 min job (if you're fast at taking screws out).
Here is a video of putting your NEW bulb in the OLD housing:
Just locate your old bulb, watch the video and you'll be running again in no time!
Thank you and please rate!
Posted on Apr 11, 2011
How do i replace fog light on picasso xsara 05
Jack up front; remove road-wheel (support Picasso on axle stand).
Remove two large torx screws on lower edge of bumper and peel back wheel arch liner (wedge behind hub).
Remove small torx screw holding black plastic support piece below lamp.
Remove 4 torx screws on holder surrounding lamp, pull back holder and support piece and lift out lamp (minding hands on broken glass)
Note that the body coloured bezel will try to fall outwards at this point.
Fit new lamp and push bezel in at the same time.
Refit all screws in reverse order, refit wheel etc.
(Total time 25 mins)
Aug 16, 2015 | 2005 Citroen Xsara Picasso
Hi i have a sony lcd projection kdf-e50a12u and as i turn it on the green light flashes for a few minutes untill it turns to red along with the light next to it and stays red?
Sir check the lamp of your projection if already damage, if damage replace the lamp and reset also the lamp hour meter. Remove the screws to open the panel labeled "lamp" on the back of the Sony TV. Remove the screws that hold the lamp in place inside the TV. Pull the lamp out. Let me know what is your observation to the lamp so I can guide you. Good day and best regards.
Sep 15, 2011 | Sony KDF-E50A12U 50" LCD HDTV
Rear turn signal b ulb burned out - How to replace
Rear Turn Signal, Brake and Parking Lights
  1. Remove the tail light assembly screws, then the assembly.
  2. Disconnect the twist lock socket from the lens housing. NOTE: To remove the bulb, turn the twist lock socket (at the rear of the housing) counterclockwise 1?4 turn, then remove the socket with the bulb; replace the bulb if defective. Fig. 7: Remove the tail light assembly screws, then the assembly - wagon shown 86816223.jpg Fig. 8: Twist the socket counterclockwise to remove from the housing 86816225.jpg Fig. 9: This type of bulb simply can be pulled out of the socket for replacement 86816226.jpg To install:
  3. Attach the socket assemblies to the back of the lamp unit.
  4. Install the lamp assembly to the vehicle with the mounting screws.
License Plate Light
  1. Remove the lens screws.
  2. Once the lens is removed you, can access the bulb and replace if needed. To install:
  3. Install the new bulb, then attach the lens to the body of the vehicle.
Center High Mount Stop Lamp
  1. Remove the screws securing the lamp cover.
  2. Remove the mounting nuts, then unplug the electrical harness to the lamp assembly.
  3. The lamp now should come out. To install:
  4. Position the lamp assembly to the vehicle, then attach the electrical harness to the lamp.
  5. Install the mounting nut, tighten to 62 inch lbs. (7 Nm).
  6. Attach the lamp cover. Fig. 10: Exploded view of the center high mount stop lamp assembly - wagon shown 86816230.gif
    Fig. 11: Light bulb application chart for all models with non-European headlamps 86816237.gif
    Fig. 12: Light bulb application chart for Buicks with European headlamps 86816235.gif
    Fig. 13: Light bulb application chart for Oldsmobiles with European headlamps 86816236.gif
Dec 19, 2010 | 1994 Buick Century
I have a front headlight out on my 1998 Mercury Mountaineer. Can I replace the bulb only or do I need to replace the entire headligjt?
according to the book, you have sealed beams--one piece:
To Replace:
  • Remove the headlight bezel retaining screws. Remove the bezel. If necessary, disconnect the turn signal lamp wires.
  • Remove the retaining ring screws from one or both lights.
  • Remove the retaining rings.
  • Remove the light from the housing. Disconnect the wiring connector from the back of the light.
  • Push the wiring connector onto the prongs at the rear of the new light.
  • Place the new light in the headlight housing. Position it so the embossed number in the light lens is on the top.
  • Place the retaining ring over the light and install the retaining ring screws. Tighten them slightly.
  • Check the aim of the headlight and adjust it, if necessary.
  • Install the headlight bezel. Secure it with the retaining screws.
  • Connect the turn signal lamp wiring (if it was disconnected).
Sep 28, 2010 | Mercury Mountaineer Cars & Trucks
I need to change the light bulb in my DLP TV. Where can I call to have someone do this?
You do not have to call anyone, this is a customer replaceable part and is fairly easy to do.
You can buy the lamp on the internet--get one from Samsung. Let me know model number---lamp is either at the back of the set or one side and the owner manual will tell you where.
I am willing to help you replace the lamp--it is a ten minute job and you should not have to pay someone to do it.
Usually all that is needed is to remove the door that covers it (one screw) and remove the two screws that hold it in; there will be a handle on the lamp housing and you just pull it out, insert the new lamp and put the screws back, the door back and bingo you are in business.
Let me know if you have questions and if you give me the model number (it is on the right side of the set and on the back of the set as well) I will get you a part number and tell you how to find it on the internet--most places like Samsung will ship it fast and give a warranty--do not buy a generic lamp--they are no bargain.
The lamp was meant to be replaceable by the customer and is easy to do.
let me know the model number and if this information has told you something you did not know rate this solution as "very helpful" as I do this here for free.
I am here to help you, let me do that.
REGARDS, SD TECH
Aug 11, 2010 | Samsung Televison & Video
Making clicking sound when turning on but won't come on then green light goes out and red lamp light comes on
You need to replace the lamp. It is located in the back on the lower right side. It costs around $130.00 with the housing and only takes 5-10 minutes to change. You need to remove about 5 screws and slide the lamp out then slide the new one in and replace screws. Hope this helps.
Jul 09, 2009 | Mitsubishi WD-65736 Television
Good sound, no picture, green standy light flashing
Replace the lamp-mine just went out also and sony told that I just need to replace the lamp---after a while the lamp indicator light will turn on red if and blink if this is your problem....also note to make sure it is your lamp unplug your tv from the wall or surge protector for atleast a minute or 2 and then replug it back in and see if the lamp light blinks red? If it doesn't then you got something else wrong. I hope this helps...if you need further assistance contact sony online via chat at sony.com and they'll help you fix the problem in no time. Take care
Mar 30, 2009 | Sony XL-2100U Projector Lamp for...
Red lamp light comes on. do i need a tech or can i replace
You will be able to do it your self.. On the back of your tv there will be a door held in place by philips screws. Take the door off and then the lamp is secured by a few more coin screws( a nickle works). Remove them and remove your lamp.. Install your new lamp be very carefull not to touch your bulb. (it causes premature bulb failure..due to the oils on your skin) put all the screws and door back on (will not operate without the door) plug it in wait the 90 seconds for mitsubishi to reset then your done.. here is your lamp part number
915P049010
Mar 16, 2009 | Televison & Video
Lamp out ...
remove front panel under screen, rove screws from lamp access panel cover. then remove the screws from the lamp assembly housing pull lamp housing straight out. install new lamp in the housing and slide the cartridge back into set replace screws and access panel cover.
Apr 09, 2008 | Mitsubishi WD-62327 62" Rear Projection...
Mitsubishi WD-60735 Projection Television Logo
158 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
