Question about Kirby Ultimate G Bagged Upright Vacuum
I can't get the belt on. I need help. - Kirby Ultimate G Bagged Upright Vacuum
I need a belt for a shark model #v131optn power pet upright bagless vacuum
Mark, Google search for a near by vacuum shop and stop in and get a belt or google search your make and model, Belt. Check the attached links for replacement belt, Good luck.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.sharkclean.com/parts/0/all/484/replacement-belts-2
Vacuum Cleaner Belts Walmart com
Vacuum Cleaner Belts at Ace Hardware
Jul 14, 2016 | Shark Vacuums
I need a belt routing for a toastmaster 3430b humidifier, looks like it needs two belts
There are actually 3 belts. One large belt from the fan to the pulley, and two identicle smaller belts that connect the pulleys. here is a pic I took of mine. Hope it helps.
Oct 04, 2010 | Vacuums
Is the dial on the head supposed to be turned to belt on or belt off when vacuuming
HI There,
This is a confusing system that Kirby has designed here. This is a source of many questions that we field on a daily basis. There is an exact procedure that needs to be followed when removing the head of the machine that has the roller brush and belt.
You need to have the dial set to Belt On when vacuuming, but when you first put the head back on after using the attachment hose, shampoo attachment, or replacing the belt, you need to first put the head onto the front of the Kirby with the Belt Off setting, then after it's connected to the front, turn the dial back to belt on.
Here's a helpful video that we've recorded showing the exact proper procedure you need to follow on your Kirby. This will also show you how to do basic maintenance on your Kirby's roller brush.
Hopefully this was helpful for you. If you have any follow up questions, or need further help on anything for your Kirby, please feel free to use the comment field here on Fixya, and I'll be more then happy to answer any of your questions. If you found this helpful, please be so kind and rate my repair helpful, or leave feedback for me.
Thanks so much,
Chris Jones
GoVacuum.com
May 07, 2010 | Kirby Generation 3 Bagged Upright Vacuum
Brush not moving, suction working
This machine is made for Sears by Panasonic. The power head, depending on model has a "gear" / cog belt or a standard flat rubber belt. First turn the power head over and see if the brush roller turns easily, if so you do need a new belt. To access the belt you will have to remove the hood from the power head. There are 4 screws, one at each of the corners to take out. Once the hood is off you will see where the belt goes and find "teeth" in the motor shaft for the motor / brush roller if you need a gear belt. If both of these are flat you need a rubber belt.
You can go to sears.com and find the belt you need with the vacuums model number.
Apr 27, 2010 | Kenmore 22812 Bagged Canister Vacuum
Need to check , belt , donot where to check,on
If you click on this link, it will take you to a website that has instructions with illustrations to show you how to change belt.
Hope this helps.
http://www.info-vacuum-cleaner.com/hoover-vac-belt.php
Aug 21, 2009 | Vacuums
Eureka Boss Model 4703 Type Belt Problem
Belt can be purchased from amazon, click here and take a look: Amazon com eureka boss vacuum belt. I hope this was helpful. Cheers
Apr 11, 2009 | Vacuums
Need to replace vacuum belt
how do i change belt on morphy richards ultralight cyclone cleaner?
Jan 04, 2009 | Vacuums
Kirby heritage II
As long as it is Kirby belt - you should be fine. Make sure that the shaft is clean and that you do not vacuum something greasy or wet (grease or oil will lubricate the belt and shaft will loose the grip -heat up and burn). Make sure that brush roll spins freely.
I am assuming you know how to put the nozzle on properly (if you not sure - go here)
Good Luck
Rocky
Aug 22, 2008 | Kirby Heritage II Vacuum
Kirby Ultimate G Bagged Upright Vacuum Logo
26 people viewed this question
Top Kirby Vacuums Experts
JoeVacs
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
